head removal
bugninva
bugninva is offline
PostPosted: Sat Jun 14, 2008 9:30 pm    Post subject: Reply with quote
Russ Wolfe wrote:
I dont think in a bug you can get the head off the studs with it in the car.
you can't... the four bottom studs must be removed so the head can clear the engine bay shelf...
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Jun 14, 2008 8:51 pm    Post subject: Reply with quote
Gary: OK. Ima poop.
bugninva
bugninva is offline
PostPosted: Sat Jun 14, 2008 8:07 pm    Post subject: Reply with quote
if you are looking for easiest, then drop the engine... if you are looking for experience in why you should drop the engine to pull the head, then do it while the engine is installed.... really...drop the engine...
GEX has. Just sayin
itfitz98
itfitz98 is offline
PostPosted: Sat Jun 14, 2008 8:01 pm    Post subject: head removal Reply with quote
is it possible to pull a head with out droppping the motor? Either way I'm ok doing it, but would prefer to leave the motor where she is sitting and not have to drop it although it will probably be 10 times easier. Also, how much to I need to drop the motor and how much to I need to take off it to get to wha tI need to get to? I am looking to make this as easy as possible.
If it was easy anyone could do it!
73 super in honor of my father. Well on her way to pretty.
