Vin Plate Restoration
Page: 1, 2, 3  Next
JeffRens
JeffRens is offline
PostPosted: Sun Jan 05, 2014 8:22 pm    Post subject: Reply with quote
Lemon juice and a toothbrush... amazing results on my VIN plate. Gotta say I'm kinda concerned about licencing my car after reading this post. I have a donor apron I need to put my VIN plate on and a non-matching pan. Wish me luck....
Russ
Russ is offline
PostPosted: Fri Nov 06, 2009 11:06 pm    Post subject: Re: figured i would revive this Reply with quote
Russ wrote:
just had my vin tag lightly blasted then i sent it out for zinc plating.it turned out really well.
not sure if the made in germany tag is supposed to be like this or black but i went with zinc and i'm happy
i just used a zinc finish and they turned out great.
Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:)
Bruce
Bruce is offline
PostPosted: Fri Nov 06, 2009 9:02 pm    Post subject: Reply with quote
Why not use the original, cadmium?
54vert
54vert is offline
PostPosted: Fri Nov 06, 2009 10:42 am    Post subject: Reply with quote
Jim.....I took my vin plate and made in Western Germany plate to a local metal finishing shop which does zinc plating....they tried twice to glass bead blast and clear zinc the two plates and they still have not turned out right....the bead blast does not appear uniform and the clear zinc has a spotty yellow color to it....the platers stated that is what clear zinc does unless you add chromate to it which then gives is a silvery blue color (does not appear to have that bare metel look anymore).
I was wondering if I could send them to you to have done since you have had 20 or so done with no problems and if so, how much?
Thanks...James
56 type 1 vert 54 type 1 vert
VWwerks
VWwerks is offline
PostPosted: Thu Oct 08, 2009 9:27 am    Post subject: Reply with quote
I tried tumbling and it didn't work as well or as fast as a light glass bead blast.
Glass bead, clear zinc plate... works perfect every time. I have done at least 20 or so this way. Some really rusted and some not very bad, all came out great. Glass bead leaves a nice uniform satin finish for the clear zink.
I use an aircraft rivet set on an air hammer to put them back on. With the gas tank out it is easy to hold a "buck" (any chunk of metal, even a hammer works) behind the rivet and a quick shot with an air hammer and you're done.
www.VWwerks.com
543fold
543fold is offline
PostPosted: Thu Oct 08, 2009 8:03 am    Post subject: Reply with quote
Has anyone tried a vibratory tumbler/polisher?
https://www.instagram.com/w.a.r._wills.auto.restoration/
______________________
....even the rust has rust!
How "NICE" do you wanna spend?
W.A.R.
Will's Auto Restoration
54vert
54vert is offline
PostPosted: Wed Oct 07, 2009 10:44 am    Post subject: Reply with quote
Russ.....I need to do the same to mine...what material was used to blast your vin plate?...sand/baking soda/other?
Thanks
James
Russ
Russ is offline
PostPosted: Sun Mar 23, 2008 9:51 am    Post subject: Reply with quote
iceland green
65 beetle done:)
Denz
Denz is offline
PostPosted: Sun Mar 23, 2008 9:04 am    Post subject: Reply with quote
Russ wrote:
here it is mounted in the car. turned out pretty good i think
Looking good Russ. What colour is that?
Denz
Denz is offline
PostPosted: Sun Mar 23, 2008 2:13 am    Post subject: Reply with quote
Cheers Josh. Cool
joshbuchan
joshbuchan is offline
PostPosted: Sat Mar 22, 2008 8:02 pm    Post subject: Reply with quote
Lanny & Darren at LanD make a billet one with your #'s on it
http://www.landproducts.ca/
Denz
Denz is offline
PostPosted: Sat Mar 22, 2008 4:20 pm    Post subject: Reply with quote
I don't actually have a VIN plate for my Oval. Its obvious that the car had a smash at some point and the plate must of perished. Anyone know somewhere where I can get a replacement?
David
David is offline
PostPosted: Sun Mar 16, 2008 7:36 pm    Post subject: Reply with quote
Looks great!
Russ wrote:
the classic if all goes well Wink
i want to finish it before i start posting a ton of pics of it.
As long as you're taking photos for the future 'build' thread, I can handle the occasional 'teaser' pic Smile
Good luck in getting it to The Classic.
Cheers,
Dave
*October '54 Ragtop
Russ
Russ is offline
PostPosted: Sun Mar 16, 2008 6:08 pm    Post subject: Reply with quote
65 beetle done:)
dirtydeedss
dirtydeedss is offline
PostPosted: Sun Mar 16, 2008 5:57 pm    Post subject: Reply with quote
so russ, When are we going to be able to see your car? Tony says its looking pretty Sweet
View user's profile Send private message MSN Messenger Classifieds Feedback
Russ
Russ is offline
PostPosted: Sun Mar 16, 2008 5:54 pm    Post subject: Reply with quote
65 beetle done:)
KantDriveFast
KantDriveFast is offline
PostPosted: Fri Mar 14, 2008 5:42 pm    Post subject: Reply with quote
So is bead-blasting is bad or ok?
Guess it depends on the blaster huh? Cool
Trevor P
Trevor P is offline
PostPosted: Fri Mar 14, 2008 5:22 pm    Post subject: Reply with quote
Here is mine before and after I soaked it in lemon juice for a day. I'm also gonna get mine plated like you did Russ. BTW all the "Made in Germany" tags I've seen have been silver like yours.
53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy
ericktheelectrician
ericktheelectrician is offline
PostPosted: Thu Mar 13, 2008 7:33 pm    Post subject: Reply with quote
I used the ones in the ad for $16.00 a set and they worked great
Russ
Russ is offline
PostPosted: Thu Mar 13, 2008 7:07 pm    Post subject: Reply with quote
i bought little alluminum blind rivets.
i'll mount my plate this weekend and if you like it i'll send you the same rivets i used for free (think i have a couple extra)
65 beetle done:)
Page: 1, 2, 3  Next
