Brake line restoration
Alan Brase
Alan Brase is offline
PostPosted: Sun Sep 05, 2004 11:06 pm    Post subject: Brake line restoration Reply with quote
How do you rusty bus restorers put the German type flare on new steel brake lines? I regularly buy the tubing in rolls and can get new flare nuts, but I've yet to find the exact tool available for sale. (I've been getting by with a Weatherhead double flare tool for American type flares and then stopping after the first operation,, but they are not very consistant. ) not dangerous, but I'd like to find a better way. I really prefer to snake in the long pipe from a roll rather that making it out of 2 or 3 pieces.
Good brake lines are pretty much a necessity with a single master cylinder system!
Al
69 double cab, 56 pickup
dstefun
dstefun is offline
PostPosted: Mon Sep 06, 2004 12:09 am    Post subject: Reply with quote
Snap-on lists 2 different sets, depending on whether it's a bubble flare or not --- don't know for sure. Hazetguy probably knows - send him a PM. What's your source for metric brake tubing on a roll? They should have something.
Bubble flare tool, metric, $105
http://buy1.snapon.com/catalog/pro_det.asp?P65=&to...ir=catalog
Double flare tool, metric, $45
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus
Alan Brase
PostPosted: Mon Sep 06, 2004 12:23 am    Post subject: Reply with quote
Actually, my Weatherhead tool looks exactly like the double flare tool. I've just been using 3/16 tubing. It seemed to be the same size as what was there, and has worked okay so far. Who supplies metric sizes?
Al
hazetguy
hazetguy is offline
PostPosted: Mon Sep 06, 2004 8:12 am    Post subject: Reply with quote
hazet makes a flaring kit, if you want to spend serious dollars. Smile
ronnie in havasu used to sell (may still) pre-made "kits" with all the lines and flares on them already. obviously the lines are not pre-bent.
ask him (splitpile).
BryanM
BryanM is offline
PostPosted: Mon Sep 06, 2004 11:19 am    Post subject: Reply with quote
Am I just ignorant or are you guys making this difficult?
I order the lines in the front drum and the one from the rear T fitting to the left rear flex line from WW and then buy the rest of the steel lines from NAPA.
-Bryan
Motorwagen LLC
Concord NC
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
swervyjoe
swervyjoe is offline
PostPosted: Mon Sep 06, 2004 11:49 am    Post subject: Reply with quote
WolfsburgWest has kits with all the metal lines for like 50 bucks. there not bent, but its not hard to do. the lines are cut to lenght and flared.
ratpanel61
ratpanel61 is offline
PostPosted: Mon Sep 06, 2004 11:54 am    Post subject: Reply with quote
I've gotten the whole kit from WW a couple of times, and it's always worked great for me. Even with shipping it's always less than the frustration of trying to biuld my own.
- '57 Sunroof Beetle (project)
- '73 THING
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Mon Sep 06, 2004 4:56 pm    Post subject: Reply with quote
Double flare tools are fairly common.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40878
Why buy what you can build.
UZI
Platinum FUBU
UZI is offline
PostPosted: Mon Sep 06, 2004 5:08 pm    Post subject: Reply with quote
i buy the WW kits too. why suffer?
Extravagant Lifestyle
Clara Premium Member
Clara is offline
PostPosted: Mon Sep 06, 2004 5:14 pm    Post subject: Reply with quote
if I feel like a vintage pervert I buy NOS brake lines.
If I dont, I go to the local brake shop and have them make the lines. I have to tell them how long to make the lines, also they end up with 12mm nuts instead of 11 mm, doesn't take long.
either way they are straight and then you have to bend them.
Alan Brase
PostPosted: Tue Sep 07, 2004 9:05 am    Post subject: Reply with quote
I've got the double flare tool, just looking for the bubble flare tool.
I've never considered just buying the lines pre made. Maybe back when I started there were NOT places like WW supplying exact length parts, but rather the only thing available were the generic parts store ones made in 10 inch steps. So sometimes I had to put a small loop in them to use up the extra. I've got a lot of practice on American cars making new lines.
Al
debunked
debunked is offline
PostPosted: Tue Sep 07, 2004 1:38 pm    Post subject: Reply with quote
question for you experienced guys:
I replaced the master cylinder, all four flex lines, and both rear wheel cylinders yet it still has sticky rear brakes. The front brakes seem to loosen back up but the rear stay somewhat rubbing unless I bleed out some fluid.
I can drive it down the road and use the brakes a few times and I am back to the rear brakes holding up again.
The return spring on the pedal seems solid and fine, but when you do a quick push and remove your foot it takes a little bit of time for it to return to full upward position.
Do you think the master cylinder could be faulty or should I be looking at replacing the lines you are talking about on this thread?
Thanks..........
View user's profile Send private message MSN Messenger Classifieds Feedback
swervyjoe
PostPosted: Tue Sep 07, 2004 2:03 pm    Post subject: Reply with quote
you might check the "t" conection in the back. (where the two rear sides split) it may be cloged. i wouldn't think the master is at fault. its a single cylinder so the front would be acting up also.
Lind
Lind is offline
PostPosted: Tue Sep 07, 2004 3:17 pm    Post subject: Reply with quote
Thanks..........
make sure that the rod going into the master cylinder has some free play. otherwise, it can hold pressure.
Flipseat
Flipseat is offline
PostPosted: Tue Sep 07, 2004 4:39 pm    Post subject: Reply with quote
Mastercool makes a *very* nice line flaring set that does everything... double flare, bubble flare, quick disconnect, and even GM fuel line flaring. Its hydraulic, not manual and at ~$400 it will set you back some, but you'll love it. Its one of my favorite tools. They also sell kits for less with just double/bubble flares too I believe.
Insert random important looking club initials here.
ToolBox
ToolBox is offline
PostPosted: Tue Sep 07, 2004 7:43 pm    Post subject: Reply with quote
I had a Mastercool 71475 in the prototype brake fab shop and it was a sweet tool. They do have other less complex tools that won't brake the bank and get the job done.
debunked
debunked is offline
PostPosted: Tue Sep 07, 2004 9:43 pm    Post subject: Reply with quote
Sounds like a good spot to check. I do get pressure when bleeding the brakes that seems to be just fine. but something holds it back like as if it had bad flex tubes but those are brand new.
I will try the t connector.
Thanks
Clara is offline
PostPosted: Wed Sep 08, 2004 9:08 am    Post subject: Reply with quote
is your pedal pivot sticky? This can make the pedal stay down even if the spring is good... it should spring back up immediately when you dont push the pedal down, and if it doesn't, something is wrong up front.
so remove the pedal (13mm nut/bolt under bus, and remove that pivot, which involves a larger nut/bolt, and probably tapping with a drift..., it can be sticky) clean off the pivoting thing, apply fresh grease, and reinstall. the earlier buses have zerks to lube the brake and clutch pivots, why did they stop that?
if the pedal doesn't pop up, the brakes will of course, stay on partway, which wears things out. you can do the clutch pivot too. and grease all the moving parts under the bus there... ebrake linkage etc.
grease is your bus' friend. have you greased yr bus today?
Thanks..........
