BoomsVW Samba Member
Joined: August 04, 2006 Posts: 193 Location: Estacada,Oregon
Posted: Sat Mar 21, 2009 12:19 am Post subject: |
| Quote: |
pretty much the same thing isn't it?
no super beetles have a different front end setup then a standard |
_________________ Trevor AKA "Benny"
1971 Standard Beetle (1600DP)
BoomsVW:THAT SOME SORTA FAT JOKE!!!
vwluver74:cool story bro!
vwluver74: look at those tks. |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9479 Location: Fallbrook, CA
Posted: Fri Mar 20, 2009 11:00 pm Post subject: Re: 73 Super Where to put jack stands on the front end |
| jamesdagg wrote: |
| Pretty much the same spots though isn't it? |
No, a Super doesn't have a front beam like the one in the picture. Follow what perrib said, place the jack stands on the outer front corners of the pan.
-jeffrey _________________ Der Kleiner Kampfwagens |
MrUnix Samba Member
Joined: March 04, 2009 Posts: 346 Location: N. Central Florida
Posted: Fri Mar 20, 2009 5:49 pm Post subject: Re: 73 Super Where to put jack stands on the front end |
| perrib wrote: |
| From his signature line I think he has a Super Beetle. |
Umm, the title of the post might have given it away as well
I use the front sway bar mounts.. got mine up in the air right now with cement blocks and some foot long 2x8's up front, jack stands in back.
(same vehicle - a '73 super).
Cheers,
Brad |
perrib Samba Member
Joined: September 14, 2004 Posts: 3402 Location: Chandler, Az
Posted: Fri Mar 20, 2009 3:49 pm Post subject: Re: 73 Super Where to put jack stands on the front end |
| jamesdagg wrote: |
| perrib wrote: |
jim |
The center of the front super pan is strong but i don't like the tripod style of three jack stands. It is not as safe as 4 stands. |
MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1813 Location: Warm and sunny coastal CT
Posted: Fri Mar 20, 2009 2:59 pm Post subject: |
| perrib wrote: |
| The strongest spot on each side is were the corner of the front of body bolts to the pan. |
x2
What perrib said. _________________ Greg
Model Citizen
| johnnypan wrote: |
| I digitize myself in the privacy of my own home. |
jamesdagg Samba Member
Joined: August 18, 2007 Posts: 3364 Location: B.C.Canada
Posted: Fri Mar 20, 2009 2:57 pm Post subject: Re: 73 Super Where to put jack stands on the front end |
| perrib wrote: |
jim _________________ '72 FI Westy
'71 Super rear inside defrost vents no longer available |
perrib Samba Member
Posted: Fri Mar 20, 2009 2:40 pm Post subject: Re: 73 Super Where to put jack stands on the front end |
Posted: Fri Mar 20, 2009 2:33 pm Post subject: |
perrib Samba Member
Posted: Fri Mar 20, 2009 1:53 pm Post subject: |
SophieDaBus Samba Member
Joined: March 20, 2008 Posts: 45 Location: Olympia, WA
Posted: Fri Mar 20, 2009 1:32 pm Post subject: 73 Super Where to put jack stands on the front end |
I know this may sound stupid, but I don't want to hurt my car, or become a pancake.
Where do I put jack stands on the front of my bug? I'm replacing Tie rod ends today, and I only have rear jack points, so I'm curious about where in the front is a safe place to put the stands.
Thanks for your help! _________________ '71 Transporter 1600 Upright: "Walter"
'72 Pop-top Westy, 1700 Dual Carb Pancake: "Sophie"
'73 Super Beetle, 1600 Upright: "Zoe"- Sold
"you can't go wrong getting a bus... you will only stop being normal" -Stolen from someone, but I don't remember who =) |
