LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5659 Location: 1st Coast
Posted: Sat Nov 22, 2025 7:51 am Post subject: Small handheld belt sanders |
Anyone using the cordless or the wired models? I just realized this small handheld belt sander would come in handy for some of my metalworking projects so I can get into small areas. But if I buy a Milwaukee cordless to work with my batteries they cost over $250. If I get a corded model I can bring the cost down to under $50. which might be the better option. I do love the Milwaukee cordless model and as some here know I just love tools for all they do for mankind. I just need to justify yet another jem in my tool bag.
Some women carry handbags some carry toolbags. Mine is much more functional.
https://www.milwaukeetool.com/products/2482-20
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
| Lind wrote: |
| Have you considered simply starting with a nicer bus? I don't know what your skills are, but the race is easier if you can see the finish line. If you are not a runner, don't start off doing a marathon. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33565 Location: Hot Arizona
Posted: Sat Nov 22, 2025 8:44 am Post subject: Re: Small handheld belt sanders |
| LAGrunthaner wrote: |
| I just realized this small handheld belt sander would come in handy for some of my metalworking projects so I can get into small areas. But if I buy a Milwaukee cordless to work with my batteries they cost over $250. If I get a corded model I can bring the cost down to under $50. which might be the better option. I do love the Milwaukee cordless model and as some here know I just love tools for all they do for mankind. I just need to justify yet another jtem in my tool bag. |
I'm in a "similar" situation. I have a Milwaukee M18 cordless drill with 2 lithium batteries. I needed a Sawzall a few years ago, decided I wanted cordless, and broke down and purchased the Milwaukee tool to fit my batteries, and it was maybe $150.
I have a Harbor Freight corded impact wrench ($50) but think a cordless 1/2" impact wrench would be very handy, but Milwaukee ones are pricey. So I'm likely to get a "clone" impact wrench through Amazon that fits my Milwaukee M18 batteries. Maybe such exists for a cordless belt sander, or choose a no-name with good reviews. Or, if you use in the same location, a corded unit could suffice.
My circular saw, belt sander, hammer drill, weed whacker, pole chain saw, etc. are all corded. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
finster Samba Member
Joined: May 26, 2012 Posts: 10594 Location: not far from the madding crowd
Posted: Sat Nov 22, 2025 8:53 am Post subject: Re: Small handheld belt sanders |
I had a corded black & decker powerfile a couple of years ago. it was a useful tool for rust removal in narrow areas but using it as depicted above caused the sanding belt to wear a groove in the rubber drive roller. the result was it kept coming off and the rubber drive roller is not a spare part I could have searched for alternative rubber sleeves and bodged it but the whole thing was binned. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3174 Location: Vancouver Island, B.C.
zerotofifty Samba Member
Posted: Sat Nov 22, 2025 11:02 am Post subject: Re: Small handheld belt sanders |
Battery tools have one big problem besides running out of juice when you need them, and that is the batteries eventually fail, and as is oft the case the battery pack is no longer produced, or maybe you can get an inferior battery pack from an aftermarket brand. I have several battery powered tools with failed batteries that are out of production. If after market are available they are often well over half the cost of a brand new battery and tool. many aftermarket packs are inferior, with lower battery capacity than factory stock packs.
battery packs age out and die, if you dont use the tool a whole lot, the tool will still be in great condition and the battery pack(s) will be dead, or maybe the battery pack will only be able to be able to take a partial charge, they oft suffer a slow death with degrading performance they will die even if never used, they age out. if you run them to full discharge, that shortens their life span
if your need for the tool is near a source of AC power, then go that route, corded. That is my advice.
for me, a belt sander will be used fairly infrequently, I am a hobbiest, it wont be used daily, and will be always be used where I have a source of AC power. thus for me the corded one is my choice.
For me a corldess hand drill is nice, I will be buying a new one as my battery pack for it is dead and after market packs are low capacity and pricey I also have corded hand drills. say I want to drive a screw or drill a hole on my backyard fence, the cordless is nice, no long cords to layout, but in my garage corded is fine.
but for sander, I will not go cordless. usually the need for a belt sander is with a welding project, and I assume it is arc welding, thus you have AC power for the welder anyway, so go with a cord sander.
If you is doing gas welding projects out in the field with no AC power, then a cordless sander makes sense. Otherwise too many disadvantages to cordless
That is my thought, worth every penny you paid for it.  _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 3067 Location: HdG, MD & NJ
Posted: Sat Nov 22, 2025 1:35 pm Post subject: Re: Small handheld belt sanders |
I’ve only used one of those the was pneumatic and it was handy. I would like a cordless one. Think ahead and keep all your cordless tools the same brand, so batteries interchange. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
viiking Samba Member
Joined: May 10, 2013 Posts: 3471 Location: Sydney Australia
Posted: Sat Nov 22, 2025 2:31 pm Post subject: Re: Small handheld belt sanders |
I have a few cordless power tools and use them constantly.
However I have found that grinders need to be corded if they are used extensively when doing body work. Regardless of the claims the battery ones in my opinion are just weak.
Regarding the belt sander, I found that it became the most invaluable tool I have for grinding down welds. I seem to have much better control of that tool than the grinder to do so. I used to use a thin cut-off wheel on edge to cut down the welds, but now find the belt sander much easier especially if you get the "valley" in the weld before you can dolly it back up.
Given I have had to do a lot of welding on my projects, I look for a cheap corded belt sander and replace it as it fails. Reason? The dust and garbage that I seem to attract around the car finds its way into the workings and I really don't want to subject my expensive tools to that environment. I can buy 3 or 4 cheap ones for the price of an expensive battery one and so far that has worked for me. The same for grinders. I keep my good one(s) for less dusty jobs and buy cheap grinders, one or two for say 40 and 80 grit size, one for cut off wheels, one or two for wire wheels. It saves the endless stopping and changing the bits every time I do a metal repair.
Whatever you buy see if you can buy a belt sander that shares its belt size with that of a normal wide belt timber belt sander. In my neck of the woods the small 1" or so wide belt sander belts are quite expensive. I buy the wide belts and then cut each wide belt into 5 or 6 narrow belts. It is quite easy to make a small scissor cut and tear the material backed belts into a perfect narrow belt. Just be careful that when you tear towards the diagonal (usually) belt join that it tears through their correctly. Sometimes you have to give that transition point a little cut. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
babysnakes Samba Member
Posted: Sun Nov 23, 2025 6:50 am Post subject: Re: Small handheld belt sanders |
| I have a Makita corded one. Very handy. |
Posted: Sun Nov 23, 2025 6:51 am Post subject: Re: Small handheld belt sanders |
Yes agree batteries don't last and replacement may not be available in the future. Also love the idea of hand cutting a large belt to make many.
I like the idea of if the outlet is nearby use corded. I guess I just wish they could bring the wireless prices down.
I have seen pneumatic models for $25. but dragging a tank to the back yard if I had some yard work or shed work down the road is a huge PITA.
https://www.amazon.com/HYFN-Pneumatic-Powered-1-5H...mp;sr=8-18 _________________ American Red Cross Safe And Well:
Maui Roadsters
| Lind wrote: |
Cusser Samba Member
Posted: Sun Nov 23, 2025 7:35 am Post subject: Re: Small handheld belt sanders |
My belt sander - not used very often, and I don't do auto bodywork - is a small unit from Harbor Freight, 120 VAC. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
