Oil rings between case
Mad Manx
Mad Manx is offline
PostPosted: Wed Oct 26, 2005 4:10 pm    Post subject: Reply with quote
What do you do if your case has been shuffle pinned as in the example above?
I just put a blob of Ultra Grey rtv under the washers when I bolt it
together, I never put any sealant on or around the main bearing journal
stands. Never had a leak. Wink
RAC400
RAC400 is offline
PostPosted: Wed Oct 26, 2005 1:28 pm    Post subject: Reply with quote
What years did the cases not have this sort of recess.?? The vw is a 70. Not sure on original motor or not.
timmy74006
timmy74006 is offline
PostPosted: Wed Oct 26, 2005 9:46 am    Post subject: Reply with quote
Tim
RonR
RonR is offline
PostPosted: Tue Oct 25, 2005 10:26 pm    Post subject: Reply with quote
BigLoaf wrote:
sorry to hijack this thread but it reminded me of this. I was trying to take the o rings out of my case, and i found them to be EXTREMELY hard. I pushed on them with a screwdriver and they didnt budge or flex or squish or anything. My screwdriver eventually slipped and scratched the case and I decided to stop before I did something stupid. I figured they would be soft rubber but maybe im missing out on something.
Well, heat does have a play in that shit. You might think about replacing those.
But getting back to the original question, that case is prior to "O" ring cases. If you try to put the "O"-rings on the main bolts, it will hold the center main open and will have really bad oil pressure.
BigLoaf
BigLoaf is offline
PostPosted: Tue Oct 25, 2005 8:23 pm    Post subject: Reply with quote
Droolman
Droolman is offline
PostPosted: Tue Oct 25, 2005 12:05 am    Post subject: Reply with quote
do you have any way to post pics?
1967 blue bug
1965 drag bug
RAC400
RAC400 is offline
PostPosted: Mon Oct 24, 2005 5:55 pm    Post subject: Reply with quote
My case halfs do not look anything like the pics. There are no recess areas. How do I seal this. Sealing washer / nut. ???
Thanks
Mad Manx
Mad Manx is offline
PostPosted: Mon Oct 24, 2005 4:38 pm    Post subject: Reply with quote
Unless you have a new CB Alum case and it will look like this.
with shuffle pins and no seal relief.
turboblue
turboblue is offline
PostPosted: Mon Oct 24, 2005 4:33 pm    Post subject: Reply with quote
RAC400 wrote:
If that is the case, then my case halfs do not have the recesses. Is it true that later model cases do not have these recesses????
Brand new off the shelf magnesium case.
O-rings go around the 6 large studs and into the recesses at the base.
Other half of the same case.
I'm thinking you have a case that at one time took the sealing case nuts on the 6 big case studs and maybe didn't have the o-ring recess.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
RAC400
RAC400 is offline
PostPosted: Mon Oct 24, 2005 3:25 pm    Post subject: Reply with quote
turboblue
PostPosted: Mon Oct 24, 2005 3:15 pm    Post subject: Reply with quote
Actually the recesses are on both halves.
I'll get some pics up in a few.
Gary
RAC400
RAC400 is offline
PostPosted: Mon Oct 24, 2005 3:12 pm    Post subject: Reply with quote
I am looking at the case halfs right now, and I do not see any sort of recess. Are they not typically where the 6 case studs are ? I thought I read some where that later year cases do not these recess. ???????
turboblue
PostPosted: Mon Oct 24, 2005 3:05 pm    Post subject: Reply with quote
The recesses are on the distributor half of the case.
Gary
RAC400
RAC400 is offline
PostPosted: Mon Oct 24, 2005 2:51 pm    Post subject: Reply with quote
I pulled the cases apart. and I do not see any sort of recess where these o rings may go. Does this mean I have a newer case?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Oct 24, 2005 7:57 am    Post subject: Reply with quote
It needs them.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
RAC400
RAC400 is offline
PostPosted: Mon Oct 24, 2005 7:53 am    Post subject: Oil rings between case Reply with quote
Does anyone know if a 1970 1600 requires the o rings between the case halfs. I assemble my engine last night and did not install o rings that came in kit. Apprantly some engines require these o rings and some years do not. I am just not sure if mine requires them.
Thanks
