OMG! how screwed am I
Schubs409
Schubs409 is offline
PostPosted: Sun Mar 26, 2006 9:02 pm    Post subject: Reply with quote
Russ Wolfe wrote:
Locknar wrote:
Update.. everything works except the dang radio.. Sad
You live and learn I guess. Thanks for the comments.
You wanted a new stereo anyway. That is the sub-concious reason you did it. Smile
that must be why i did it too!!! its so clear to me now!!! Very Happy
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Mar 26, 2006 3:51 pm    Post subject: Reply with quote
Gary: OK. Ima poop.
Locknar
Locknar is offline
PostPosted: Sun Mar 26, 2006 3:46 pm    Post subject: Reply with quote
Life is a web woven by necessity and chance.
My Fav vw shop: www.airkooledkustoms.com
1973-T3-SQB
1971-1302
Russ Wolfe
PostPosted: Sun Mar 26, 2006 3:41 pm    Post subject: Reply with quote
Air_Cooled_Nut wrote:
My only concern would be the polarization of the generator. I'll let someone more knowledgeable speak about that.
I would recommend you put some masking tape on the battery cables and use a permanent marker to label them so you won't do it again. Better yet, replace the cables with the appropriate color cables Wink If anything, replace the ground cable with a braided one. That's more unmistakeable and will work equal to or better than a cable Cool
If the generator light is out now, he didn't hurt it. If the engine didn't start with the reversed polarity, the generator never got power applied to effect the polarity.
Gary: OK. Ima poop.
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Sun Mar 26, 2006 3:35 pm    Post subject: Reply with quote
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
Russ Wolfe
The FI control unit has a protection diode in it. If the FI engine runs, then you are OK there. You might have hurt the radio, or the T/S flasher, but I think that is about it.
Gary: OK. Ima poop.
Schubs409
PostPosted: Sun Mar 26, 2006 2:59 pm    Post subject: Reply with quote
does ur radio work? i fried my radio that way exact same way....luckily its the only thing that was hurt.
Locknar
Locknar is offline
PostPosted: Sun Mar 26, 2006 2:54 pm    Post subject: Reply with quote
True, but I am one of those guys that will loose sleep thinking about that dang screw-up.
1973-T3-SQB
1971-1302
Gary
Person of Interest
Gary is offline
PostPosted: Sun Mar 26, 2006 2:50 pm    Post subject: Reply with quote
If it started up, then it doesn't appear that there's a problem.
West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943)
Locknar
Locknar is offline
PostPosted: Sun Mar 26, 2006 2:42 pm    Post subject: OMG! how screwed am I Reply with quote
I decided to work on the area under the battery today and give it a good cleaning and anti-rust coating. While removing the battery I noticed that the cable marked neg(-) was RED and the cable marked Pos(+) was black. I thought it was odd but removed the battery and spent the next couple of hours cleaning/coating the compartment.
Guess what I did when I stuck the battery back in.. Yeah I put the RED on pos(+) and Black on neg(-). The car would turn over but I got no fuel pump noise. I checked the cables for tightness and then I realized they were backwards... I switched the cables back to the way they were prior to me removing them and it started right up.
Q: Do you think I fried anything having the cables backwards??? ??
and yes I have fixed the cables so that this wont happen again. geesh
1973-T3-SQB
1971-1302
