shifting help.
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Tue Apr 22, 2008 1:28 pm    Post subject: Reply with quote
Widefiveguy wrote:
pre 63 the shifters are straight i believe.
For future reference, in late August of 59. the shifter was changed from straight to bent. Also, the position on the floor that the shifter pivots was moved farther forward.
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
jroymcd
jroymcd is offline
PostPosted: Tue Apr 22, 2008 1:00 pm    Post subject: Reply with quote
got it shifting smooth. Freind loaned me another stock shifter to see if it would work and it took care of the problem. Cool
www.cultwagen.com
jroymcd
jroymcd is offline
PostPosted: Tue Apr 22, 2008 9:29 am    Post subject: Reply with quote
should there have been a lockout plate on the berg? there was but I thougth one did not need to be there.
www.cultwagen.com
Widefiveguy
Widefiveguy is offline
PostPosted: Tue Apr 22, 2008 8:42 am    Post subject: Reply with quote
More than likely you got a shifter from a later bus. Is it bent? if it is then it is not for your bus. pre 63 the shifters are straight i believe. Well the are on mine. Ive had a 67 and it was bent, so is the 66 i have.
Eric
360 gt: USTrucker
1965 Beetle
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
jroymcd
jroymcd is offline
PostPosted: Tue Apr 22, 2008 7:22 am    Post subject: shifting help. Reply with quote
Have a berg did not really like it. Got a stock shifter to see if I would like it better. installed it and I cant get it to push down for reverse and its not very smooth.
Its a 60 single so it has the shift rod guide not the bushing. It has the shift rod with the slit in it.
what am I doing wrong? could I have the wrong shifter? would else could it be?
www.cultwagen.com
