New Cam Same Lifters
norcalmike
norcalmike is offline
PostPosted: Wed Sep 02, 2009 3:25 am    Post subject: Reply with quote
if you run a used cam with new lifters, do you have to break in the cam again?
Matthew
Matthew is offline
PostPosted: Tue Sep 01, 2009 3:28 pm    Post subject: Reply with quote
You can run a used cam with new lifters, but you should never put a new cam with used lifters. You may get lucky and get away with it, but it is considered bad practice. Worst case scenario is the lifters fail, the cam goes flat and the builder gets to do the job again the right way.
1965 Beetle sedan
Click to view image
sbeetle79
sbeetle79 is offline
PostPosted: Tue Sep 01, 2009 2:36 pm    Post subject: New Cam Same Lifters Reply with quote
So I had a oil pump failure and took the engine to a builder to check it out. Of course he replaced the pump and the cam, but I question if he replaced the lifters. What will be the result if he did not? Can lifters with under 10,000 miles be reused? I thought lifters when they are flat tappets are replaced with the cam.
