brake light comes on randomly
Todd Wilson
Todd Wilson is offline
PostPosted: Fri Sep 02, 2005 10:26 pm    Post subject: Possible Solution to lighting problem Reply with quote
Most aftermarket master cyclinders have and adjustment for the pistion I was working on my rail tonight and it just dawned on me I had forgotten about the piston adjustment screw in the back of the master cyclinder. If you remove the brake light switch and turn the adjustment screw clock wise this should reduce some of the pressure on the brakelight switch and allow for normal braking. After I had made this adjustment the lights work perfectly as did the brakes. Hope this helps Laughing
DrDarby
DrDarby is offline
PostPosted: Thu Sep 01, 2005 10:44 am    Post subject: Reply with quote
What about the handbrake warning light ? The switch is under the hand brake lever.
Midwest Autosavers, Inc. Crystal Lake, IL
Todd Wilson
PostPosted: Wed Aug 31, 2005 9:58 pm    Post subject: Troublesome Brake Switch. Reply with quote
This sounds like a similar poblem I am having with a rail, I am using disc brakes on the rear only and just changed out the master cyclinder. But my brake lights are staying on all the time after I hit the brakes one time. I am guessing that I am building too much presure in the lines and there is no where for it to go. As I said this is a new master cyclinder that was designed to use the 2 wire brake light switch. This may be what could be causing your problem as well. I have let just a little air in the line to test my theory and the brake light switch now works properly most of the time however, I do not recomment you let air into the system as this could cause a lockup or worse the could cause the cyclinder to bottom out and loose all braking. The other solution I can think of is to move the switch to the "T" at the back of the car since the bias would be less there that could also solve the problem. :shock:
Miguel Arroyo
Miguel Arroyo is offline
PostPosted: Sun Aug 07, 2005 5:37 am    Post subject: Reply with quote
Have you verified the electrical connections are cleaned. Is there air entraped?
drrnsk8ter4
drrnsk8ter4 is offline
PostPosted: Sun Aug 07, 2005 12:31 am    Post subject: brake light comes on randomly Reply with quote
i have a 74 std with a newly installed master cylinder that has a solid brake pedal but usually when i start my car the brake light comes on and then as i drive along (brakes work great) the light eventually just turns off...what would be the cause of this???
(O\U|U/O)--->74 std bug...
