Pogel Samba Member
Joined: November 21, 2005 Posts: 41 Location: Florida
Posted: Wed Nov 12, 2025 8:38 am Post subject: M Code 531 Upgraded suspension SO531 |
I have a 63 Kombi with some great extra options including 531, which I believe is an upgraded suspension. Is there anywhere which explains what the upgrade includes? Is it more than stiffer springs, like beefed up shocks? Thank you.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26330 Location: Olympia Wash Rinse & Repeat
Posted: Wed Nov 12, 2025 8:50 am Post subject: Re: M Code 531 Upgraded suspension SO531 |
| Pogel wrote: |
| I have a 63 Kombi with some great extra options including 531, which I believe is an upgraded suspension. Is there anywhere which explains what the upgrade includes? I'm guessing it would include beefed up shocks, but maybe there is more. Thank you. |
Above top right is the "Technical" button. Hover your mouse cursor over that, and a pop up list will pop up. In that list is "M-Codes", left click on that and on the next webpage scroll down to 531. _________________ In Stereo, Where Available! |
Pogel Samba Member
Posted: Wed Nov 12, 2025 8:54 am Post subject: Re: M Code 531 Upgraded suspension SO531 |
| Thanks |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71964 Location: Phoenix 602
Pogel Samba Member
Posted: Wed Nov 12, 2025 4:57 pm Post subject: Re: M Code 531 Upgraded suspension SO531 |
| Great information, I’ll see if I can get any marking off my shocks. |
von_hansel  Samba Member
Joined: June 12, 2006 Posts: 859 Location: Inland Empire
Posted: Thu Nov 13, 2025 9:36 am Post subject: Re: M Code 531 Upgraded suspension SO531 |
| EverettB wrote: |
There are heavy duty shocks but I think you would have M-Code 106 if those were used too:
Some pics:
Interesting that they changed the heavy duty shocks so late into production of the split window bus (Sept '66). I wonder what the reasoning was? Maybe it was cost savings measures, improvements, or due to supply change?
If you look at part number 47 found here it shows that M 140 specifies different torsion bars ( part number 211 511 113 A) than those standard on all other buses (excluding the ambulance model).
I wonder if m-code 531 includes both 106 and 140?
Also, in the m-code section of this site, it states Fire Engine as Specified by German DIN Specifications for M 140. VW was known for recycling m-codes.
Lind has tons of literature including specifically around m-codes. Maybe he can chime in about 531. _________________
| Mugatu wrote: |
| von_hansel is still so hot right now |
Lind Samba Member
Joined: November 06, 2000 Posts: 10278 Location: idaho
Posted: Fri Nov 14, 2025 6:49 pm Post subject: Re: M Code 531 Upgraded suspension SO531 |
Back in the '90s when I was first researching M-codes, before you could just look up a list on the internet, I had a notebook with a list of all the M-codes which I knew at that point. I forgot to bring it along when I want to a junkyard in LaGrande, Oregon, which was a few hours from home. There was a fairly stripped out split bus there that had M531. I couldn't remember the M-code off the top of my head, so I looked all over the bus to see if I could find something different. Seeing nothing out of the ordinary, I plucked whatever small items were left on the bus including the M-code plate. When I got home, I looked it up, and realized that it was heavier rear suspension, and the transmission was still in the bus, so it still had the torsion bars. I wasn't about to make a special trip for just them, so I figured I would just get them the next year when I went through the area. Of course when I went back it had been crushed. Years later, I got a '64 standard with that M-code, so I switched out the torsion bars before I sold the bus. The torsion bars are the same diameter as regular torsion bars. They are painted red, but I have seen others that were red which certainly didn't have that M-code.
I would think that the torsion bars would have a bigger diameter to be stiffer but those were the same diameter. The softer ambulance torsion bars are a smaller diameter. The torsion bars have the M-code of 140 in the parts list, but the parts list doesn't say what is different on them, just that they are for a firetruck. Maybe the M-531 is a grouping of M-140 and M-106. I looked in a few places and I wasn't able to find any other info on M531.
I have the torsion bars out of the M531 bus, and I have some NOS M-106 shocks, and I will put the package on one of my buses at some point that I am loading up with as many M-codes as I reasonably can just for fun. I should probably be able to get a couple dozen M options onto it. _________________ .
Wanted:
