rontv Samba Member
Posted: Thu Jul 09, 2020 3:32 pm Post subject: Re: B-pillar wiring access |
@IdahoDoug
I'm referring to the B-pillar |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Tue Jul 07, 2020 9:58 pm Post subject: Re: B-pillar wiring access |
Ron - which pillar? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
rontv Samba Member
Posted: Tue Jul 07, 2020 1:06 pm Post subject: Re: B-pillar wiring access |
Hi All
i know its an old post but still to get some feedback
I managed the get the fishwife through all the way up / or down so i can pull the actual air through
But i was wondering what did you guy do for attachment of the wire.
You just let it hang loose in the pillar?
quite curious
Ron |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1350 Location: PNW - its a dry rain.
Posted: Wed Nov 09, 2016 6:46 am Post subject: Re: B-pillar wiring access |
I am using a snake in the b-pillar but do have a couple wires to run in the a-pillar.
I can confirm that I have successfully pulled a small ish 3/8"-1/2" shrink wrapped bundle "up and through" the b-pillar. The geometry of the hole is such that I could not pull it down from the top. I entered through the front facing hole. It seems that the rear facing hole does not access the same hole at the channel. Can anyone confirm this?
I created my fish tape using some SS wire that I folded in half and then twisted with my drill. It worked 100x better than my traditional flat fish tape real as it could bend easily in all directions. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Merian Samba Member
Posted: Tue Nov 08, 2016 4:53 pm Post subject: Re: B-pillar wiring access |
but I'd still like ot see the pics of that "A" pillar opening... _________________ .... |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10385 Location: Orbiting San Diego
Posted: Tue Nov 08, 2016 3:27 pm Post subject: Re: B-pillar wiring access |
It reads like he's asking about the "B" pillar, not the "A" pillar.
rmcd wrote: |
...Plan A was to fish through the existing hole at the top of the channel into the b-pillar and down to the driver side battery box- as described in this thread. Unfortunately the hole isn't big enough... |
0cean Samba Member
Joined: February 29, 2012 Posts: 1153 Location: California
Posted: Tue Nov 08, 2016 2:36 pm Post subject: Re: B-pillar wiring access |
Gnarlodious wrote: |
rmcd wrote: |
I need to run a 7/8" + bundle of wires from the area near the mirror. down to the drivers side battery area |
Not a chance. The upper corner of the A pillar has a small hole that may pass a few #16 wires but not the diameter you are talking about. You may be able to drill an access hole with a hole cutter and get more room, if you don’t mind altering the strength of that corner. You can also take out the headliner and shove wires through the crack just under the tintop. I ran a #14 zip wire that way to an outlat at the mirror. |
It maybe possible if you use a wire snake and then pull it though. I have a lot of wire in the A pillar, yet it is a small opening. I will post some picks of the A pillar with it opened up a little later tonight or tomorrow. _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3) |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2404 Location: Bonners Ferry Idaho
Posted: Tue Nov 08, 2016 5:44 am Post subject: Re: B-pillar wiring access |
rmcd wrote: |
Not a chance. The upper corner of the A pillar has a small hole that may pass a few #16 wires but not the diameter you are talking about. You may be able to drill an access hole with a hole cutter and get more room, if you don’t mind altering the strength of that corner. You can also take out the headliner and shove wires through the crack just under the tintop. I ran a #14 zip wire that way to an outlat at the mirror. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
rmcd Samba Member
Posted: Mon Nov 07, 2016 8:43 pm Post subject: Re: B-pillar wiring access |
I have an overhead console and I need to run a lot of wires from the area near the mirror. Long story to be covered in my build but for now I need ideas as I've run into a wall.
I need to run a 7/8" + bundle of wires down to the drivers side battery area. Some of these will Continue on to sensors and such in the engine bay.
Plan A was to fish through the existing hole at the top of the channel into the b-pillar and down to the driver side battery box- as described in this thread. Unfortunately the hole isn't big enough. I will have an exact measurement later for history but it is less than 1/2" in diameter.
Any ideas how to do this?
Plan A.2. Is to try to use a whole bit and long flexible drive but I'm thing this will not work.
Thanks. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
lovedavdubs Samba Member
Joined: April 30, 2004 Posts: 1597 Location: New York, NY.
Posted: Thu May 08, 2008 4:34 am Post subject: |
rumitcu wrote: |
Finally got it! I tried using my new fish tape reel, but I wasn't able to get it into the B-pillar like I was with the 14/2 wiring. Eventually, I was able to fish a 2 foot piece of 14/2 wiring down into the B-pillar with a piece of string attached to it. Once the wiring made it down into the B-pillar, I used one of those long, remote claw picker up things to grab the wiring from half way up the B-pillar. I also used a small mirror to look up the B-pillar from the exhaust vent hole. Definitely a pain, but it's done now!
Pat |
Congrats! _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
rumitcu Samba Member
Joined: February 12, 2008 Posts: 97 Location: Boulder, CO
Posted: Sat May 03, 2008 8:03 am Post subject: |
Pat _________________ 85 Westy with Bostig V2.0 & private beta turbo
Boulder, CO |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Wed Apr 30, 2008 1:25 pm Post subject: |
lovedavdubs wrote: |
rumitcu wrote: |
Sweet, let me try that... |
Just be patient. It takes a while to get the wires down there. My guess is that the hole in the top of the pillar isn't more than 5/8" diam. it takes some delicate fishing. |
x2. I used a piece of very,very stiff wire (basically bendable rod) to jam down there until I found the opening. Keep trying....I hit it only moments before I was going to give up. _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
Posted: Wed Apr 30, 2008 12:55 pm Post subject: |
I tried using some 14/2 house wiring as an improvised fish-tape, but was only able to get it part way down the B-pillar before my pre-bent curl in the wire caused it to hang up. I think I'm finally going to buy a 25' fish tape and see if that helps. I have had so, so many times that I could have used a real fish tape over the past 10 years, so I think it's finally time to get one! _________________ 85 Westy with Bostig V2.0 & private beta turbo
Boulder, CO |
Posted: Wed Apr 30, 2008 10:36 am Post subject: |
rumitcu wrote: |
Just be patient. It takes a while to get the wires down there. My guess is that the hole in the top of the pillar isn't more than 5/8" diam. it takes some delicate fishing. _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway. |
Posted: Wed Apr 30, 2008 10:31 am Post subject: |
Sweet, let me try that... _________________ 85 Westy with Bostig V2.0 & private beta turbo
Boulder, CO |
Posted: Wed Apr 30, 2008 10:28 am Post subject: |
rumitcu wrote: |
Did you have to drill a hole at the top of the B-pillar also?
I'm not sure how the B-pillar intersects with the top rail. If the intersection is closed, then I will have to drill into the B-pillar, but if it is open, then I can drill into the top rail. The top rail is a little more hidden then the B-pillar access, so I would prefer that location. |
Nope.
the first picture is of the top rial above the B-pillar you can fish your wires down through the top of the B-pillar from the rail. You will however need to drill a hole at the bottom of the pillar to get the wire out as seen in the second picture. Make sure you use grommets on the hole you bring the wire out through. You dont want to fray the coating off and short it out. _________________ 82 Air-cooled Westy (Lola)...My other vehicle is a subway.
Posted: Wed Apr 30, 2008 10:05 am Post subject: |
I'm not sure how the B-pillar intersects with the top rail. If the intersection is closed, then I will have to drill into the B-pillar, but if it is open, then I can drill into the top rail. The top rail is a little more hidden then the B-pillar access, so I would prefer that location. _________________ 85 Westy with Bostig V2.0 & private beta turbo
Boulder, CO |
Posted: Tue Apr 29, 2008 6:26 pm Post subject: |
I did the same with all my wiring. It was nice to finally get it up off the floor. I ran a wire for an ON/OFF indicator light from my gauge cluster up the A-pillar and down the B-pillar to my inverter. The hole in the B-pillar is only about 3/16" in diam. I'm no engineer but I don't thing that will be enough to threaten the structural integrity of the pillar. The wire comes out down inside the sink cabinet completely out of site
I also ran my speaker wires up the passenger side A-pillar and along the ceiling to the back cabinet. It was a bit of a pain in the ass to fish them through but I think the outcome was worth it.
Posted: Tue Apr 29, 2008 2:48 pm Post subject: |
Thanks, Steelhead. I didn't really think there were any holes, and am also planning on using the fresh air vent to help me snake the wires. _________________ 85 Westy with Bostig V2.0 & private beta turbo
Boulder, CO |
Posted: Tue Apr 29, 2008 2:23 pm Post subject: |
Don't know of any pre-existing holes, but when I dropped my headliner and ran wire down the b-pillars I did use the fresh air vent in the door well to help guide and manage the wires. I did drill holes to get to my spare battery, but they were easily hidden. Here's a rheostat I put in the passenger side b-pillar (photo taken through the fresh air vent hole).
