jcerier Samba Member
Posted: Wed Jan 07, 2026 3:23 pm Post subject: Factory installed gas heater |
My all stock 1970 Ghia has what appears to me to be a factory-installed gas heater. The components have VW part numbers on them, and are all installed above the transaxle in a way that I highly doubt a dealer could have done. The wiring also all looks stock. Interesting that when I Google this I can't find anything about it. This also explains the mystery dash light that I had previously posted about. See pictures.
I am in the process of removing this, as I am converting to electric propulsion and want to get anything gas-related out of the car (and reduce remove any unnecessary weight). (If you feel the need to comment on the EV conversion please go to this thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=808016&highlight=ev)
I have everything out except one component and another bracket. They are bolted through the sheet metal above the transaxle. I was going to remove the carpet in the storage compartment behind the rear seat to get at the three bolts, but as I started doing that I noticed these three plastic/rubber plugs in the carpet at the locations of the three bolts. I tried prying them out, but they seem very well glued to the carpet. Again, they look very factory, not dealer-installed.
Posting for two reasons:
1. To document what I have here for future reference, and see if anyone knows anything about factory-installed gas heaters.
2. To get thoughts on whether I should pull the carpet out, or yank those plugs out of the carpet, to get to the bolts. I might have to take the carpet out anyway to mount my rear battery box in there anyway, so it might be a moot point. But I am curious to hear people's thoughts. |
Posted: Thu Jan 08, 2026 4:40 am Post subject: Re: Factory installed gas heater |
I'll add that my car was originally delivered in Canada.
Has anyone ever heard of a heater like this in a Ghia or Beetle? |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4239 Location: Georgia
Posted: Thu Jan 08, 2026 7:18 am Post subject: Re: Factory installed gas heater |
I’ve never seen nor heard of such an animal until now.
To me those carpet grommets look like they have a center cap that pops out but not seeing it up close and personal it’s just a guess. _________________ Volkswagen!
(Compression 8.7:1) |
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 1044 Location: France
Posted: Thu Jan 08, 2026 1:31 pm Post subject: Re: Factory installed gas heater |
So that is a Webasto and not a Eberspacher heater that vw usually fit. You can tell it is Webasto from 3 things , 1 it is red in colour first tell tail sign, 2 it's manufacturing plate has only 2 central rivets holding it in place, and 3 the fuel line bango type connector.
Similar models were mainly fitted to 1960's Porsche 911's and 912's s possibly as they take up less room than similar eberspacher ones, but are probably more expensive back then so used only when space was limited on VW's and a high end model which the Karman was sold as..
On the Porsche 911 and 912 the webasto appears to have had porsche factory part numbers...
Just like your webasto in the Karmann having VW part numbers...
It looks totally factory and similar to the porsche one apart from the hose connectors points even though the small and large hose is on also on the 911 and 912.
On the porsche it sits in a purpose built flush hole in the front trunk |
Posted: Thu Jan 08, 2026 3:34 pm Post subject: Re: Factory installed gas heater |
@Nitramrebrab72 for the win! Thanks so much. I knew that someone somewhere in Samba-land would know something about this. Odd that I can't find any reference to it as a factory option anywhere.
Got the rest of it out today. More pics for the record. Found an electrical box under the rear seat that the spark plug and other electrical connections ran to.
Anyone know of a web site where you can look up obsolete VW part numbers? |
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3913 Location: Eastern WA
Posted: Thu Jan 08, 2026 11:17 pm Post subject: Re: Factory installed gas heater |
You could order a birth certificate and see what M codes it came with. Possibly look for some Canadian sale brochures and see if it a listed option. I would not rule out dealer install, they could be done as cleanly as factory. Main reason I wouldn't rule it out is the part numbers, all of the one you show start with 111, Beetle part number, Ghia parts start with 141. Not a definite answer, but something to consider. Really not much issue for you since you don't plan on using it . _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Fri Jan 09, 2026 12:51 am Post subject: Re: Factory installed gas heater |
| Teeroy wrote: |
| I would not rule out dealer install, they could be done as cleanly as factory. Main reason I wouldn't rule it out is the part numbers, all of the one you show start with 111, Beetle part number, Ghia parts start with 141. |
Both above statements seem misleading, never seen a dealer fit anything with that much attention to detail and finesse.
111 part #'s are not unique to Beetles. 111 is the VW internal model number of the LHD Beetle standard hardtop and often integrated into the part#, they cover at least Beetles, Type 3's, Type 147's, Type 181's Type 2's , T 25/T3 , MK 1 Golf and Karmann Ghias.
141 is the internal VW model number for the LHD Karmann Ghia convertable and often integrated into the part # if it's design is primordial to the Karmann.
If the part was primordial to the Type 111 Beetle then it would start with 111, and if it is also used on a Mk1 golf it will also start with 111 as it is a Beetle LHD hardtop standard designed part being used in a MK 1 Golf .
There would be something that would shine some light on it that would be if the paper part# ticket of the cable in the rear started with 141,142,143 or 144.
It would be nice to restore the heater as what appears to be an original factory fitted heater. |
rsbadura Samba Member
Joined: November 30, 2009 Posts: 778 Location: Berlin, Germany
Posted: Fri Jan 09, 2026 4:14 am Post subject: Re: Werkseitig installierte Gasheizung |
Webasto is a well know brand in Germany
(founded 1901, 1908 renamed to WeBaSto because of the founder Wilhelm Baier Senior and the location Stockdorf)
It had also supplied a lot for VW parts (sunroofs, auxiliary heaters, etc.).
But I never seen this heater... it's quite rare!
Something that you could also post here: https://www.thesamba.com/vw/forum/viewtopic.php?t=65121 "Rarest accessory?".
Some of the 111 order numbers appear to be for standard parts such as standard exhaust brackets.
The location for this auxiliary heater isn't ideal either – it's near the engine's waste heat, further heating very hot air from the engine while hanging unprotected under the car. The concept doesn't seem particularly durable or reliable. Many other auxiliary heaters were placed in the protected trunk and only heated cold air.
regards, _________________ Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools collection |
GHIA Samba Member
Marlonius Samba Member
Joined: October 06, 2004 Posts: 400 Location: Edmonton, Alberta
Posted: Fri Jan 09, 2026 1:16 pm Post subject: Re: Factory installed gas heater |
| Fellow Canadian here. Yes, I've seen a few installations like that over the years, including on my '69 parts car. I think I still have a number of the components around. |
Posted: Fri Jan 09, 2026 1:23 pm Post subject: Re: Factory installed gas heater |
I found a pic from my stash... |
Posted: Sat Jan 10, 2026 7:27 am Post subject: Re: Factory installed gas heater |
That is quite an intriguing heater. It is a heat amplifier as opposed to a stand alone heater.
As it uses the already heated air from the heat exchangers and increases it's temperature by blowing it around a cylinder which has fuel burning inside of it.
It has no fan of it's own to propulse air through it so solely relies on the engine cooling fan shroud take offs that send air first through the exhaust heat exchangers and then through the unit.
Fuel is pumped to the unit by the engines fuel pump via a t-connector. Fuel is sucked into the system using a vacuum air pump a bit like a carburetor and the mixture is determined by a diaphragm regulator.
The air/fuel mixture is then pumped into the heat exchanger part of the unit where it is ignited by a spark plug that is induced by an electronically controlled coil.
Prufrex are the inventors of the electronically controlled coils that we find on todays modern cars.
I guess the Prufrex is the brains of the system as well as a coil , determining when to start the air pump(regulating the speed of it based on the temperature readings it is being sent by the heat sensors in the unit, increasing the speed when it is cooler, decreasing when hotter )when to shut it down and when to send sparks to the spark plug. It also has a too high temp. cut off switch by the looks of things.
Due to the fact it is a heat amplifier it has no temperature setting, so just an on off switch. |
Posted: Sat Jan 10, 2026 7:38 am Post subject: Re: Factory installed gas heater |
| I am not 100% certain if the Prufrex regulators the unit by controlling the speed of the pump or by switching it on and off solely based on the temperature sensor feed back or both combined... |
smuenchrath Samba Member
Joined: February 20, 2005 Posts: 379 Location: Calgary, Alberta
Posted: Thu Jan 15, 2026 4:23 pm Post subject: Re: Factory installed gas heater |
They seem to be a fairly common installation on 68-69 Canadian Beetles and Ghias. I have come across a couple over the years. _________________ 69 Ghia Toga White Coupe
74 Yosemite Yellow Westfalia |
Posted: Fri Jan 16, 2026 12:30 am Post subject: Re: Factory installed gas heater |
| smuenchrath wrote: |
| They seem to be a fairly common installation on 68-69 Canadian Beetles and Ghias. I have come across a couple over the years. |
They are really cool, a quirky design from the past, as it is a heat amplifier as opposed to the stand alone self efficient heaters with their own blower...
There is just an on-offswitch, no adjustable thermostat, no fan speed setting, it just amplifies / increases the temperature of the already warmed air coming from the heat exchangers... Adjusting the temperature is done by simply using the original VW Temp lever on the dash that reduces the air coming from the heating exchanger and the webasto follows suit.... |
