Jetting advise based in AFR readings
Scott Novak
Scott Novak is offline
PostPosted: Wed Feb 11, 2009 12:28 am    Post subject: Reply with quote
What are the float settings?
Is it just me or does anyone else think that the 28 mm venturis seem a little small for a 1912cc engine?
Scott Novak
Bruce
Bruce is offline
PostPosted: Wed Feb 11, 2009 12:11 am    Post subject: Reply with quote
You should measure the diameter of your idle jets. There's no way a 45 should produce an A/F ratio of 10.5:1
74driver
74driver is offline
PostPosted: Tue Feb 10, 2009 10:40 pm    Post subject: Reply with quote
Follow Johns advice from aircooled.n*t. He has probably forgotten more about vw jetting than you or I will ever learn.
Luftgekült
Luftgekült is offline
PostPosted: Tue Feb 10, 2009 3:12 pm    Post subject: Reply with quote
Please help Pray
After I figure out the jetting I going to take the car to the dyno, then change to 44IDF and post the results.
One thing I forgot is that I am using an Empi GT exhaust which I believe is seriously reducing engine's performance. Waiting for a CSP supersport to arrive...
'71 VW 1302 1300cc in progress....
'72 VW 1302S 2109cc
'84 Passat Variant GL 1.6TD
Luftgekült
PostPosted: Tue Feb 10, 2009 9:14 am    Post subject: Reply with quote
Thanks for the replies,
well, I made new tests.
Fuel pressure is 3 psi. Stock fuel pump with pressure regulator.
Floats set.
Tests made in 3rd gear, full throttle, steep slope.
I changed to:
115 mains
45 idles
185 airs
My AFR readings are a bit better.
Idle --> AFR 13,5 Screws 1,5 turs out
1000-1800 rpm --> 12
2000 rpm --> 10.5
2500 - 3000 rpm --> 13.5
3500 rpm --> 12.5
5000 rpm --> 15
It starts to lean from 3500 till the end, reaching +15:1 at 5000rpm. I have to try smaller airs but not sure of how many sizes do I have to down.
I have another issue with a rich condition at 2000rpm. Looks like a rich progression from idles to mains. I can't go leaner on idles because 45 is the smaller size, I believe.
It has F11 emulsion tubes. I have a set of F7s, would it make any difference?
My other questión is about accelator pump. If I stomp on the gas the engine reponds well (instant rich condition, AFR arround 11:1) but I does not respond well to slight changes (16 to 20 AFR) How can I fix that?
'72 VW 1302S 2109cc
[email protected]
john@aircooled.net is offline
PostPosted: Tue Jan 27, 2009 10:24 am    Post subject: Re: Jetting advise based in AFR readings Reply with quote
next stop
47.5
115
180
John
Aircooled.Net Inc.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Luftgekült
PostPosted: Tue Jan 27, 2009 9:28 am    Post subject: Reply with quote
grimace007 wrote:
just curious but your checking these under a load right?
Yes, I made the measurements on a steep slope in 3rd gear at full throtle
'72 VW 1302S 2109cc
grimace007
grimace007 is offline
PostPosted: Tue Jan 27, 2009 9:17 am    Post subject: Reply with quote
Brian
68 sedan
Dallas Air Coolers
perrib wrote:
Hey It is The Samba where well thought out rational answers can take a while and getting side tracked is normal. I was just lucky this time. Smile
cr@M wrote:
No one has any personal responsibility these days. This country is sue happy. Intelligence is no longer a requirement, just an accessory.
Luftgekült
PostPosted: Tue Jan 27, 2009 8:50 am    Post subject: Reply with quote
Eaallred wrote:
Are these reading ast WOT?
If so, I would start by changing the mains one size smaller. Airs look like they're coming in just fine.
Yes, it was at WOT. I'll try then the 115 mains.
What about idles?, they seem to be too big. I am getting AFR readings of around 10 until 2500rpm
'72 VW 1302S 2109cc
Eaallred
Eaallred is offline
PostPosted: Tue Jan 27, 2009 8:37 am    Post subject: Reply with quote
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
Luftgekült
PostPosted: Tue Jan 27, 2009 8:17 am    Post subject: Jetting advise based in AFR readings Reply with quote
Hi,
I'd noticed a lack of power in my engine below 2500rpm. Thinking in rejeting, I installed a LC-1 wideband. As I suposed the engine is working very rich.
I went from 50's to a set of used 47's idles i had, but it made no change, I would even say that it is going richer.
Here are my engine specs,
1914cc - 40x35 valves - w120 cam - ac net SVDA - 8:1 comp
and carbs'
dual 40IDF - 120 mains - 50 idles - 200 airs - 28 venturis
my AFR readings are roughly
Idle --> 13,5
1000 - 2000 rpm --> 9,8 - 10,5
2500 rpm --> 12,5
3000 rpm --> 12
3500 rpm --> 12
4000 rpm --> 12,5
>4500 rpm --> 12,8 - 13
what jets should I try next??
thanks!!
'72 VW 1302S 2109cc
