What is this rubber bushing from my '70 Beetle steering column?
timdhawk
timdhawk is offline
PostPosted: Fri Nov 28, 2025 3:39 pm    Post subject: What is this rubber bushing from my '70 Beetle steering column? Reply with quote
Trying to diagnose a wonky horn problem, and noticed this rubber bushing was ... well, looked like this, inside the steering column tube. It clearly goes between the shaft and the tube and is NOT part of the roller bearing, and it doesn't look any of the pictures of anti-rattle bushings that I've found on-line.
What is it? Is it an OG anti rattle bushing? If so, are the new ones made of hard plastic?
thanx
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Fri Nov 28, 2025 11:03 pm    Post subject: Re: What is this rubber bushing from my '70 Beetle steering column? Reply with quote
This?
https://www.bughaus.com/steering_column_bushing_-_111-535D.htm
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
PostPosted: Fri Nov 28, 2025 11:16 pm    Post subject: Re: What is this rubber bushing from my '70 Beetle steering column? Reply with quote
You don't mention the nature of this wonkiness, but if it has to do with an intermittent or stuttering horn, check/clean the ground connection at the steering coupler. I spent a lot of time chasing horn gremlins on my '69 and the main problem ended up being a poor ground connection at the coupler.
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
timdhawk
timdhawk is offline
PostPosted: Sat Nov 29, 2025 8:02 am    Post subject: Re: What is this rubber bushing from my '70 Beetle steering column? Reply with quote
OldSchoolVW's wrote:
This?
Those are what I'm seeing in various places, but to my eyes do not look even close to the diameters and makeup of the one from my column.
You don't mention the nature of this wonkiness ...
Thank you, I have another post started about my horn woes, I don't think its the bushing ground. : https://www.thesamba.com/vw/forum/viewtopic.php?t=807854
