77 westy 2L help
Bleyseng
Bleyseng is offline
PostPosted: Sun Sep 02, 2007 11:07 am    Post subject: Reply with quote
wyomingriviera wrote:
Sounds like when my points go out of adjustment. That sucker'll crank but not start up. It's easy to check anyway...
if it has points check inside the dizzy first
then onto the starter connections.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
wyomingriviera
wyomingriviera is offline
PostPosted: Sun Sep 02, 2007 10:52 am    Post subject: Reply with quote
'77 Rivi 2.0 T2 GD
"I tell you, we are here on Earth to fart around, and don't let anybody tell you different."- Kurt Vonnegut
agreendaya
agreendaya is offline
PostPosted: Sun Sep 02, 2007 9:58 am    Post subject: Reply with quote
Did he jump start it? I know it says in my Idiot guide & chiltons that if you jump it, the computer may die...
Good luck.
NUKETROOP
NUKETROOP is offline
PostPosted: Sun Sep 02, 2007 9:24 am    Post subject: Reply with quote
Jon,
This is a common issue with FI Buses. Coil wires are very easy to get mixed up. Do you have a bentley's manual? If not, get one immediately. If so, go to the wiring diagram.
Look at your coil. one post will have a "1" and the other is "15". Terminal 4 is the sparkplug wire in the middle.
The Bentleys says this
15 will have three black wires
1 from the fuse holder on the left side of the engine compartment
1 goes to terminal 86c on the double relay
1 goes to the fuse box
(ALSO RED PERTRONIX WIRE)
Terminal 1 has three wires also
1 is green that goes to the condenser (disregard if you have pertronix as the condenser will be gone)
1 is White and goes to pin 1 of the brain
1 is Gray/greenstripe and goes to test point 13 in the central plug
(ALSO BLACK WIRE FOR PERTRONIX)
Los Alamos Nat'l Labs weapons rock. Lawrence Livermore weapons SUCK!
IYA-ATOMIC-YAS
1977 Campmobile w/78 Engine(H-Lifters)
[email protected]
solexes@hotmail.com is offline
PostPosted: Sun Sep 02, 2007 9:05 am    Post subject: Reply with quote
Also - if this is an FI model, check your wires on the starter terminal. Theres a couple there - one feeds the Fuel Pump, another goes to the Dual Relay. I had this problem when a couple of the wires came off. It would crank, but not start.
Ryan
1963 Beetle
busdaddy
busdaddy is offline
PostPosted: Sat Sep 01, 2007 4:16 pm    Post subject: Reply with quote
Welcome Jon,
Did you do anything to the points?, is the coil getting current when you crank?
Get your hands on a test light or better yet a multimeter and start testing.
Слава Україні!
suttwhat?
suttwhat? is offline
PostPosted: Sat Sep 01, 2007 3:35 pm    Post subject: 77 westy 2L help Reply with quote
i have a 77 westy that all of a sudden would not crank, the AAA guy did some stuff and now it cranks and magically now will not start even if it does crank, i have not had this problem before. i have checked alot, i have new rotor and cap, swapped the coil out and it did work when i got it. and checked if any of my terminals or connections were loose. i cannot get any spark out of the coil , would someone please throw me some advise? thanks for your time! - jon
