Brakes to the floor... occasionally
Lettuce
Lettuce is offline
PostPosted: Fri Dec 24, 2010 1:45 pm    Post subject: Reply with quote
the brake light switches should be the same. The warning light goes on if one switch trips quicker than the other, so if the the switches are different the warning light could be on even if your brakes work fine do to different pressure tolerances of the switches. I have reused the switches several times.
Rex lucy
Rex lucy is offline
PostPosted: Fri Dec 24, 2010 9:10 am    Post subject: Reply with quote
wondered that myself a while back. buy two they are alike.
gaggle o vws
Worknclassbug
Worknclassbug is offline
PostPosted: Fri Dec 03, 2010 6:16 am    Post subject: Reply with quote
Well I managed to get the master cylinder out last night. I had let the brake line connectors soak in WD-40 overnight and they came lose with no issues. The question I have now is about the brake switches. They both look identical. Are they? I don't see a separate listing in the parts catalog that says either one is different. So do I just buy two of the three prong brake switches?
73 Thing
71 Karmann Ghia (2.2L Subaru Conversion)
72 Deluxe Transporter
Huntington WV
Member of The Wagenfolks
Worknclassbug
PostPosted: Mon Nov 29, 2010 6:42 pm    Post subject: Reply with quote
I agree. I repaired some dash wiring today. I guess after some aging the terminals become brittle and crack so I had to replace a bunch of wire terminals. When I was done I did notice that the brake light is on constantly. I'm thinking that tomorrow I'll drain the gas tank and remove it since I need to check the sender in the tank and I need to check the fuel pump for the gas heater. I think it will make changing out the master cylinder a lot easier. Thanks for the help guys.
73 Thing
Huntington WV
Wildthings
Wildthings is offline
PostPosted: Mon Nov 29, 2010 10:29 am    Post subject: Reply with quote
Worknclassbug wrote:
Both have already been done. I think it is the seals in the master cylinder at this point. If they are of the type that I'm used to seeing they are flared and are probably bypassing until they happen to catch. I've noticed that it usually goes to the floor if I'm just slowly pushing the pedal but if I press it fast it catches so I'd say the seals have degraded or shrunk on the piston of the master cylinder. I've got a new one on the way and will replace it and post some results.
You may well have worn or hardened seals or you could have trash in one of the compensator ports (or whatever they are called). Either way a new master cylinder is probably the best way to go.
Worknclassbug
PostPosted: Mon Nov 29, 2010 6:26 am    Post subject: Reply with quote
alex77 wrote:
it sound like your brake master cyl is loosing pressure. That is why the second time you press on the brake pedal it feels better. Do you have a functional brake warning light?
The brake warning light is on my list of things to check while I have the dash apart this week. As far as I can tell it is not working at this point. I have the dash apart to repair the odometer and the fuel gauge (both of which I fixed last night). None of my dash lights (outside of the spedo now) work and I plan to go through them all. The wiring inside the dash has had some fingers in it in the past.
73 Thing
Huntington WV
Worknclassbug
PostPosted: Mon Nov 29, 2010 6:20 am    Post subject: Reply with quote
73 Thing
Huntington WV
norcalmike
norcalmike is offline
PostPosted: Mon Nov 29, 2010 1:59 am    Post subject: Reply with quote
if you are not loosing brake fluid, then id consider a bleed job or recheck adjustment. that the only thing it could be IMO
Wildthings
PostPosted: Sun Nov 28, 2010 10:11 pm    Post subject: Reply with quote
Press the pedal slowly and see what happens.
kubelmann
kubelmann is offline
PostPosted: Sun Nov 28, 2010 8:50 pm    Post subject: Reply with quote
Other than OE German master cylinder units the other (country of origin) outlander units fail just some sooner than others.
alex77
alex77 is offline
PostPosted: Sun Nov 28, 2010 5:53 pm    Post subject: Reply with quote
91 mexibeetle
BNMike
BNMike is offline
PostPosted: Sun Nov 28, 2010 12:06 am    Post subject: Reply with quote
This is one of the projects that Hermann is going to get this Winter. I've got all 4 new wheel, and a Master cylinder.
BNMike
Worknclassbug
PostPosted: Fri Nov 26, 2010 7:03 am    Post subject: Reply with quote
I'm draging this post up from the past. I'm having the same problem as the OP. The brake pedal is very random. The PO of my car had a shop rebuild the the brakes at each wheel and they did a great job. They replaced all of the cylinders, shoes and hardware at all wheels. I've adjusted the shoes and the pedal is nice and firm and the car stops straight and great. The problem is that the point that the brakes engage is random on the pedal. Sometimes they go straight to the floor but the next pump of the pedal they are up to the top. Sometimes they are half way down and at times they are at the top like they should be. It's very random. The master cylinder appears to be the original so I think my first step will be to replace it but I was curious as to what the OP of this thread did to correct the problem. I have no problem replacing the m/c but I don't want to do it if I don't have to. Any advice would be great. Thanks.
73 Thing
Huntington WV
Video Bob
Video Bob is offline
PostPosted: Mon Oct 23, 2006 10:43 am    Post subject: Reply with quote
No beam adjustment. Only the brake components were removed for cleaning, replacement and painting. Suspension was blasted and painted in place.
Ya can't have too many Vdubs!
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22
Ian Epperson
Ian Epperson is offline
PostPosted: Mon Oct 23, 2006 9:54 am    Post subject: Reply with quote
Video Bob wrote:
Here's a photo of my start on brake restoration.
Did you adjust the caster? It looks as if the beam is leaning back a bit.
Great looking job! I hope I can get mine looking as good.
Pittoale
Pittoale is offline
PostPosted: Fri Oct 20, 2006 12:36 pm    Post subject: Reply with quote
Wow, great picture! Good job on that brake restoration.
markie61
markie61 is offline
PostPosted: Fri Oct 20, 2006 12:28 pm    Post subject: Reply with quote
Towel Rail wrote:
You can't afford NOT to have good reliable brakes.
I put money into "stopping" before putting money into "going".
Mark
Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!?
Video Bob
PostPosted: Fri Oct 20, 2006 12:18 pm    Post subject: Reply with quote
Brakes are everything. Here's a photo of my start on brake restoration. Only new parts in photo is the shoes and cylinder. Everything else was restored by sandblasting and polishing with a vibrating polisher. Hi temp engine paint used for painted parts including brake drum (not shown)
Check out the sandblasted shock with orange metal flake paint.
https://www.thesamba.com/vw/gallery/pix/310265.jpg
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Thu Oct 19, 2006 11:08 pm    Post subject: Reply with quote
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Pittoale
Pittoale is offline
PostPosted: Thu Oct 19, 2006 8:57 pm    Post subject: Reply with quote
Thanks for the help, I will hopefully be working on it soon, we'll see if I can afford to do the whole brake system or not.
