Help With Spring Plates
johneliot
johneliot is offline
PostPosted: Sat Apr 12, 2008 8:43 pm    Post subject: Reply with quote
I would hazard a guess that those bushings haven't seen the light of day for 35+ years. You have already done the hard work, why would you want to put the old one back in? No matter how you turn it, it's still out of round from all the banging of the torsion bar. Put a new one on the inside and outside. It's cheap.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=311511246
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111511245E
John
John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost"
brunowren
brunowren is offline
PostPosted: Sat Apr 12, 2008 5:14 pm    Post subject: Reply with quote
K got them off.. now another question .. the rubber on the inside is MOLDED with indentions that fit into the carrier... can this rubber be pried off and adjusted (turned to fit flush in the carrier again)
Bashr52
Bashr52 is offline
PostPosted: Sat Apr 12, 2008 2:31 pm    Post subject: Reply with quote
You need to have the trailing arm and shock unbolted to do this. It is rather fun on 69's as they have the double spring plates, but I have done two of them and they arnt so bad, just a PITA.
There is a cap pressed into the end of the spring plates, if you were to remove it then you would see the splines. They are just covered.
bnam
bnam is offline
PostPosted: Sat Apr 12, 2008 9:48 am    Post subject: Re: Help With Spring Plates Reply with quote
brunowren wrote:
Ok So I go to lower the rear of my 69, I have read the stickies on lowering. So I take of the spring plate caps and I see this.... Other pics I have seen show the notches etc... Am I missing something here.. And it seems like the plate is welded to the tube
Yes, that is how it should be on the IRS suspension. The end cap on the torsion bar is welded to the spring plate.
B
Cusser
Cusser is offline
PostPosted: Sat Apr 12, 2008 9:38 am    Post subject: Reply with quote
Re-read all the stuff, and consult a manual. The spring plate, with that tube, needs to be unbolted, then lifted/raised/pulled outward. I haven't done this in years, rather difficult the first time to explain.
brunowren
PostPosted: Sat Apr 12, 2008 9:11 am    Post subject: Help With Spring Plates Reply with quote
