Soul Built Pimpin' Aint Easy
Posted: Fri Aug 08, 2008 7:34 am Post subject: |
Bruce wrote: |
Mainshaft ball bearing. It is adjacent to 4th gear, so that's why the noise is greatest in 4th. |
I agree..........I have been there a few times before |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17620 Location: Left coast, Canada
Posted: Thu Aug 07, 2008 8:53 pm Post subject: |
Mainshaft ball bearing. It is adjacent to 4th gear, so that's why the noise is greatest in 4th. _________________
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36034 Location: Conejo Valley, CA
Posted: Thu Aug 07, 2008 7:56 am Post subject: |
Loose shifter has nothing to do with the noise. Check/replace your front shift rod bushing, and same for the coupler under the rear seat.
Try changing fluid, adding a tube of MoS2 grease halfway thruogh the fill. |
vwmaniaman Samba Member
Joined: June 07, 2005 Posts: 604 Location: Grand Rivers,KY
Posted: Thu Aug 07, 2008 3:35 am Post subject: |
Sounds like the pinion bearing is trying to tell you its time. _________________ Working on a VW is like fun with a friend!
65 Beetle
75 Westy "Pumpkin Van"
86 Westy "Brown Betty"
87 Cabrio |
fastinradford Samba Member
Joined: June 08, 2008 Posts: 2895 Location: Athens Ohio
Posted: Thu Aug 07, 2008 2:21 am Post subject: |
Change the fluid, probably just wearing out, but should last a while longer, unless it gets really really loud, also might be wheel bearings, maybe, |
stixitinya Samba Member
Joined: February 14, 2008 Posts: 84 Location: Norwalk, CA
Posted: Thu Aug 07, 2008 1:30 am Post subject: getting funny noise in third & forth gear >:( |
I've been driving my 65 around and it runs fine but when I shift into third gear I start getting this noise and in forth the noise is a little louder but if I take my foot off the gas pedel the noise will stop and as I go faster the noise will get louder too WEIRD! .I have no clue what that is oh and I can feel a lot of movement when I move the shifter around in any gear. So if anybody knows what this could be please let me know so I can fix this problem this weekend. Thanx |
