Cannot Time My '65 Bug
PWS
PWS is offline
PostPosted: Fri Nov 21, 2025 5:11 pm    Post subject: Cannot Time My '65 Bug Reply with quote
I've timed my '65 Bug countless times, but this time my test light will never light, even through multiple revolutions (with the key ON, of course). Point gap has been set properly at .016". I have confirmed "juice" at the coil. The condenser checks out using John Muir's suggested procedure. The bulb of the timing light is good. Points are new. The car has set idle for about 4 years, and during that time period I redid all the wiring. But I don't see how that would contribute to my problem. John Muir does mention the possibility of a short in the distributor, but I don't know how to go about that possibility. I'm baffled and don't know how to proceed, aside from taking it all apart and reassembling.
Attaching photo below.
zerotofifty
zerotofifty is offline
PostPosted: Fri Nov 21, 2025 5:31 pm    Post subject: Re: Cannot Time My '65 Bug Reply with quote
ok how about confirming how your test light is connected? a photo will be helpful, also show spark coil connections one terminal of the coil gets the battery voltage from the key switch, and connected to this is also your electric choke and fuel cut of solenoid is so equiped. the other coil terminal get the wire to the distributor condenser, and nothing else, except the test light. other end of test light is grounded to engine case.
i do see a potential short inside your distributor, the wire from condenser has that conennector to the breaker points very close to the body of the distributor. bend it away, or sleave the connector with some heat shrink to be on safe side.
anyway let us see photos of coil and your connections to the test light
of course confirm test light works by putting power on it. assure your coil is getting power with the key switch on,.
wire diagram in color...
https://www.thesamba.com/vw/archives/info/wiring/Beetle_1962-65_Clymers.jpg
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
Big Bill
Big Bill is offline
PostPosted: Fri Nov 21, 2025 5:52 pm    Post subject: Re: Cannot Time My '65 Bug Reply with quote
zerotofifty thank you for the colored wiring diagram. Will be using it soon.
PWS
PWS is offline
PostPosted: Fri Nov 21, 2025 6:14 pm    Post subject: Re: Cannot Time My '65 Bug Reply with quote
Tomorrow I'll investigate that possible short. Here are my coil connections:
zerotofifty
PostPosted: Fri Nov 21, 2025 8:45 pm    Post subject: Re: Cannot Time My '65 Bug Reply with quote
OK, the coil appears wired ok, with the single green wire to the distributor. Clip on lead of your test lamp to the terminal on the coil, other end of the test lamp to the engine case for ground
Beware that the wire to the key switch is NOT fused. so if you create a short on that wire you can melt that wire, along with any wires that are adjacent to it in close contact. That melting can go all the back to the wire harness, melting a lot of wires together. So make sure you have no risk of shorting that wire (nor the electric choke wire)
Words to live by.
ashman40
ashman40 is offline
PostPosted: Sat Nov 22, 2025 1:25 am    Post subject: Re: Cannot Time My '65 Bug Reply with quote
In your pics it appears the green wire from the points turns into a black wire coming out from the distributor??
There is a green(?) wire at the left of the pic but it appears to be a much lighter green/blue color? This could all be lighting changes causing the wires to appear as a different color. Please confirm the points wire is the single green wire connected to the #1 (-) terminal on the ignition coil.
If the points wire is mistakenly connected to the #15 (+) terminal of the ignition coil it creates a direct short to ground when closed and will melt the #15 ignition wire..
The points are a simple ON/OFF contact switch. When the contacts are closed the green points wire is grounded. When the point contacts open the ground circuit is OPEN.
Disconnect the points wire at the ignition coil and place your test lamp between the end of the points wire and the #15 (+) terminal of the ignition coil. This will give the test lamp a power source and the points will be the switch for ground. Rotate the crank pulley until the points are CLOSED. Turn the ignition switch ON. The test lamp should turn ON as it now has 12v power and a path to ground. With a plastic spoon or wood stick, push the point arm to OPEN the contacts. The test lamp should turn OFF as the path to ground has been disrupted. If this doesn't happen it means the point wire is shorted to ground somewhere other than the point contacts. Check if the condenser is this path by disconnecting it from ground or disconnecting it from the points. Retest and see if now the points opening turned the lamp OFF. If not, you may need to replace the points or look for a short in the points wire.
AshMan40
Dougy Dee
Dougy Dee is offline
PostPosted: Sat Nov 22, 2025 6:58 am    Post subject: Re: Cannot Time My '65 Bug Reply with quote
Sat for 4 years???
You didn't mention it but, running a points file thru the points contacts to clean may help.
ppilotmike Premium Member
ppilotmike is offline
PostPosted: Sat Nov 22, 2025 9:01 am    Post subject: Re: Cannot Time My '65 Bug Reply with quote
does the test light work? The test light should be on with the points closed so the light can be tested to the distributor body any where when the points open they remove the ground and turn off the light which is what you look for to set the timing. Good luck I'm sure you will figure it out Very Happy
PWS
PWS is offline
PostPosted: Sat Nov 22, 2025 11:28 am    Post subject: Re: Cannot Time My '65 Bug Reply with quote
Reporting back, everything now working beautifully. Taking zerotofifty's advice, I slightly bent the end of the wire from the condenser away from the body of the distributor. I don't think it was touching, but it was awfully close. I then followed the procedure that ashman40 suggested in the last paragraph of his post, and the test light did exactly what it was supposed to. I also rechecked the condenser: points fully open, disconnect green wire at coil #1, connect test light leads to coil #1 and end connector of green wire, key ON, timing light remains off, indicating presumably a good condenser. Thanks for all your help and suggestions.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Nov 22, 2025 11:58 pm    Post subject: Re: Cannot Time My '65 Bug Reply with quote
If the wire from the distributor is black consider amending that as the power wire to the coil from the ignition switch should also be black which could cause confusion. I do see a green wire at the coil. Also it appears that your coil is reversed from original in its bracket.
Roads Scholar
Member# 2059
PWS
PWS is offline
PostPosted: Sun Nov 23, 2025 1:35 pm    Post subject: Re: Cannot Time My '65 Bug Reply with quote
The wire from coil #1 to distributor is uniformly green. Part of the wire does appear somewhat darker in the photo, but that's simply a lighting issue. I'm not sure what you mean about the coil appearing reversed from original in its bracket. My Bentley manual shows the coil mounted as I have positioned it. Are you suggesting that I need to rotate it somewhat? '65 Bug Sedan.
tasb
tasb is offline
PostPosted: Sun Nov 23, 2025 3:36 pm    Post subject: Re: Cannot Time My '65 Bug Reply with quote
Actually I am wrong. The #1 coil terminal is closer to the carburetor in 1965.
Roads Scholar
Member# 2059
