O2 sensor
plummerdesign
plummerdesign is offline
PostPosted: Sat May 25, 2013 10:27 pm    Post subject: O2 sensor reset button Reply with quote
The location of this black box is so unexpected. With road grime it is also hard to see the button. Here is a picture of the box…
Cheers,
Jeffery
(Westfalia travel / camping videos at YouTube link below)
It is old and green and it makes me grin.
1984 Westfalia 1.9
denwood
denwood is offline
PostPosted: Wed Oct 03, 2012 8:17 pm    Post subject: Reply with quote
It's already grounded via the exhaust. The white and black should just be capped. You could run 12v to the sensor heater wires to speed the system closed loop cycle...otherwise insulate and secure those wires.
Cheers,
Dennis Wood
The Grape
Vinzanto
Vinzanto is offline
PostPosted: Wed Oct 03, 2012 7:47 pm    Post subject: Reply with quote
Okay, grey wire (signal) to the green wire (to ECU). Should I ground the new sensor or just cut the ground back?
denwood
denwood is offline
PostPosted: Wed Oct 03, 2012 2:11 pm    Post subject: Reply with quote
One is signal (likely grey) , another is ground (black) and last is 12v (white). Your ECU signal wire must only be connected to the o2 sensor signal. To do otherwise will result in a very poor running van.
Cheers,
Dennis Wood
The Grape
Vinzanto
Vinzanto is offline
PostPosted: Wed Oct 03, 2012 1:39 pm    Post subject: Reply with quote
So my FLAP'S Universal 02 sensor has 3 wires; a Grey, Black, and a White. Do I splice the green shielded wire into one specific wire or do I just link them all ?
-Thanks
tencentlife
tencentlife is offline
PostPosted: Sat Nov 06, 2010 5:12 pm    Post subject: Reply with quote
A heated sensor is indeed better, but only 86+ have the heater power supply circuit, earlier vans just use the one-wire sensor. Wouldn't be at all hard to add a heater circuit, though, probably worthwhile especially for urban drivers and for passing the idle emissions test.
Experience is death to doctrine.
RGS Paul
RGS Paul is offline
PostPosted: Sat Nov 06, 2010 11:47 am    Post subject: Reply with quote
Make sure you get the three wire O2 sensor not the one wire. Heated O2 sensors are a wonderful thing and your van will thank you.
Paul
'87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman
crowinghen
crowinghen is offline
PostPosted: Sat Nov 06, 2010 11:45 am    Post subject: Re: O2 Sensor Reset Reply with quote
Tully Mars wrote:
This is what I LOVE about this forum. My O2 Sensor light comes on... and I go okay.. now what??
x2
susie
1984 Westfalia a work in progress " Butters"
Tully Mars
Tully Mars is offline
PostPosted: Sat Nov 06, 2010 10:48 am    Post subject: O2 Sensor Reset Reply with quote
A two minute research job here tells me about the whole reset thing. I find the box. Driver side front of the wheel mounted to the frame. I find the button. Oh by the way, a small phillips head screwdriver works great because you have to push it All the way in.
Light is off. Problem solved for the time being.
Peace love dove. Laughing Very Happy Cool
I'm a man. But I can change.
If I have to.
I guess.
_______
84 Wolfsburg Westfalia
Hobie Cow
Creativemind
Creativemind is offline
PostPosted: Tue Jul 21, 2009 7:46 am    Post subject: Any Problems with the Gen. Bosch 02 sensor after install? Reply with quote
Has anyone had any problems with the cheap $40 dollar general Bosch O2 sensor since it was installed?
Any inspection passing issues?
Thanks,
Robert
88 Wolfsburg, Automatic Silver Vanagon, 250,500 miles. Rebuilt Engine. 8/09
JunkYarDog
JunkYarDog is offline
PostPosted: Sun Apr 01, 2007 7:27 pm    Post subject: Reply with quote
Sorry I didn't see the post date.
bucko
bucko is offline
PostPosted: Sun Apr 01, 2007 4:28 pm    Post subject: Reply with quote
Thanks. Got this figured out a few months ago.
Current VW drives: 1984 Westfalia
Past VW drives: 1967 Beetle, 1973 Beetle, 1977 Bus, 1971 Military Type 181
JunkYarDog
PostPosted: Sun Apr 01, 2007 12:56 pm    Post subject: Reply with quote
bucko wrote:
So once it has been replaced, how do I reset the warning lamp on my dash?
Trace the speedo cable from the wheel, along the way you will find a junction box that it runs into. This box has a reset button. The O2 sensor light is not a fault light, the box tracks mileage and sets it off on a set schedule. Push the button and viola light is off.
klucz
klucz is offline
PostPosted: Tue Oct 10, 2006 12:50 pm    Post subject: Reply with quote
Ditto on the universal sensor. The reset button is on the speedo on the front drivers side wheel if I'm not mistaken.
84 Westy 4spd sold
bucko
bucko is offline
PostPosted: Tue Oct 10, 2006 12:46 pm    Post subject: Reply with quote
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Oct 10, 2006 9:12 am    Post subject: Reply with quote
I did. I soldered it too after crimping it. The generic Bosch single wire sensor comes with a ferrule just for that. Then used a piece of small heatshrink tube over the connection. I also slipped another tube over the wire to protect it more. Don't forget the grommet in the engine tin where it passes through.
I used a Bosch one with the following numbers on the box:
11027
0258001027009
489992
UPC code 0 28851 14027 0
Premium Oxygen Sensor
http://www.boschusa.com
bucko
bucko is offline
PostPosted: Tue Oct 10, 2006 8:17 am    Post subject: O2 sensor Reply with quote
What are you folks doing when it comes time to replacing the O2 sensor? My parts guy will sell me the replacment O2 that has the correct wiring plug for $47.00, or I can get the Bosh one for under $10.00, which would only require me to cut and splice it on.
Acceptable to splice a single wire Bosh and save $37.00, or is there something "special" in using one with the wired plug end?
