What Wheel Bearing For AC Industries Disk Conversion
DavyBoy1
DavyBoy1 is offline
PostPosted: Sat Aug 23, 2025 4:37 pm    Post subject: What Wheel Bearing For AC Industries Disk Conversion Reply with quote
Hi All,
I was really hoping for some help with this and apologies in advance for my very limited knowledge, I am no mechanic but trying to learn as I go!
I bought my dream Kombi three years ago (1962 RHD German Splitty), she was fully restored by the previous owner 8 years ago.
I have a big trip planned in October from Sydney to Melbourne & back again which will be over 2,000 Km’s so I have been doing some maintenance in preparation & replacing the front wheel bearings is part of this.
What I know
• Front Beam – 68 bay window ball joint
• Spindle – I think that is original
• Brakes – AC Industries 5 wide (5 x 205) Disk conversion Kit (From SoCal Imports, I believe)
I guess my Question is What Wheel bearings do I need?
Will it be for a Split Bus or a Bay Window?
Thanks in advance
Culito
11010101
Culito is offline
PostPosted: Sat Aug 23, 2025 11:24 pm    Post subject: Re: What Wheel Bearing For AC Industries Disk Conversion Reply with quote
I think you're just going to have to remove them and find some part numbers, or contact AC Industries.
Assuming the bearings look good, a simple clean and re-pack should be just fine.
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
DavyBoy1
DavyBoy1 is offline
PostPosted: Sun Aug 24, 2025 3:48 pm    Post subject: Re: What Wheel Bearing For AC Industries Disk Conversion Reply with quote
Thanks Culito, agreed that was my next step, I wanted to change the bearings as I am getting a little scraping sound when I turn right.
A friend of mine is a mechanic and had a good look over all of the running gear and brakes and he cant see anything either.
I thought I will give the whole area a good overhaul.
jeffavatech
jeffavatech is offline
PostPosted: Sun Aug 24, 2025 4:59 pm    Post subject: Re: What Wheel Bearing For AC Industries Disk Conversion Reply with quote
The disc pads are D696. From 89-99 jetta / passat.
Bruce Amacker
Bruce Amacker is offline
PostPosted: Tue Aug 26, 2025 2:42 pm    Post subject: Re: What Wheel Bearing For AC Industries Disk Conversion Reply with quote
I doubt it's the bearings making your noise, it's likely a flake of rust in the wrong place making noise. If the bearings were lubed and adjusted correctly going together you'll never wear them out.
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
