assistance needed stranded 40mi outside las vegas
verstraelen
verstraelen is offline
PostPosted: Sun May 20, 2007 11:59 am    Post subject: Reply with quote
dogpilot,
I've checked for loose wiring can't see anything unusual. engine cranks but does not fire or cough or anything else, I took of the center distributer cable and there is no spark to ground when cranking. Think gas is ok.I am alone here picked up the van from CA heading to NM, stranded in parking lot of nevada welcome center waiting on a call from a friend to see if we can tow the van into las vegas. if you want to pm me a phone number that i can call may be I can try something else... just grasping at straws..
thanks anyway
rudi
Dogpilot
Dogpilot is offline
PostPosted: Sun May 20, 2007 11:51 am    Post subject: Reply with quote
I would start on the ignition system first off and make sure all the wires are in place. I would then systematically check all the connectors and ensure they are plugged into thier respective mates. Look for loose wires. Open up the little black box above the coil and check the relays. See if they click when you try to start. Would need more info to give you more help. Does it try to start, or just turn over and not do a thing. Do you smell gas, etc?
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
verstraelen
PostPosted: Sun May 20, 2007 11:07 am    Post subject: assistance needed stranded 40mi outside las vegas Reply with quote
I am stranded outside vegas, trying to make it into town for repairs.
89 vanagon won't start, turns over but does not fire. was fine last night when I stopped for the night. IF ANYBODY CAN GIVE ME SOME CLUES ON WHAT TO TEST OR LOOK FOR PLEASE CALL MY CELL 505 259 6621.
ANY HELP MUCH APPRECIATED.
thanks.
rudi
