scottydub Samba Member
Posted: Wed Feb 07, 2024 1:41 pm Post subject: Re: Re-Key or Replace ignition housing? |
Excellent! Thanks |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25934 Location: Olympia Wash Rinse & Repeat
Posted: Tue Feb 06, 2024 9:12 pm Post subject: Re: Re-Key or Replace ignition housing? |
scottydub wrote: |
Great! Where can I find the code? Is it on the ignition |
_________________ In Stereo, Where Available! |
Posted: Tue Feb 06, 2024 7:19 pm Post subject: Re: Re-Key or Replace ignition housing? |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15228 Location: Casa de Oro, California
Posted: Tue Feb 06, 2024 7:04 pm Post subject: Re: Re-Key or Replace ignition housing? |
This guy will make and mail it to you.
https://gabvwkey.com |
Posted: Tue Feb 06, 2024 3:13 pm Post subject: Re: Re-Key or Replace ignition housing? |
scottydub wrote: |
Is it possible to make a key with a key code from the ignition? |
A proper old fashioned lock shop should be able to cut such for you. That is why the key code is there. _________________ In Stereo, Where Available! |
Posted: Tue Feb 06, 2024 12:47 pm Post subject: Re: Re-Key or Replace ignition housing? |
Yalmar Samba Member
Posted: Wed Jul 08, 2009 1:43 pm Post subject: |
huuuh - mine is stuck. Does someone have any photos showing the inside.
Do I have to un-screw the hole steering-shaft - and "enter from above"...  |
Clara  Samba Member
Posted: Tue Jul 07, 2009 9:27 pm Post subject: |
rebapuck wrote: |
The problem is it's a generic switch from BusBoys. But where could I get a VW one? |
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
To have the one key system you need to buy the ignition switch with the correct key profile for your bus.
67 only is L (like 20L123),
64-66 is T profile (like T1234),
55-63 is the kind that have number letter number like 4Z1
55-60 are screw terminal, 61 & later are push terminal.
They are physically interchangable and fit 55-67, like the new ones, but the above are particulars to keep in mind if you want a one key system, and don't want to mess original wireing up.
The key code is here:
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Tue Jul 07, 2009 7:41 pm Post subject: |
CaliforniaShagWagon wrote: |
The Story is long and embarassing but the end of it leaves me Keyless to my 64' Bus. The Doors and ignittion keys were not matching. A rekey is quoted at 200 bucks, a new ignition switch is 30. How hard is it to change out the ignition switch?
Shaka,
Adam |
A rekey should not be that expensive. Talk to this guy. You should be able to just send him all of your handles and ignition switch and he'll cut you a set of VW keys and key them all the same for less than $200.
http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=7058
rebapuck wrote: |
I recently replaced my ignition( by myself!!) and it came with 2 keys. I'm kind of paranoid and like to have more than enough keys. The two biggest locksmiths (and 3 smaller) in the area could not find a key blank to match. Am I stuck? Or could the vw key guy come up with one? The problem is it's a generic switch from BusBoys. But where could I get a VW one? |
You're not going to be able to get a VW key for a generic switch. You'll have to replace that generic switch with a VW ignition switch. Talk to the same that I just told the guy above to talk to and he should be able to set you up with an ignition switch and a set of keys and be able to key it to the rest of your VW. _________________ -Andrew |
WM971252 Samba Member
Joined: September 10, 2004 Posts: 1783 Location: Franklin CT
Posted: Tue Jul 07, 2009 10:47 am Post subject: |
rebapuck wrote: |
Yep the "replacement" switch (available for Bugs too) are some weird key profile that I have not heard of any blanks around (but still trying...). |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71524 Location: Phoenix 602
Posted: Mon Jul 06, 2009 11:18 pm Post subject: |
Yalmar wrote: |
thom wrote: |
Yalmar wrote: |
Going to change my ingnition switch - removed the "electrical cabel-plate" on the other side... BUT it seems that the switch is locked by a "pin "(?) - not a screw - from underneath. On the attached picture - you'll see hole where the "pin" enters,..... http://www.justkampers.com/shop/type_2_split/vw-ca...14354.html |
That's a threaded hole - just a crappy picture. |
So its a screw then - not a bolt...... ? just have to find the corect screwdriver then.... |
Originally it was a flat-head screw but yes, it removes quite easily. One of the wires is live so you should disconnect the battery first. _________________ How to Post Photos
rebapuck Samba Member
Joined: May 17, 2007 Posts: 1023 Location: Chapel Hill NC
Posted: Mon Jul 06, 2009 8:50 pm Post subject: |
I recently replaced my ignition( by myself!!) and it came with 2 keys. I'm kind of paranoid and like to have more than enough keys. The two biggest locksmiths (and 3 smaller) in the area could not find a key blank to match. Am I stuck? Or could the vw key guy come up with one? The problem is it's a generic switch from BusBoys. But where could I get a VW one? _________________ Judy
1966 Camper "Hannah"
1967 SingleCab "Khady" |
volksaddict Samba Member
Posted: Mon Jul 06, 2009 7:36 pm Post subject: |
Quote: |
At least some of them should work with your key and you can leave some out or file them a little to make them work. |
Thats a really sorry ass way to rig an ignition switch. Heck, might as well take all the tumblers out and just use a screwdriver as a key! If you can't redo the tumblers properly, using all of them, send it to gabvwkeys who advertises here and he'll fix it right. And it won't be anywhere close to 200 bucks. Geeze, he can probably even make your ign match the doors (1 key like factory) for less than 200 bones! |
Yalmar Samba Member
Posted: Mon Jul 06, 2009 1:08 pm Post subject: |
thom wrote: |
Yalmar wrote: |
thom Samba Member
Joined: October 12, 2000 Posts: 6168 Location: Sacramento
Posted: Mon Jul 06, 2009 12:04 pm Post subject: |
Yalmar wrote: |
That's a threaded hole - just a crappy picture. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Yalmar Samba Member
Posted: Mon Jul 06, 2009 11:47 am Post subject: |
justcruzin wrote: |
Campy wrote: |
I removed the ignition switch from my 1963 bus fairly easily without removing the tray. |
Me too!! I even put a different one in and then had to remove it because I think it was a bug ignition. So now I have the bug ignition one hooked up on the outside until I can get a replacement bus one!!!
justcruzin |
how do I get the switch loose ? |
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1493 Location: United States
Posted: Sun Aug 28, 2005 9:48 pm Post subject: |
Campy wrote: |
justcruzin |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sun Aug 28, 2005 9:37 pm Post subject: |
coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Sun Aug 28, 2005 5:23 pm Post subject: |
As long as the door and ignition are the same key profile, it's fairly easy to rekey them yourself. The ignition is very easy to remove. Remove the battery cables first. I can't stress enough how important this step is. One of the wires at the ignition switch is coming, unfused, directly from the battery. If it grounds out, it will at the very least fry that wire and could fry all the wires in the harness coming from the engine compartment. Battery disconnected? Good. Now remove your parcel tray. Loosen screws in the steering shaft grommet to swing the parcel tray support out of the way. Remove wires from back of ignition switch. Remove screw (there's only one) from bottom of ignition switch. Pull switch out.
Now that it's out, take a jeweler's screwdriver and remove the clip in the back that holds the switch together. The tumbler assembly can be pushed out the front and you can rearrange the wafers in there until your key works. At least some of them should work with your key and you can leave some out or file them a little to make them work. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
CaliforniaShagWagon Samba Member
Joined: August 03, 2004 Posts: 1 Location: Alameda, CA
Posted: Sun Aug 28, 2005 4:58 pm Post subject: Re-Key or Replace ignition housing? |
Shaka,
Adam |
