Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Wed Sep 27, 2017 1:02 pm Post subject: Re: Injector leaking test |
On a healthy system, "holds pressure" on step #6 would not necessarily mean the FPR is at fault.
That is correct. On a system that is initially holding pressure and not leaking.
But if pressure is held at that point, then there is probably no need to follow the rest of the steps, as if there isn't a leak,
That is correct. There is no need to follow the rest of the steps, if the gauge holds pressure. This would indicate that none of the 5 injectors are leaking.
Test done.
In my particular case, I don't yet have a reason to believe there is a leak, as overall pressure holds even after a few hours I've turned the engine off. So unless I'm mistaken (not unheard of Wink ) I assume the check valves on pump and FPR are ok, as are the injectors.
In your case (hard start, dies on idle) could be a leaky injector. You would want to jump to step #6, to test just the 5 injectors.
Gauge holds pressure, none of the 5 injectors are leaking.
Pressure drops move onto next step.
| raygreenwood wrote: |
Leaving the pump in the mix risks that the pump is leaking backwards....but if that has already been checked its not an issue.
This is the one that will bite you. The pump will be cycled 3 more times during testing. It only takes one bit of debris to hang the check valve open in the pump and your test results are compromised.
I've been bitten in the past by this. If it is not a component I am testing, I remove it from the test and isolate the components that I am testing.
Tcash |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23536 Location: Oklahoma City
Posted: Wed Sep 27, 2017 9:11 am Post subject: Re: Injector leaking test |
| furgo wrote: |
| Tcash wrote: |
Think of it this way. You have 5 injectors and 1 FPR in a line and you don't know which one is leaking. So if the leak stops when you remove the FPR. That is the part that is leaking.
So effectively by pinching the hose off before the FPR, you are removing it from the line. |
Thanks for keeping on the ball.
I think I can see what's happening. The instructions assume there is a leak somewhere. However, I was reading them as a set of steps that can be followed either on a healthy (i.e. confirm it's all good) or a leaky system (i.e. find a leak). This was my misunderstanding.
On a leaky system, step #6 now makes sense to me. Although I would suggest adding the "Does not hold pressure => at least one of the 5 injectors is leaking" bit, or something along those lines.
On a healthy system, "holds pressure" on step #6 would not necessarily mean the FPR is at fault. But if pressure is held at that point, then there is probably no need to follow the rest of the steps, as if there isn't a leak, there isn't particular component to isolate either.
In my particular case, I don't yet have a reason to believe there is a leak, as overall pressure holds even after a few hours I've turned the engine off. So unless I'm mistaken (not unheard of ) I assume the check valves on pump and FPR are ok, as are the injectors. |
The confusion is that in this instance.....we are just checking for actual "leaks"...and not testing for the "effectiveness" of the fuel pressure regulator.
A "leak" test is just a quick test to find out if fuel is actively dribbling from anything. Clamping the FPR and pump out of the system checks just the five injectors. Leaving the pump in the mix risks that the pump is leaking backwards....but if that has already been checked its not an issue.
You can have a fuel pressure regulator left in the loop....and as long as the fuel pressure is marginally lower than its minimum threshold pressure with no vacuum...which is 36 psi-ish....it may not seem to leak at all in a short test where you are just searching for big leaks.
However overnight....or over an hour...it may leak down. The difference between a leak-down test and a leak test is time and intent. Ray |
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Wed Sep 27, 2017 8:38 am Post subject: Re: Injector leaking test |
| Tcash wrote: |
In my particular case, I don't yet have a reason to believe there is a leak, as overall pressure holds even after a few hours I've turned the engine off. So unless I'm mistaken (not unheard of ) I assume the check valves on pump and FPR are ok, as are the injectors. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Tcash Samba Member
Posted: Wed Sep 27, 2017 7:55 am Post subject: Re: Injector leaking test |
| furgo wrote: |
| Tcash wrote: |
Moving on to #6, should the gauge not be placed between the FPR and the clamp?
This is an exercise in the process of elimination. Taking one component out of the picture, one at a time to isolate the faulty component. As long as the fuel gauge is in the section that is being tested. It does not matter where it is installed. |
Right, but if I understood it correctly, in #6 the FPR is not in the section being tested.
The section being tested seems to me to be the injectors only. The FPR is out of that section. Then the possible outcomes would be:
• It does not hold pressure: one of the 5 injectors is leaky
• It does hold pressure: all good
• It does hold pressure: FPR is leaking
|_/___[i]___[i]___[i]___[i]___[i]____[FPR]--------- Leaking but we don't know which one?
|_/___[i]___[i]___[i]___[i]___[i]__/__[FPR] We remove the FPR. No leaks, it must be the FPR leaking.
Make sense?
Tcash |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7869 Location: Santa Cruz
Posted: Tue Sep 26, 2017 10:54 pm Post subject: Re: Injector leaking test |
What an awesome post.
Someone is an L-Jet ninja for sure.. _________________ Bus Motor Build
It does not exist! |
furgo Samba Member
Posted: Tue Sep 26, 2017 10:49 pm Post subject: Re: Injector leaking test |
| Tcash wrote: |
| Tcash wrote: |
| furgo wrote: |
| Otherwise, in the way diagram #6 is right now, the gauge is measuring pressure in a closed circuit between the two clamps, where the FPR is not involved. In this scenario, it should hold pressure. If it didn't, pressure would have been relieved through a leaky injector, correct? |
That is correct. |
which you also confirmed earlier ^^
| Tcash wrote: |
| Holds pressure = FPR leaking - Replace FPR |
^^ That's the part I can't follow in #6 right now: how can holding pressure in the isolated injector section determine that the FPR is leaky?
Again, thanks for all the answers. Really appreciated. I'm not trying to be picky, these instructions are great and I want to make sure I understand them before performing the test! _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Tcash Samba Member
Posted: Tue Sep 26, 2017 4:25 pm Post subject: Re: Injector leaking test |
Then if pressure does not hold (again for a given amount of time, I guess) we can determine that the FPR is leaky.
If pressure does not hold, one of the 5 injectors is the problem. Not the FPR. If pressure holds, it is the FPR.
Not a timed event. The initial Residual pressure test that you performed and failed and #5 are the only timed events.
That is correct.
Also, what's the purpose of the clamp between the fuel pump and the 3/4 rail in this step? Is it to rule out pressure escaping via the pump's check valve?
Yes it is. It takes the fuel pump check valve out of the test. Eliminating the chance of the check valve hanging open resulting in inaccurate test results. |
furgo Samba Member
Posted: Tue Sep 26, 2017 2:43 pm Post subject: Re: Injector leaking test |
Ok, that step makes sense now, thanks.
Moving on to #6, which is the one I'm mostly interested in atm (still unsure if my FPR is working correctly), should the gauge not be placed between the FPR and the clamp?
Also, what's the purpose of the clamp between the fuel pump and the 3/4 rail in this step? Is it to rule out pressure escaping via the pump's check valve? _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Tcash Samba Member
Posted: Tue Sep 26, 2017 1:12 pm Post subject: Re: Injector leaking test |
I can't picture the correlation between the side of the rail behind the pinch point holding pressure and a leaky fuel pump check valve.
I have the gauge in the wrong place on #5
[fuel tank]__________[fuel pump]___________[0 gauge]_______[clamp]
And in the case it all works as expected (i.e. does not hold pressure), where/how is the pressure being relieved?
The check valve in the fuel pump is allowing pressure to return to the fuel tank.
Does the pinch introduce extra pressure that is being then relieved by the FPR opening its valve and returning fuel to the tank?
The pressure is captured between the pinch and the Fuel pump. The FPR is not involved in test #5.
Finally, should "holds pressure" be determined after a given period of time (e.g. 20 minutes) or instantly?
Good question. The pressure should not drop below 14 psi in a 10 minute period of time. |
furgo Samba Member
Posted: Tue Sep 26, 2017 11:53 am Post subject: Re: Injector leaking test |
Awesome, thanks Tcash! Just what I needed to test my fuel rail
I've got a few questions, though. Taking step 5 for instance:
| Tcash wrote: |
5. Pressurize:
Pinch off the Hose between the Fuel Pump / 3-4 Fuel Rail
Holds pressure = fuel pump check valve leaking - Clean check valve and or replace pump |
I can't picture the correlation between the side of the rail behind the pinch point holding pressure and a leaky fuel pump check valve. Would you mind ellaborating?
And in the case it all works as expected (i.e. does not hold pressure), where/how is the pressure being relieved? Does the pinch introduce extra pressure that is being then relieved by the FPR opening its valve and returning fuel to the tank?
Finally, should "holds pressure" be determined after a given period of time (e.g. 20 minutes) or instantly? _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Tcash Samba Member
Posted: Mon Sep 25, 2017 10:32 pm Post subject: Fuel Injection Leak Down Test |
To link to this post copy and paste
| Code: |
| [url=https://www.thesamba.com/vw/forum/viewtopic.php?p=8568753#8568753]Fuel Injection Leak Down Test[/url] |
1. Disconnect the wire (usaully green) from the #1 terminal on the coil that
leads to the distributor. So you do not fry the points and or the coil
during testing, by leaving the ignition switch on. Unplug the CSV (cold
start valve) so it will not open during testing.
2. Connect fuel gauge to test fitting on 3-4 Fuel rail. Or between 3-4 Fuel rail
and Fuel pump hose.
3. Turn the ignition switch to the 1st run postition.
4. It will be necessary to pressurize the fuel system before each of the
following steps. Remove the Air filter and use a chopstick to
open the flap in the AFM (air flow meter) to pressurize the fuel system.
5. Pressurize:
Pinch off the Hose between the 3-4 Fuel Rail / Fuel gauge
Does not hold pressure = fuel pump check valve leaking - Clean check valve and or replace pump
6. Pressurize:
Pinch off the Hose between the FPR (fuel press. regulator) / 1-2 Fuel Rail
7. Pressurize:
Pinch off the Hose between the 1-2 Fuel Rail / CSV (cold start valve)
Holds pressure = 1 or 2 injector leaking - Pull 1-2 injectors and retest for
leaking
8. Pressurize:
Pinch off the Hose between the CSV (cold start valve) / 3-4 Fuel Rail
Holds pressure = CSV leaking - Replace CSV or in warmer climates bypass
CSV
Does not hold pressure = 3 or 4 injector leaking - Pull 3-4 injectors and
retest for leaking
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf
Good luck
Tcash
Randy in Maine Samba Member
Posted: Mon Jun 16, 2008 11:23 am Post subject: |
There are 2 check valves, one if the pump and one in the regulator that can also cause a drop in the residual fuel pressure.
But look at it this way.....if the pressure holds for a day without dropping much, everything is likely to be good. |
RZAR Samba Member
Posted: Mon Jun 16, 2008 11:18 am Post subject: |
| Randy in Maine wrote: |
| I would install my fuel pressure gauge, fire it up, shut if off and watch for the residual pressure. |
But what if the check valve in the fuel pump is bad? |
Posted: Mon Jun 16, 2008 10:11 am Post subject: |
VWLover77 Samba Member
Joined: June 20, 2003 Posts: 1001 Location: North Canton, Ohio
Posted: Mon Jun 16, 2008 9:40 am Post subject: |
Yes. _________________ Don
1978 Westy
1971 Super Beetle Convertible
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world." - J.R.R. Tolkien |
jayknockout Samba Member
Posted: Mon Jun 16, 2008 9:33 am Post subject: Injector leaking test |
Can u test the injecters ion a 2l FI in a bay if they are leaking by getting pressure in the lines (starting fuel pump in afm) and look if they are leaking,
knew that u could do this on the late T25´s to have pressure in the lines and look if the injector is dripping. |
