dizzy advice for 1176
surfindo
surfindo is offline
PostPosted: Fri Nov 05, 2004 9:26 am    Post subject: dizzy advice for 1176 Reply with quote
OK this my "BUS" engine 1776 with double Dells DRLA 36, it has worn-out brazilian bosch 009 dist. so I need to get the new dist.
the choices are bosch 034 used in good condition (cheap) , used 010 in good condition, and brand new Mallory HD with single point, after search the forum and my eyes get tired from the screen,seems the vaccum advance is the choice but before I decide I need input which one is best for my engine, the engine just fresh rebuild with new 69 crank,90,5 cyl, and new heads and cam.
I cant wait to drive but first I have to chose the dist.
Thanks.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Nov 05, 2004 10:16 am    Post subject: Reply with quote
If you already have the 034 and 010, i'd try them both and see which one you like better.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
surfindo
surfindo is offline
PostPosted: Fri Nov 05, 2004 5:19 pm    Post subject: Reply with quote
No I dont have them yet!! but friend of mine have 034 and 010 for sale and other guy want to sell his brand new mallory single point , at this moment I have only the worn out Brazilian 009 so before I buy them I need opinion, Hi Glenn I ve been check ur site and you have those rebuild 010 for sale but my engine is in Indonesia, Rolling Eyes
THANKS
stevemariott
stevemariott is offline
PostPosted: Fri Nov 05, 2004 11:46 pm    Post subject: Reply with quote
I have a 1776 with 36DRLAs in my bus. I had a mildly tweaked 009 in it for awhile, and it wasn't terrible like you would imagine but it wasn't fabulous either. I picked up a good 034 at the swaps so I cleaned it up and installed it. There was a noticable drivability improvement with the 034, it just seems a bit smoother all around. I can't say much about MPG figures, my around town MPG seems about the same and I haven't been on a real long distance freeway trip since I've installed it to see how it might fare there. I expect it would be at least a little better. You might as well try to take advantage of the vacuum advance, especially in a heavy bus.
I don't have an 010 so I can't comment on it.
I also have an 019 sitting around, but I never have picked up the required parts to finish it (rotor, cap, points - two piece?). I also have a non-vacuum Unilite I bought secondhand, and I even bought the grey/grey springs for it, and... the module doesn't work Crying or Very sad
1963 Manx copy
1968 Bus
