Dogpilot Samba Member
Posted: Tue Jun 02, 2009 3:26 pm Post subject: |
We have signs all over Arizona at the steep grades telling you to turn your AC off. Wonder if that was meant for the Vanagons only? _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Tue Jun 02, 2009 3:25 pm Post subject: |
| funagon wrote: |
| Andrew A. Libby wrote: |
You could add a switch to deactivate the compressor clutch under full throttle.
Andrew |
I don't know if you were just being funny but that sounds like a great idea to me. |
Its pretty common on a lot of newer cars to have the compressor disengage under full throttle. Seems like it might be pretty easy to rig something up for a vanagon. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
Posted: Tue Jun 02, 2009 3:24 pm Post subject: |
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
funagon Samba Member
Posted: Tue Jun 02, 2009 3:20 pm Post subject: |
Andrew |
I don't know if you were just being funny but that sounds like a great idea to me. _________________ 1990 GL 7-passenger
2.2 liter WBX |
weatherbill Samba Member
Posted: Tue Jun 02, 2009 1:50 am Post subject: |
| thanx. I didn't know if that was normal or not. |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10146 Location: Where?
Posted: Mon Jun 01, 2009 6:40 pm Post subject: |
Andrew |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10874 Location: Western WA
Posted: Mon Jun 01, 2009 6:39 pm Post subject: |
| son1caaron wrote: |
| I think loosing power while using the AC is pretty standard. Your engine only puts out so much power and when you turn the AC on it has to power the compressor as well so there isnt as much power available to propel you forward. |
Yes this is true. If it takes 5 hp to run the air conditioning compressor then you have only 85 remaining, and that's at peak RPM 4100.
If you are running at 3000 rpm where you have say,,,,70 HP then the available HP remaining to push the car drops to 65.
The only 'fix' for this is to increase horsepower or change the weather. _________________
....KTMs, GasGas, SPOT mtb |
devesvws Samba Member
Joined: January 05, 2004 Posts: 1540 Location: madison va
son1caaron Samba Member
Joined: May 31, 2008 Posts: 15 Location: Arlington Heights, IL
Posted: Mon Jun 01, 2009 2:35 pm Post subject: |
I think loosing power while using the AC is pretty standard. Your engine only puts out so much power and when you turn the AC on it has to power the compressor as well so there isnt as much power available to propel you forward. _________________ 1987 2wd Westy w/ Ford Zetec Engine
Bostig install group 6
http://www.bostig.com |
Posted: Mon Jun 01, 2009 2:22 pm Post subject: Why loosing power when AC is on |
Why am I loosing power and acceleration when my Air Conditioning is on?
Is there an electrical part getting weak an dneeding replaced?
What can I do to improve this...
might it be a good idea anyways to replace old ignition coil with a high performance one?
has anyone done this? or anyone gone thru this? |
