2003 Floppy review mirror
67rustavenger
67rustavenger is offline
PostPosted: Thu Nov 06, 2025 4:14 pm    Post subject: 2003 Floppy review mirror Reply with quote
Hello, after my van spent a month in the shop getting an electrical issue sorted.
I picked it up today.
I needed to readjust the interior rear view mirror and noted the rather floppy windshield stalk when making the adjustment.
It's been like this since I bought the van and I have never really took a good look at the mirror attachment to the windshield.
When I got home from the shop. I twisted the mirror stalk 90° to remove the mirror.
Looking at the springs that hold the mirror stalk to the windshield mount, I can see that there is some spring steel that clamps to the mount.
Can those spring steel brackets be bent to tighten the mirror stalk to the bracket?
If anyone has dealt with this issue, how'd you bend the springs for a tighter grip on the mirror stalk to the windshield mount?
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
50Splitman
50Splitman is offline
PostPosted: Sun Nov 09, 2025 9:58 am    Post subject: Re: 2003 Floppy review mirror Reply with quote
I have this exact issue and haven’t been able to resolve it yet, and it has become quite annoying. Keeping and eye on this thread. My current thought is to fabricate a shim to sit between the mounting elbow and the windshield to add some friction and stabilize the mount if the spring portion cannot be remedied.
67rustavenger
PostPosted: Sun Nov 09, 2025 4:12 pm    Post subject: Re: 2003 Floppy review mirror Reply with quote
Rather than bending the spring steel on the mirror stalk.
I'm gonna try using some gasket paper to go between the stalk and the windshield mount to place some tension on the stalk and hopefully eliminate the floppy condition.
I'll give this a go tomorrow and report back if that improves things a bit.
Buy Once, Cry Once!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Nov 09, 2025 4:15 pm    Post subject: Re: 2003 Floppy review mirror Reply with quote
Spring steel has a memory returned to it's original shape. If you try to bend it, be careful since it can snap.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
67rustavenger
PostPosted: Sun Nov 09, 2025 8:07 pm    Post subject: Re: 2003 Floppy review mirror Reply with quote
Thank you Glenn.
The spring steel is less of a concern that the terrible pot metal the springs are mounted to.
When looking at the springs, the pot metal tabs look fragile.
That's why I want to try a few simple things before trying to bend the spring steel back in place,
Buy Once, Cry Once!
vwplenty
vwplenty is offline
PostPosted: Tue Nov 11, 2025 11:42 am    Post subject: Re: 2003 Floppy review mirror Reply with quote
I filled the area around the metal clip with epoxy and the fix has lasted 6 years. Take the mirror off, push the clip tighter, fill around it and keep rotating the arm to keep the epoxy from getting in the wrong place until set. Use a faster setting epoxy.
I just tried to take my mirror off to take a picture for this post but it did not want to slide off the windshield clip.
Cheers,
Robert
2002 MV 190K
67rustavenger
PostPosted: Tue Nov 11, 2025 12:11 pm    Post subject: Re: 2003 Floppy review mirror Reply with quote
Ok so, I mended the floppy issue for the time being.
First I made a rather thick gasket from material that I use for making fiber type 1 intake manifold gaskets from.
When I tried to mount the mirror on the windshield mount it was a No Go! Dammit!
Ok, next attempt was using a manila file folder for the gasket material.
I used the mirror stalk base as a template to get the outside diameter pretty close as to be hidden when the mirror was mounted.
I cut the center out in a crude star pattern so the gasket would slide over the windshield mount then, Mounted the mirror.
Success! Very Happy No more floppy rearview mirror.
I can only guess that the mirror was floppy from PO's taking the mirror off the clean the inside of the windshield. Then sloppily reinstalling the mirror bending the springs inside the stalk base.
Buy Once, Cry Once!
