Can I remove the top layer of paint safely on this beetle wheel?
jonat
jonat is offline
PostPosted: Fri Aug 15, 2025 4:14 pm    Post subject: Can I remove the top layer of paint safely on this beetle wheel? Reply with quote
The original paint looks to be present underneath all this top layer of paint which must have been painted by brush years ago. This is the spare tyre in the boot.
Is there a way to remove this top thick layer safely without damaging the original bottom paint?
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Aug 15, 2025 4:21 pm    Post subject: Re: Can I remove the top layer of paint safely on this beetle wheel? Reply with quote
Unlikely. And it probably isn't pretty since someone felt the need to respray it.
I'd remove as much paint as possible mechanically, then smooth it, and respray with Wurth or other matching silvertone paint.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
jonat
jonat is offline
PostPosted: Sat Aug 16, 2025 11:30 am    Post subject: Re: Can I remove the top layer of paint safely on this beetle wheel? Reply with quote
You might be right. Seems quite rusty in places so probably not worth it.
I’m considering having the whole set of 5 powder coated in the closest match of diamond/metallic German silver which the local powder coater had which looked near spot on to the correct L91D
hitest
hitest is offline
PostPosted: Sun Aug 24, 2025 11:46 am    Post subject: Re: Can I remove the top layer of paint safely on this beetle wheel? Reply with quote
Originally those wheels (and many other models) were coated from the factory completely in black. Then a template was laid over just the fronts for a coat of silver paint. You can see the fade around the lug bolt areas.
That said, I often powder them black and spray a good coat of silver myself. The result is more factory on the inside rim face as well.
FU#5
