magician Samba Member
Joined: February 20, 2007 Posts: 95 Location: Seattle, WA
Posted: Mon Dec 17, 2007 7:24 pm Post subject: |
| Quote: |
| switch the gearset at the back of tranny from a 3 gear set to a 2 gear set, |
Where could I find a 2-gear set for the Passat/A4/A6? Oh also which years? thx! _________________ 04 R32 | 85 Cabrio | 79 Rabbit | 91 T3 Carat Auto
'00 Jetta TDI (sold)| 91 Cabrio (sold) | 81 Rabbit diesel (sold)| 87 T3 GL (sold) | 91 T3 Carat 4sp (sold) |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2987 Location: Issaquah, WA
Posted: Mon Dec 17, 2007 5:29 pm Post subject: |
The 4 speed Type 097 automatic doesn't have anything in common with the earlier 3 speed unit. So unfortunately it isn't compatible with the final drive of the 3 speed. You can use the automatic section of an Audi 5000 turbo tranny, but that is still a 3 speed with the exact same ratios. The only advantage here is stronger internals.
The other thing to keep in mind about the 4 speed and the later ZF trannys that Audi used is that they are all computer controlled rather than governer controlled. That means even if you could physically mount it, you'd have to have an engine that could supply the appropriate signals to make the tranny work.
Interestingly, it is possible to get a 5 speed automatic from a late model Passat/A4/A6 to work. You have to switch the gearset at the back of tranny from a 3 gear set to a 2 gear set, but that will get the drive flanges turning in the correct direction. Same problem with the electronic controls though. This would be a great conversion for someone updating to the matching 1.8T or Audi V6 that goes with the transmission.
David |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Mon Dec 17, 2007 3:33 pm Post subject: |
that would be a nice modification if its possible. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
motorcity_rob Samba Member
Joined: December 06, 2007 Posts: 4 Location: Detroit, MI
Posted: Mon Dec 17, 2007 3:32 pm Post subject: 4 speed automatic? |
Hi All, I have a venerable 3 speed auto in my 89'. But I'm looking to replace it with a 4 speed automatic. I've read that people have used Audi 5000, 4 speed auto's bolted onto the final drive of the 3 speed. But has anyone out there acutally done this or seen it in a van? (what year Audi has these transmissions?)
How about a Porsche transmission? Thanks for any insight......... |
