Porsche engine in a bus
Page: 1, 2, 3  Next
VWBobby
VWBobby is offline
PostPosted: Thu May 18, 2006 1:23 pm    Post subject: Reply with quote
Dave,
You really should rebuild your stock 1500 engine or build a 1600 sp or dp(depending on what parts you already have). If you already have all the SP parts, stick with that. Its a reliable, economical ($$ and mpg), long lasting engine.
Try to source as many German parts as you can.
The things you can get away with are: Mahle p&c's are better than most other Brazilian sets. Some people have luck with Cofap, I'm not impressed. German (KS) sets are expensive, so thats out of your budget.
I always try to get German Kolbenschmidt bearings. Otherwise, Metal Leve, and some Austrialian sets are good.
Victor gasket sets or Sabro. Eagle or Engle cams are good, I use Web Cams but they are more expensive.
69doublecab,
I won't give out all the specs on the engine. Here is what I will give out from the questions you asked: 9.85:1 compression ratio. AMC round port castings, 44 x 36 SI ss valves, Ti retainers, chromo keepers, studs and pushrods. Sane porting. Cam specs are secret, but its 'close to' 250 Actual intake and 260 Actual exhaust duration, .500" lift, non-standard lobe centers. Dellorto 40 DRLA's, CB update kits. Hand built 1 5/8" exhaust, 44" secondaries, 3" stubs, 2 1/2" collector, Ultraflo muffler.
DTM fan shroud. Original from Joe's son, before Jake started making them.
Well under $4000.
Stock '74 stupidbeetle trans. Cruise at 70mph, white knuckle ride!
davelarue
davelarue is offline
PostPosted: Thu May 18, 2006 12:08 pm    Post subject: Reply with quote
Well, now i'm not sure what my engine will cost....
I believe in a good solid engine that lasts, and is reliable. If it has speed, thats cool, but not my priority.
So, i should go for german parts?
I'm going to do the engine work myself (not the machine work though). It'll probably cost more than $500, so i'll save up a couple hundred more.
Alan Brase
Alan Brase is offline
PostPosted: Thu May 18, 2006 10:32 am    Post subject: Reply with quote
VWBobby wrote:
Also the comments about big engines sucking tons of gas are way out of line. My engine is tuned for HP instead of economy and I still get around 24-26mpg hwy from a 2270cc T4 with a very healthy cam and nice flowing heads. Its about HOW you build it and what parts you use.
"Good, cheap, fast", pick two. Wink
Tell us more about how your 2270 is built. compression ratio, type of heads, valve size, cam specs, induction, exhaust. final drive ratio and transmission ratio. And in what vehicle. anything else that would affect mpg.
I like type 4's by the way, have a ac Vanagon and a 912E project.
I'd love to make my ac Vangon a little more thrifty. I bet it doesn't get 15mpg right now. The best mpg fix for it has seemed to be a subie transplant or a diesel.
BTW I suppose you have 5-10 times $500 in the 2270 and getting into a splitty, though, right?
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
VWBobby
VWBobby is offline
PostPosted: Thu May 18, 2006 10:14 am    Post subject: Reply with quote
$500!!! Good luck! My last $500 rebuild was closer to $550 and I skimped out on everything except: line bore ($55), P&Cs ($83 Mahle), bearings (total $50), gaskets ($20), hardware, etc. That was back in 1999, by the way. Prices have gone up since then.
No offense, but how could you expect to do any type of conversion, or even a Good rebuild for $500? You can't even walk out of a junk yard with a running turn-key engine for less than $200 these days. Like Ronnie (splitpile) said, "I can't even rebuild a stock 1600 that will last for 1000 dollars."
Also the comments about big engines sucking tons of gas are way out of line. My engine is tuned for HP instead of economy and I still get around 24-26mpg hwy from a 2270cc T4 with a very healthy cam and nice flowing heads. Its about HOW you build it and what parts you use. Slapping together a 2L engine with monster carbs and shitty heads will give you bad gas millage. Not to mention that the engine doesn't even feel or produce power like it should.
Alan Brase
PostPosted: Thu May 18, 2006 9:15 am    Post subject: Reply with quote
I know prices have gone up a bit recently, but I think it might be possible to to a $500 stock rebuild to a 1200, 1300, 1500 or 1600 type 1 engine yet. No magazine bling-bling, just good machine work and stock parts. With the price of gasoline these days, building up a hot rod motor is just the beginning of your expense. And I really question what the longevity would be, especially with larger bored versions. 87's or machine in 88's might be okay.
I once rescued a 70 bus from a junkyard. (Had to re-title it and everything!)
I drove it around town for a while and one day someone stopped me and said he was the 2nd previous owner (me being the 5th owner).
He had driven that same engine to Alaska 3 times! I later located and became friends with the engine builder. New Mexican case and slip in 87's. This in a stock 1600 single port. I think it had about 80k miles on it when end play got excessive. My brother then line bored it, re-ringed it and put in another car.
So, my point is, avoid the California-bolt-on stuff. Stock parts. German is usually better, but perhaps not worth the extra $. Ask your machinist.
If your engine is a known quantity, (you know it has not been run out of oil!), you can usually just rebuild the top end. Valve guides, exhaust valves, piston rings or p& c assemblies. A machinist you trust for the valve work, one that is familiar with VW heads. If the engine has a lot of end play, then the bottom end needs to come apart and get line bored, usually.
Practice years ago was to rebuild the top end once before splitiing the case.
I still think you can do it for $500!
Al
Al Brase
Vanagons:
davelarue
PostPosted: Wed May 17, 2006 10:34 am    Post subject: Reply with quote
pyrOman wrote:
davelarue wrote:
Wow! I really have to save now. This makes a new engine! Isn't it better to order from one supplier, regards to shipping?
Thanks for the list.
I've priced that too. Comes out to about the same, give or take a couple of hundred, but I rather do the work myself. That way I know exactly what's going into my engine and I won't have anyone but myself to blame if anything goes wrong. Not to mention my being able to get right back into it, tear it down and find/fix the problem vs having to take the engine back to whoever for warranty or whatnot, time without a motor blah blah blah... Rolling Eyes
Again, my last built was the 1835. Had low oil pressure "issues" since day one but that "day one" was some 5 years ago and it still runs good. I just got tired of the oily mess the cracked case is making. So on to the new one! Cool
You're right. It'll definitely get you more "control" of your engine. Also, you learn a lot, and it's cheaper in the long run....
I can't wait to rebuild it!
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed May 17, 2006 9:22 am    Post subject: Reply with quote
davelarue
PostPosted: Wed May 17, 2006 8:50 am    Post subject: Reply with quote
pyrOman wrote:
Just stumbled into a list I made to use as "reference" when buying my engine parts. The prices listed were taken from current magazine ads of various parts houses:
Case $450 SoCal Imp. Super Case
Crank $269 cpi1.com Scat Volkstroker 111
Crank Gear Kit $ 45 Pacific Customs
Jugs $180 Pacific Customs
Total Seal Rings $ 87 Pacific Customs
Heads $240 (pair) SoCal Imp. (Bore 90.5)
Copper Gaskets $ 12 Pacific Customs 0.060”
Rods $110 Pacific Customs Stroker Chromoly
Cam $ 71 SoCal Imp. W100
Bearings $ 40 SoCal Imp.
Lifters $ 80 cpi1.com Scat Lube-A-Lobe
Rockers $130 cpi1.com Scat 1.25
Flywheel $ 60 SoCal Imp. Stock 12v
Teflon buttons $ 10 Pacific Customs
Tin $135 SoCal Imp.
Total $1919
Just a rough estimate, your prices may vary! Razz
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed May 17, 2006 8:45 am    Post subject: Reply with quote
Tin $135 SoCal Imp.
Total $1919
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed May 17, 2006 5:54 am    Post subject: Reply with quote
davelarue wrote:
You all have me convinced. I will stay away from a Porsche engine, and rebuild my 1500cc. I have some good manuals: Haynes, John Muirs, and others. Firsti'll strip the engine, and then take the case to the shop. Then i'll get some new studs, find a decent fan housing, and go from there. It's really just the machine work that will cost me. I will save up a little more, so i have a better budget Wink
Thanks you all. Now i know what its all about....
D
Again, the first thing to do with your present case is to have checked for cracks before you get any work done on it!!!! Confused
davelarue
PostPosted: Wed May 17, 2006 3:08 am    Post subject: Reply with quote
D
Flipseat
Flipseat is offline
PostPosted: Tue May 16, 2006 6:36 pm    Post subject: Reply with quote
A $500 budget? No offense, but Porsche power is out of the question just like others have said. Heck, just the exhaust on my 911 cost $1400. Stay with VW power, rebuild the 1500, read up, and do as much as you can yourself. Rebuilding my 40hp the last time cost me more than $500 though... Keep in mind, a manual is something that you can't afford not to buy.
Insert random important looking club initials here.
Dave24
Samba Hack Purist
Dave24 is offline
PostPosted: Tue May 16, 2006 5:52 pm    Post subject: Reply with quote
Exactly, some sage advice.
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Tue May 16, 2006 4:09 pm    Post subject: Reply with quote
[quote="davelarue"]
Dave24 wrote:
....in case i came across a Porsche engine, i just wanted to know if it would fit my car. Sometimes there are some really good deals in the local classifieds, or paper....
When you come across that Porsche engine, make sure it's air cooled
and not out of a 924 or sumpin'
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Tue May 16, 2006 2:46 pm    Post subject: Reply with quote
I'm putting a 64 356 SC engine in my 60 DC. The engine cost close to 4000 dollars to have rebuilt, years ago. By the time I have a turn key engine I will have close to 7000 into it.
"no more hacking my sig line"
Dave24
Samba Hack Purist
Dave24 is offline
PostPosted: Tue May 16, 2006 2:28 pm    Post subject: Reply with quote
davelarue wrote:
Dave24 wrote:
So we've gone from what porsche engine will fit in your bus, to rebuilding your 1500 on a $500 budget?. I mean no offense, but thats a huge swing. You could not do a porsche engine conversion or type 4, of any type, for $500. So I'm not sure why you posed the orig. question, if the budget is truly $500 that you have to work with.
Even doing the work yourself, I think you'll go way outside that budget in short order on a complete rebuild of your 1500. I'd say you need to re-think either you're budget, or the type of rebuild/engine you can really afford to do. As suggested by the others, a rebuilt 1600 long block MAY fit your budget/needs. Again, no offense intended, just being realistic.
Sure, but in case i came across a Porsche engine, i just wanted to know if it would fit my car. Sometimes there are some really good deals in the local classifieds, or paper....it wan't ment as a discussion, just a small question. As for the 1500cc. I'll look around for a 1600cc long block. That sounds great.
Thanks you all! Now i know which Porsche engine to look for, and what to do with my engine. not bad for one thread Wink
D
Dave, you really need to think VW, for your VW. If you do find a "good deal" on a porsche engine/drive train, then buy it and set it aside till you find a "good deal" on a porsche to put it into. The rebuild on my old '71 911s 2.2 cost $6800 to do, years ago. VW=your budget. Porsche=$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$. Good luck with your project.
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Tue May 16, 2006 1:52 pm    Post subject: Reply with quote
Let us know what kind of Porsche engine you "come across", please.
davelarue
PostPosted: Tue May 16, 2006 1:33 pm    Post subject: Reply with quote
D
Dave24
Samba Hack Purist
Dave24 is offline
PostPosted: Tue May 16, 2006 1:31 pm    Post subject: Reply with quote
arthurnugen wrote:
if I had my choice though, I would go with a 1600 SP with stock dizzy for good low end torque and good gas mileage.
1600 s/p is what I run, for those reasons (and the reliability).
Dave24
Samba Hack Purist
Dave24 is offline
PostPosted: Tue May 16, 2006 1:26 pm    Post subject: Reply with quote
Page: 1, 2, 3  Next
