Spare tire well question (Bulkhead)
Lind
Lind is offline
PostPosted: Fri Dec 27, 2024 12:20 pm    Post subject: Re: Spare tire well question (Bulkhead) Reply with quote
von_hansel wrote:
campingbox wrote:
von_hansel wrote:
Lind wrote:
June 22 1961 one drain hole
now between June 1961 and Jan 1962.
Thank you Lind. We are getting closer to narrowing this down.
If you have a '62 walk thru built between July 1961 and December 1961, can you let us know how many drain holes you have in your spare tire well?
Have you been looking at flipseats westies too?
Hi Greg,
The April '61 pic posted above is Clara's flipseat and Lind's June '61 is a flipseat as well. My assumption is whether it is a flipseat, swivel seat, or walk through, it would have the same number of drain holes depending on the year, which is either one or two.
For the record, I have not looked at a '58 walk through to confirm if it has a drain hole.
my april '58 walkthrough has two smaller holes spaced further apart than the later holes.
Also, I would speculate that the first use of these holes was to drain primer out of the spare tire well after they dunked the body in a vat of primer.
Wanted:
von_hansel Premium Member
von_hansel is offline
PostPosted: Fri Dec 27, 2024 8:13 am    Post subject: Re: Spare tire well question (Bulkhead) Reply with quote
Hi Greg,
Mugatu wrote:
campingbox Premium Member
campingbox is offline
PostPosted: Fri Dec 27, 2024 7:34 am    Post subject: Re: Spare tire well question (Bulkhead) Reply with quote
PostPosted: Thu Dec 26, 2024 3:09 pm    Post subject: Re: Spare tire well question (Bulkhead) Reply with quote
Mugatu wrote:
Lind
Lind is offline
PostPosted: Mon Dec 23, 2024 5:00 pm    Post subject: Re: Spare tire well question (Bulkhead) Reply with quote
von_hansel wrote:
Thank you so much Kommercial! With your information, we have now narrowed it down between April '61- January '62
Lind: Can you let us know how many drain holes your mouse grey flipseat has in the spare tire well?
Wanted:
PostPosted: Sun Dec 22, 2024 4:14 pm    Post subject: Re: Spare tire well question (Bulkhead) Reply with quote
Mugatu wrote:
Kommercial
Kommercial is offline
PostPosted: Sun Dec 22, 2024 2:43 pm    Post subject: Re: Spare tire well question (Bulkhead) Reply with quote
June62- 2 drain holes. (And factory pad?)
January, 30th, 62- 2 drain holes, if the judges will accept the half arc hole before it is lost to time.
Seems like it's pushing it into the 61 year change...
PostPosted: Thu Dec 19, 2024 1:12 pm    Post subject: Re: Spare tire well question Reply with quote
Kommercial wrote:
My March 3rd 63. 2 drain holes, no side bumps.
Thank you for the response Kommercial! This helps us narrow it down.
Can someone with a 1962 Walk-Through bus please let us know if your bus's spare tire well has one drain hole or two drain holes?
Thanks
Mugatu wrote:
Kommercial
PostPosted: Mon Dec 16, 2024 8:34 pm    Post subject: Re: Spare tire well question Reply with quote
PostPosted: Mon Dec 16, 2024 4:20 pm    Post subject: Re: Spare tire well question Reply with quote
Old thread but I couldn't find the info anywhere..... Does anyone know when the spare tire well on a walk through bus went from one drain hole to two?
April '61 with one drain hole
Late '63 with the bumps with two drain holes
Can someone with a '62 walk through post a pic of their spare tire well and provide the build month?
Mugatu wrote:
derv
derv is offline
PostPosted: Tue Nov 01, 2005 8:56 am    Post subject: Reply with quote
Pertaining to the bulkhead discussion, I have a '67 OG paint nice Kombi non-walk thru. It looks as if the PO was trying to 'tow' something behind the bus by opening the rear hatch and running a rope or chain thru the cabin and hooked it up to the bulkhead - and let er rip.
The result is a nice 6-8" bend in the whole bulkhead from the center toward the rear of the bus. The seats still line up ok, but it is the first thing you notice when looking at the bus.
Is this something I should worry about repairing? Perhaps trying to 'bend' the whole bulkhead back into shape the other direction? Or just not worth the hassle?
This is a very nice bus and am not certain major surgery like replacing with a doner would be a good idea.
Thoughts?
Kommercial
PostPosted: Tue Sep 27, 2005 5:19 am    Post subject: Reply with quote
Hey Everett
I believe jul62 and later non panel is all the same AFAIK. Has anyone ever mapped out how many full bulkheads there are?
I know of at least 8 different full bulkheads (not counting barndoor).
2 of each type, panel and non-panel
late 50s to Oct 60
rising sun, bench seat, no tire bracket.
http://www.thesamba.com/vw/forum/album_page.php?pic_id=212702
Oct 60 to Jan 62
rising sun, 3 position bench, no tire bracket
Jan 62 -June 62
rising sun, 3 position bench, with tire bracket
June 62-up to 67.
Full sun, split bench, w/tire holder bracket, Deeper recess
http://www.thesamba.com/vw/forum/album_page.php?pic_id=5073
Am I missing any?
I just happen to have a grey back/pearl white front bulkhead, I don't remember if it's panel or non panel, I'll look. Mmmm nothin like repairing og buses with og paint parts.
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Mon Sep 26, 2005 9:32 pm    Post subject: Reply with quote
Yes, it's 1963-up as several people emailed. (basically '63 model year)
I have corrected my ad.
Thank you to everyone for the responses so far.
I would be interested to know if it changed again at a later date.
EB, why don't you stop by here on your way to or from vegas, I have about every year bus (non walkthrough) from 59 to 67, you're more then welcome to take pics and you can even cut out the spare tire well you need if I have one out of one of my parts busesor I allready might have a couple bulkheads cut. Have sawzall and plasma cutter.
"no more hacking my sig line"
PostPosted: Mon Sep 26, 2005 8:38 pm    Post subject: Reply with quote
Clara Premium Member
Clara is offline
PostPosted: Mon Sep 26, 2005 5:35 pm    Post subject: Reply with quote
On 30 July, 1962, at VIN 971 550
The spare wheel recess was deepened
The driver's seat became split 1/3 2/3
The front and rear wheel arches were changed.
TeamSpatula
Samba In The Rain
TeamSpatula is offline
PostPosted: Mon Sep 26, 2005 12:58 pm    Post subject: Reply with quote
Might as well go ahead and make it a walkthrough...that doesn't hurt anything right? Then you can add those Camaro seats...
<---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
1981 Diesel Rabbit
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com
///Mink
///Mink is offline
PostPosted: Mon Sep 26, 2005 9:29 am    Post subject: Reply with quote
Gag. Why do people do crap like that??? Good luck, I'm sure you'll be able to find one easily enough.
PostPosted: Mon Sep 26, 2005 9:23 am    Post subject: Spare tire well question (Bulkhead) Reply with quote
I posted this ad:
http://www.thesamba.com/vw/classifieds/detail.php?id=223621
Is 1962-up correct? Are the spare tire wells from 1962-67 identical?
I want to make sure I get the right one.
I know the spare tire retainer L bracket (held on with wingnut) changed at some point but it was not at the change from 15" to 14" rims.
Example:
http://www.thesamba.com/vw/forum/album_page.php?pic_id=104657
http://www.thesamba.com/vw/forum/album_page.php?pic_id=104651
As far as I know, the metal itself didn't change when the bracket changed but let me know...
