harryset Samba Member
Joined: July 14, 2005 Posts: 690 Location: Bemidji, MN
Posted: Mon Jul 18, 2005 5:51 am Post subject: |
Thanks for the great answers. I didn't have time to do any serious work on it yesterday due to family maintenance day. I did go out and rip out some of the carpeting along the wheel housing and front heater channels, just to see what might be hiding there, and it looks very encouraging. All of the metal I see, so far is clean and strong. |
Pennywise Samba Member
Joined: January 19, 2004 Posts: 396 Location: Ellicott City, MD
Posted: Sat Jul 16, 2005 8:48 pm Post subject: |
Good luck, and I hope the rust is only where you see it now. |
Posted: Sat Jul 16, 2005 6:27 pm Post subject: |
we'll be ripping carpets and breaking out the wire-wheel tomorrow. |
Posted: Sat Jul 16, 2005 5:11 pm Post subject: |
Sounds like where the heater channel meets the wheel well? If that is the case, you might have a deeper rooted problem than just what you can see. To be rid of the rust completely you will have to investigate more to see where it ends and remove all the rust. All the way back to good metal. |
Jowlz The Anti-Purist
Joined: May 02, 2005 Posts: 2464 Location: Tunkhannock, PA
Posted: Sat Jul 16, 2005 4:20 pm Post subject: |
Thats not the worst place to have rust. I say this because the fix is pretty easy if I am reading you right on where it is. You can cut the old rusty metal out and put in sheet metal. No need for panels. It is a good flat area. Another bonus is its not an area that you can see easily with the body on..Also alot of people run undercoating down there. It will hide and welding seams. _________________ The honey-do list put my project on hold....... |
Posted: Sat Jul 16, 2005 1:34 pm Post subject: Advice on body rust. |
I just removed the fenders on my 72 beetle, engine removed, wheeled her outside and pressure washed her pretty good. Although it shows some signs of some loose paint, very little rust or pitting except for two spots. On both the RF and LF wheel wheel, behind the tire down at the very bottom, on both sides there is a fairly large hole rusted through, but I don't know what piece this is affecting and what the correct repair procedures might be. Any suggestions? I'm only guessing that these might be the very front of the heater channels. This is rusted through from the outside of the wheelwell into the channel. |
