thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Thu Feb 17, 2011 12:29 pm Post subject: |
Would it be possible to get the photo links working again? From what I remember they were very helpful and detailed.
I'm adding this to Ratwells Baywindow FAQ topic too. _________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Randy in Maine Samba Member
Posted: Fri Jan 18, 2008 1:07 pm Post subject: |
Now if I just had a doublecab pickup....... |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52887 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jan 18, 2008 6:40 am Post subject: |
Good to know, thanks for the warning. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8731 Location: Victoria, BC
Posted: Fri Jan 18, 2008 2:15 am Post subject: Reproduction Fuel Filler Neck |
I've been out of touch for some time so this may be old news but it's an important issue and here's my take on it:
I've been searching for a 74-79 pickup specific fuel filler neck for a while. The pickup filler neck is a different shape because the filler pipe is different to accommodate the body shape and position of the tank.
While searching I came across a euro vendor who reproduced their own bus filler neck and said it fits both bus and pickup bodies. I'm not sure if this was intended or if the flexibility of the rubber allowed it to bend to match the pickup profile. Naturally curious, I had to get one and check it out.
Unfortunately it is not a very good reproduction. Besides the stinky chinese smelling rubber typical of lower quality reproductions the dimensions are way off:
I measured these differences:
- smaller flange by 7mm (the screw holes are also 5mm closer together)
- the length after the bend in the neck is 15mm shorter.
- the opening is smaller (no big deal for unleaded pumps) but the pipe end of the neck is also smaller by a few mm.
It's as if it had shrunk during/after the molding process.
As a side of effect of contacting as many US vendors as I could trying to obtain it, I think the discovery of this repro has resulted in the import of it into their catalogs.
Apart from the fit issues, I don't think the rubber quality is good enough to last especially under the extra stress of stretching and I predict you'll be changing the fuel filler neck again much to your displeasure.
The fuel filler neck in the left side of the photos is the best available and came from Bus Boys and I'm sure is available at other vendors still. Before ordering a fuel filler neck I'd verify you are getting the best one. _________________ '78 Westfalia CDN
'76 Doublecab Sweden
Read the Baywindow FAQ |
