70 Beetle turn signals not working but hazards do
Mark33563
Mark33563 is offline
PostPosted: Wed Jul 23, 2008 10:26 am    Post subject: Reply with quote
EMPIImp69 wrote:
Thanks Cusser for the info. Yes a few weeks ago they worked fine until I found out this week they stopped working all of a sudden. Do I need to take the turn signal switch out to access the wire in order to test it with the test light or can I track it down in the trunk by the column? thx
You can start by testing the signal on the dash side. I had a similar problem and it turned out to be the wire from the switch where it connects into one of the plastci splices. It had wiggled lose but was still in there. No contact resulted in my problem. Check all the connections, even to the point of sliding them off and then back on a couple of times...start with the easy stuff then work your way into the surgery of dismantling the car.
"That's an ultra-rare Dung Beetle... in reverse, it rolls up giant balls of crap. " - Dave24
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Gallery Classifieds Feedback
EMPIImp69
EMPIImp69 is offline
PostPosted: Wed Jul 23, 2008 7:50 am    Post subject: Reply with quote
1963 Ragtop Bug
1966 Vert Bug
Check out my ads, Thanks!
Cusser
Cusser is offline
PostPosted: Wed Jul 23, 2008 7:09 am    Post subject: Re: 70 Beetle turn signals not working but hazards do Reply with quote
EMPIImp69 wrote:
what would cause the turn signals on my 70 Beetle not to work?, but yet the hazards do work.
Different parts of the flasher are involved, even though the same lights are used.
You need to use a 12 volt test light or voltmeter to check to see if voltage is getting to the turn signal switch with key "on" (the test light should flash like a turn signal). The turn signal switch merely routes the voltage to either the left or right side, you could test that if you get voltage to the switch by moving the lever with key "on". Did both sides go out at once, what is the history?
EMPIImp69
PostPosted: Wed Jul 23, 2008 6:55 am    Post subject: 70 Beetle turn signals not working but hazards do Reply with quote
Hi guys what would cause the turn signals on my 70 Beetle not to work?, but yet the hazards do work. Could it be the turn signal switch? The hazard switch seems to work fine and all 4 flashers work like they are supposed to. Thanks for help
1963 Ragtop Bug
1966 Vert Bug
