questions about #2 & #4 lower rear air deflectors
volkaholic1
volkaholic1 is offline
PostPosted: Sat Dec 27, 2025 11:13 am    Post subject: questions about #2 & #4 lower rear air deflectors Reply with quote
just trying to find out what years the uncommon versions are from
in the pic, the center is what i call the "typical" #4 and #2 lower rear air deflectors.
the #4 in the upper left has a hole in it, i know that is for running the small paper hose up to the air cleaner, but what years did it come on?
the #2 in the lower right is a mirror image of the #4, what years did that come on?
i can buy the typical parts from VW mexico, but does anyone make the others new?
Volkaholic
rugblaster
rugblaster is offline
PostPosted: Sat Dec 27, 2025 2:06 pm    Post subject: Re: questions about #2 & #4 lower rear air deflectors Reply with quote
I'm going to say the number 4, left is off of a '67.....'67's had a twin snorkle on the air cleaner.......I you want one with a hole in it, just put a hole in it.
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
volkaholic1
PostPosted: Sat Dec 27, 2025 3:56 pm    Post subject: Re: questions about #2 & #4 lower rear air deflectors Reply with quote
so that is a 1 year only part, good to know
Volkaholic
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sun Dec 28, 2025 6:27 am    Post subject: Re: questions about #2 & #4 lower rear air deflectors Reply with quote
I think the 68 air cleaner also used that one on the left side.i will look at a 68 air cleaner today and correct my post if I am wrong.
diablosandwich
diablosandwich is offline
PostPosted: Sun Dec 28, 2025 7:21 am    Post subject: Re: questions about #2 & #4 lower rear air deflectors Reply with quote
The #4 with hole for left side was on 40hp and 1300 too. I am not sure if it was only on fresh air 40hp or not though.
Casey
2 1966 Java Greens and a 65 Sea Blue that is green
john7
john7 is offline
PostPosted: Sat Jan 03, 2026 9:20 am    Post subject: Re: questions about #2 & #4 lower rear air deflectors Reply with quote
Top left is 65-67
The one you don’t have is the right side 67 only version with the hole
Jesus Saves
Slot Mag King!
I accept Paypal, CASH, GOLD, SILVER, COINS, GUNS & money orders.
volkaholic1
PostPosted: Sat Jan 03, 2026 9:41 am    Post subject: Re: questions about #2 & #4 lower rear air deflectors Reply with quote
i am starting to wonder if the lower right is VW Mexico or VW Brazil
Volkaholic
Teeroy Premium Member
Teeroy is offline
PostPosted: Sat Jan 03, 2026 12:17 pm    Post subject: Re: questions about #2 & #4 lower rear air deflectors Reply with quote
I think upper left and lower right are off 1500 bus. 67 beetle also would use upper left, 40hp looks similar but would be shorter end to end. I put lower right style on my dual carb engines without preheat to even the airflow
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
