dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Tue Mar 15, 2016 10:39 pm Post subject: Re: Rear brake cable (better angle re-route bracket) |
Well, the brake is not fully released. There are stronger springs available for this model caliper. Also Biggred.UK has seal kits and the Audi guys have posted full instructions for rebuilding.
Dan |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10639 Location: Western WA
Posted: Tue Mar 15, 2016 5:35 pm Post subject: Re: Rear brake cable (better angle re-route bracket) |
Plated the bracket yellow Zinc. Got some shiny bits, gonna have to clean up the rest now.
View from front looking rearward
Looking forward.
....KTMs, GasGas, SPOT mtb |
Sodo Samba Member
Posted: Wed Feb 10, 2016 11:08 am Post subject: Re: Rear brake cable (better angle re-route bracket) |
A rear pic showing the re-route.
Driver side.
Passenger side. Notice the cable is aimed to pass straight thru the gap between the cooling system tubes and the frame.
Sodo Samba Member
Posted: Sat Jul 11, 2015 6:58 pm Post subject: |
insyncro wrote: |
I make my own cables now after buying pre-made a few times.
IIRC, about $75 per cable when buying pre-made.
About half that when you make them. |
Well my bracket cost much less than even 2x $35, (Free). Not everybody has the tools to make cables. Or welders either. But I posted how I did my mod, pics & how-to, in true Samba DIY spirit!
On that note I bet folks would like to see how you make (or order) brake cables. I would too.
I really like the idea of removing the cable from its housing, to clean & lube it with waterproof lube. Not looking fwd to winter when water in the cable freezes the brake stuck. _________________
insyncro Banned
Posted: Fri Jul 10, 2015 8:42 am Post subject: |
The cable linked above is featured in a thread here...along with its matching lever. |
Sodo Samba Member
Posted: Fri Jul 10, 2015 7:25 am Post subject: |
How much do custom cables cost? I looked into it, and recall that it wasn't really that simple. Pretty much had to order a cable for a couple hundred $$ and "see if it fits" which was too much risk for me. This was 6 years ago and my foggy memory suggests that I asked on the forum and "nobody" replied or was willing to share a cable spec. So custom cables remained a phantom solution (or perhaps a proprietary solution).
"Two clicks" sounds phantom to me.
Heres one adjustable cable that might work for $125 http://amzn.com/B000CONKC4
Looking back on it I wonder why I didn't just make my own adjustable cable ends for the VW cables, it would be just "easy". And especially useful if they could be disassembled and lubed. There's 20/20 hindsight for ya! Custom cables don't improve upon the cable route. But with active lube, the original route is probably OK.
I suppose a commercially produced re-route adapter might cost $150? The adapter could accommodate disc brake kit spacers for various caliper choices, allowing use of off-the shelf cables. Its a viable product.
It takes time to post this stuff, probably more time than the project. Understood very few will undertake a project like this, even how simple it is but hope my pics and description will help someone, someday. _________________
insyncro Banned
Posted: Fri Jul 10, 2015 5:04 am Post subject: |
Custom cables that adjust at both ends is a very simple solution, no spacers needed and allow for two clicks to fully engage the parking brake. |
Sodo Samba Member
Posted: Thu Jul 09, 2015 3:23 pm Post subject: |
Signalocity wrote: |
You really shouldn't have to do all of this to get the parking break to operate correctly... |
Haha you're right about that! Most people just buy a new F-150, I tried that and it works !!
I worked HARD on my original system, for months if not years, before doing the mod. Wouldn't have done it if I thought it was possible to make it work otherwise (with my disc brake conversion kit).
Never thought to change the springs though, the originals seemed strong. But its feasible that new ones would be stronger.
The cables and tension paths are much straighter now, and it sure FEELS good. The system is much better able to handle dry or aging cables (which may happen over time, like next week! ). Agreed this is a project for someone who wants a project. If you could buy it at VanCafe or something I guarantee you would be happy though. _________________
Signalocity Samba Member
Posted: Thu Jul 09, 2015 2:51 pm Post subject: |
You really shouldn't have to do all of this to get the parking break to operate correctly with the rear disk conversion or otherwise. If your factory plastic routing guides are popping loose, It is likely that your tubing spacers are not the correct length or following the correct routing curve. I had that same issue until I dialed everything in. If your caliper springs are not strong enough to return the cable, you probably need new ones. One of mine was hanging up for that very same reason, on a fresh rebuilt caliper. |
Sodo Samba Member
Posted: Thu Jul 09, 2015 11:14 am Post subject: |
Six years later,,, a mod to the mod.
This has been a good mod, it really cleans up the routing of the long and somewhat troublesome cables. The Disc brakes return spring is barely strong enough to return the Vanagon's long cable contraption. Add poor routing,, tight bends, friction and the weight of the cables it just couldn't do it. With proper routing the springs are OK!
This item is a bolt-on mod, anybody could make this kit. I used riv-nuts for the brace. But the brace could simply be CLAMPED to the frame rail (no drilling).
I have my tranny out and decided to brace up my cable re-route bracket. The relocation created a much better cable route, which firmed up the brake action a lot. Buts since the bracket itself could flex on its mounting, even in better "feel" at the handbrake is available by eliminating more flex.
It DID firm up the handbrake - a little more than 1 inch reduction and it feels TIGHT!
Un-bolting the brace, then pull handbrake, you can see it moved about 4mm under tension.
Here's what the braces look like.
Construction details
Driver side (plastic moved for welding)
Passenger side (plastic moved for welding)
Franklinstower Samba Member
Posted: Mon Oct 12, 2009 9:45 am Post subject: |
Sodo wrote: |
My brakes have since healed 100% ( no more hooop......hoooop......hoooop )
They are Vanagon brake cables, modified a little by Smallcar, who used a 2WD cable on one side. Their 'modification' is to add length to the housing, they used a very hard, thick-wall plastic tube to extend the housing a little, maybe an inch or two.
My housing extender looked like this:
I bet I could make a bracket like yours to eliminate the housing extenders...hmmm _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB |
Sodo Samba Member
Posted: Mon Oct 12, 2009 9:33 am Post subject: |
Andrew A. Libby wrote: |
Sodo wrote: |
Yup ---> can't get the shock bolt out dangit. |
I assume the easy solution is to put the bolt in the other way... |
Yes - do this before installing the caliper. _________________
Sodo Samba Member
Posted: Mon Oct 12, 2009 9:24 am Post subject: |
When you make the new bracket, make it strong. It has to withstand as hard as you pull on the brake lever. I would consider a brace forward to counteract the cable tension. Mine has no brace, and it feels stout....but if I had the thing up on a lift ( ) I would do it stouter......... because I think the brake would then feel more positive.
When a handbrake has a solid, positive 'feel', I just feel better about parking on a hill for example. The vanagon drum brake does NOT have that feel, and I was hoping to get a more positive e-brake adding the rear discs. They are better, but did not provide the 'positive' feel I was hoping for. The new bracket helped a lot, but possibly a brace (and optimum angles) could help even more.
Smallcar, Van Cafe, any of these crafty folks (with their lift, and their skillz) could make this part easily and get all the angles right, and could probably sell one with every disc brake kit. _________________
iceracer Samba Member
Joined: February 28, 2006 Posts: 981 Location: Milwaukee, Wisconsin
Posted: Mon Oct 12, 2009 9:16 am Post subject: |
I like your rust free undercarriage. _________________ 86 Syncro Wolfsburg edition
63 Beetle (The Iceracer) |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10017 Location: Where?
Posted: Mon Oct 12, 2009 9:09 am Post subject: |
Sodo wrote: |
Posted: Mon Oct 12, 2009 8:44 am Post subject: |
Tom,
I get a similar brake grabing issue and noise too with my rear discs. They are not the small car version, rather the jeff (A914622) Ford Taurus Version.
The hand brake cable had to be modified too, but like you say, I think the angle of the cable completly sucks. I will try your mod and see if that gives some relief.
Do you use the stock VW cable with that Small Car Rear Disc ?
Thanks for the post!
paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
YITB |
Sodo Samba Member
Posted: Mon Oct 12, 2009 8:20 am Post subject: |
Yup ---> can't get the shock bolt out dangit. _________________
hiram6 Samba Member
Joined: September 29, 2006 Posts: 1880 Location: Beautiful South
Posted: Mon Oct 12, 2009 6:56 am Post subject: |
Loos to me like the caliper blocks removal of the shock bolt? If you turned it around so the nut is on the open side, it might work.
Picture could be deceptive though, that may not be the mystery problem. _________________ 1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18760 Location: Retired South Florida
Posted: Mon Oct 12, 2009 6:46 am Post subject: |
Looks like you had to notch the shock brackets for the cable to align with the caliper? |
Sodo Samba Member
Posted: Sun Oct 11, 2009 11:29 am Post subject: |
Yes one of the angles is 'worse' than the other. As it is, the brake action is noticeable improvement in the clicks and ease of use of the e-brake, it sounds more like a normal car e-brake.
But I can't say whether my angles are the "best", just certainly better. A guy who has a LIFT could do a better job, and get better pictures too. I did it on wheel ramps, and there's not really enough room between the car and the ground to see the angles properly, and end up with the best angles for "tension and loose".
Here is another rear disc brake problem I ran across recently. Not a big problem, but one that ANYONE in the midst of a rear disc install can solve easily during the project.
OK who can spot the problem? (no cheating!!!!)
