lhwood Samba Member
Joined: August 14, 2012 Posts: 70 Location: san diego, ca
Posted: Fri Sep 13, 2013 10:30 am Post subject: WooHoo! |
I just talked to the guy that welded in the new bucket for me and he still has the old assembly! He sent me a pic. I'll pic up today. i'm a long time lurker, and haven't posted any pics yet. When I get the 67 done I will post a build post and let you all see what I've done.
For all the info and questions you guys have answered I am very grateful.
Thanks a million.
you guys and your knowledge are invaluable!!!
Cheers.
Les |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8241 Location: San Dimas
lhwood Samba Member
Posted: Fri Sep 13, 2013 10:03 am Post subject: Please comment on this issue to help me out |
I am having an issue with my headlight assembly. I had two assemblies to start with, but lost one. The number of the headlight retainer was SB12 311-941-045. Is this a Type 3 part? I thought I would order two new ones from KGPR. I ordered 141-941-041 KGPR #941-041 64 1/2 - 74 RP. The whole assembly. I get the assembly together inside the bucket, when I put the ring on the assembly is sticking out like a nipple in sub zero temps. I tried adjusting but it is simply to shallow to allow the bulb to come inside far enough. I want the light and assembly to maintain the line of the fender and not stick out like it is with the new assemblies. I can't find an old one on the Samba or anywhere, possibly because it is HELLA?
i hope I explained this clearly enough.
Please help out a guy in need of the infinite wisdom you all possess.
Thanks in advance |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Thu Dec 14, 2006 7:50 am Post subject: |
| 69ghiavert wrote: |
Yes absolutely.....for the life of me I can't find the inner guts of the other !#$%^@^ing headlight...I know I had TWO when we moved....I've gone through apparently every box but one....the right one ! ! ! I need the inner guts of the headlight bucket. the two piece round "framing" with the tension screw at the 6 o'clock position and the springs on it....I will gladly trade several other parts for this one....!
Name what you need Ghia related and I will ship it out nacho pronto ! |
PM me your address and let me know how many of each part you need. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2632 Location: Now in Honea Path, SC
Posted: Thu Dec 14, 2006 6:38 am Post subject: |
I'd like to suggest caution with this.
Many VW assemblies may look the same,
but when you get the adjuster assembly
into the bucket, many times you'll find that
not all the mounting tabs will line up!
Been there, done that & got the t-shirt to prove it.  _________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
HouseofGhia  Samba Member
Joined: February 17, 2005 Posts: 858 Location: Bellingham, WA
Posted: Thu Dec 14, 2006 5:23 am Post subject: |
if you are talking about the headlight retainer/adj assy...the 64-74 ghia shares the same assy with bugs 67-79, buses 68-79 and some other vw's
pretty common adj assy..... _________________ House of Ghia, since 1980
We Speak Karmann Ghia!! |
69ghiavert Samba Member
Posted: Wed Dec 13, 2006 10:53 pm Post subject: |
Name what you need Ghia related and I will ship it out nacho pronto ! _________________ There is something that needs to be said here. |
Posted: Wed Dec 13, 2006 6:46 am Post subject: |
Ghia only. Are you looking for parts? _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Tue Dec 12, 2006 10:52 pm Post subject: Headlight assembly question |
Are the guts...or skeleton frame behind the headlight for my 69.5 vert the same as any other Type 1 or are they specific to ghias? _________________ There is something that needs to be said here. |
