Mcwhit02 Samba Member
Posted: Wed Aug 13, 2025 12:43 pm Post subject: Thumping Noise From Front Suspension |
| 1972 Super Beetle. I get a thumping noise from what I am thinking is the front suspension on rough roads and bumps. What is the best way to diagnose/repair the issue? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33478 Location: Hot Arizona
Posted: Wed Aug 13, 2025 2:08 pm Post subject: Re: Thumping Noise From Front Suspension |
Get front end up on lift or jack stands, and pry with long bar to look for loose part. Or let an experienced mechanic do that. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Aug 13, 2025 2:44 pm Post subject: Re: Thumping Noise From Front Suspension |
| Thank you |
redhot Samba Member
Posted: Thu Aug 14, 2025 11:45 am Post subject: Re: Thumping Noise From Front Suspension |
If you are indeed sure of front suspension there are some easy checks/inspections that informs a lot. Such as strut bearing, wheel bearing, just knowing if balljoints and/or rubber bushings are very old or farily new etc.
Basically, looking at the diagram you will see a lot of possible culprits - while remember to include steering in addition to suspension...
Posted: Fri Aug 15, 2025 7:31 am Post subject: Re: Thumping Noise From Front Suspension |
| Thank you. Where did you get the diagrams? |
vamram  Samba Member
Posted: Fri Aug 15, 2025 12:14 pm Post subject: Re: Thumping Noise From Front Suspension |
I had a thump once when I was missing this bell-shaped metal bushing at that top of the strut. With it missing on a stock strut as in the manual pages above, you'll have like 1/2" of play that will thump. It's #5 in this page borrowed from the samba gallery:
_________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
Posted: Fri Aug 15, 2025 2:15 pm Post subject: Re: Thumping Noise From Front Suspension |
| Thank you |
redhot Samba Member
Posted: Fri Aug 15, 2025 4:07 pm Post subject: Re: Thumping Noise From Front Suspension |
| Mcwhit02 wrote: |
| Mcwhit02 wrote: |
| Thank you |
The diagrams comes from the different documents available via the TheSamba technical archives. If you hover above the images with the points, you should be able to see the address/link and navigate according. I think these were the "what is new" for the 1971 year list/postings.
Here is the common link; https://www.thesamba.com/vw/archives/manuals/71vwprogram.php
And also; thanks for just saying thanks to any one of the repliers trying to help - not always people extend such curtoesy in general, so worth itself to comend  |
Posted: Mon Aug 18, 2025 10:58 am Post subject: Re: Thumping Noise From Front Suspension |
| Thank you for the help |
mrinnovation1 Samba Member
Posted: Mon Aug 18, 2025 11:08 am Post subject: Re: Thumping Noise From Front Suspension |
| Tire belt separation will give you a thumping noise. Often it is not visible until the tire is taken off of the rim and you can see the inside. It happened to me some years back and was not always audible or felt thru the steering wheel. I could feel it on a right-hand turn. The tire was the left front. |
Posted: Mon Aug 18, 2025 1:32 pm Post subject: Re: Thumping Noise From Front Suspension |
| I'll check that out. Thanks |
