payton Samba Member
Joined: February 11, 2002 Posts: 791 Location: naples,florida
Posted: Tue Sep 30, 2008 4:35 am Post subject: |
| Where are you in South Florida. There are some decent buses around with minimal rust. I agree to look for a west coast dry bus before going out of the country. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4778 Location: Arizona Highways
Posted: Mon Sep 29, 2008 7:01 pm Post subject: |
if you're willing to fly to cosa rica to look @ a bus, you should check out the sunny, dry southwest (rubber is MUCH easier and cheaper to replace). the only cancer you'll find out here is under the battery. _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
babysnakes Samba Member
Posted: Mon Sep 29, 2008 6:44 pm Post subject: |
| Sellers post back up. Mexican case W/single port. |
Posted: Mon Sep 29, 2008 3:52 pm Post subject: |
Yeah well.. I decided to walk on this one before I got your replies. Thanks though. You backed up my decision.All I had to do was re-read my post after it was posted. Anyway I flew to Costa Rica where the bus was located. I needed a vacation anyway(got a good deal on airfare)so I figured if the bus was a bust,( because I asked for 20 some odd photos and pixels only go so far) I would have a blast in CR and lose no sleep. Back to the hunt!!
Thank you everyone. |
c4l3b Samba Member
Joined: August 15, 2007 Posts: 467 Location: Springfield Missouri
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53181 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Sep 29, 2008 7:37 am Post subject: |
Some detailed pics are needed here, I've seen a couple of busses with the parts you describe welded on, but there was absolutely no structure remaining underneath, they only installed the outer skins , looked good from the outside but awful from underneath. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Mon Sep 29, 2008 7:29 am Post subject: |
Have you ever done rust repair before.
"cancer" Can be one of the hardest things to repair right, finding and getting all of it is the problem.
If you happen to find it all, you had better repair it right the first time,
Or it will start to rust again in short order.
It sounds like you would also have to fix someone elses bad repair, you won't know how bad a job they did till you tear into it.
I would walk on this one if I was you.
I will never buy another rust bucket, with the intent of fixing it, I have the option now since I live in Texas.
The secreat to buying an old car is the body, as long as it's straight, and rust free, everything else can be bolted on.
Socket wrench has alot less of a learning curve then a mig welder does. |
jah_B Samba Member
Joined: March 18, 2008 Posts: 1147 Location: Tempe, AZ
Posted: Mon Sep 29, 2008 7:06 am Post subject: |
Sounds not so great. PIK CHERS  _________________ 1984 CABRIOLET 6spd, quaife diff, Neuspeed springs, sway bars, tie bar, short shift kit, bilstein shocks, 16X7 RSE 3pc wheels, BFG TA 205 40s
1972 tintop P30 CAMPMOBILE: M/T, 1.7L, dual kadrons, 019 diz. Sunny the S'kool Bus
You gotta know what you don't know. That's the key to wisdom. man. |
Posted: Mon Sep 29, 2008 5:05 am Post subject: VW Dilemma |
| OK babysnakes here. After a wealth of knowlegable advice. I finally got a look in person at my 69 Bus. Now I am asking for ya'll to give me your opinions. In Florida everything old is a rustbucket so it is impossible to find something. So this is what I found on this bus.1)lower doglegs have been replaced 2) doors stay 1/4" outside body when closed. 3)rust repaired well in corners of front window,lower front apron,rear left corner under driprail. 4) Battery tray 5) a patch under passenger seat . It will cost me $3000. I think this is a bit much. Its so stinkin hard to judge a bus by the pixel. Ive looked @ a bunch of advertised buses,t-3s and am constantly let down. Maybe I'm being picky or is this a reasonable price. |
