need help with removing the doghouse
scratchs68
scratchs68 is offline
PostPosted: Sat Nov 14, 2009 5:57 pm    Post subject: Reply with quote
well it worked like a charm. i ordered a new thermostat today since i have it apart.
scratchs68
PostPosted: Wed Nov 11, 2009 8:12 pm    Post subject: Reply with quote
thanks to everyone for the help. i'm hoping to get to it this weekend. thanks again.
74Pepper
74Pepper is offline
PostPosted: Wed Nov 11, 2009 4:01 pm    Post subject: Reply with quote
Hope this isn't too late...better to say, the thermostat screws into the rod. You can't turn the rod while it's connected to the flaps. Un-do the bolt that holds the thermostat to the bracket, then unscrew the thermostat from the rod. Smile
'66 Beetle, in restoration
'74 Ghia, in restoration
'77 Westfalia Campmobile - Dangit - rear-ended! Now has primer-butt!
Per Gary, A.K.A. "Purple dress girl")
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Nov 11, 2009 5:20 am    Post subject: Reply with quote
It just screws in.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
scratchs68
PostPosted: Wed Nov 11, 2009 4:51 am    Post subject: Reply with quote
how does the rod attach to the thremostat. does it just unscrew? the pic's are great thank you for your time.scott
Cusser
Cusser is offline
PostPosted: Wed Nov 11, 2009 2:56 am    Post subject: Reply with quote
I've removed shrouds about 10 times without dropping the engine; for me this would be the easiest way, and I've R&R'd over 100 VW engines. Yes, I've removed the hood and the spring. I've never found the spring hard to re-install, I just grapped it with a vise-grip.
74vwbuglove
74vwbuglove is offline
PostPosted: Tue Nov 10, 2009 9:43 pm    Post subject: Reply with quote
those pics would have helped me out so much about a week ago!
if you're taking the fan shroud off my suggestion is to drop the engine, i tried to do it with the engine on the car (keep in mind i have a baja, so i have almost no sheet metal around the engine) and just couldn't quite get the angle right. dropping the engine is easy, all you need is some 2x4 a skateboard and to remove 4 bolts, the accelerator cable, the fuel pipe and some wiring.
youll thank yourself for doing it.
webwalker
webwalker is offline
PostPosted: Tue Nov 10, 2009 7:31 pm    Post subject: Reply with quote
there's where the rod would be:
And there is where it goes between the cylinders.
and there is where it attaches.
"Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image
scratchs68
PostPosted: Tue Nov 10, 2009 7:27 pm    Post subject: Reply with quote
i removed the tin around the thremostat to take a closer look. now you say unscrew it from what rod? do you have a pic of this rod placement? Thank you for your help.
webwalker
PostPosted: Tue Nov 10, 2009 7:11 pm    Post subject: Reply with quote
then yes, you are likely hanging up on the thermostat on the right side. A rod goes down between the cylinders to the 'stat. So unbolt the 'stat from its bracket (DON"T unbolt the bracket from the case) and unscrew it from the rod. Then you should be able to lift the whole fan shroud out in one piece, assuming you've cleared all of the other fasteners.
A 68 is a dandy Beetle to get started on if it is not rusty. Bought my 68 in 1991, pimped it up and sold it for enough to pay for my first term at college. I would not do to a car again what I did to this one. But its simplicity saved me from a lot of trouble. The only suggestion I can make to you is to relax and BE HAPPY with the power you have, rather than wishing for more.
M
Click to view image
scratchs68
PostPosted: Tue Nov 10, 2009 7:04 pm    Post subject: Reply with quote
its a 68 sedan stock not auto stick. and the fan shroud is what i'm referring to.
webwalker
PostPosted: Tue Nov 10, 2009 7:00 pm    Post subject: Reply with quote
By doghouse do you mean the small tin at the front (front is front) of the fan shroud...or do you mean the fan shroud itself? What year engine are you working on?
Look underneath on the right side and see if the thermostat is still connected. Accordion thingy.
You probably shouldn't be taking this apart if you don't know what you're doing. Stop. Get the Bentley book for your car. Read. Then start again.
In VW parlance, it is a 'case' not a 'block' as it is not a solid piece of metal that has been machined, but rather two halves (like a suitcase) that have been cast and then machined. You can't take apart a block; you merely take things off of it.
Click to view image
Viande
Viande is offline
PostPosted: Tue Nov 10, 2009 6:58 pm    Post subject: Reply with quote
The entire hinge has to be removed to do it in car. You can drop the engine and not fight all that in the same amount of time. Good luck
Bobby
New Items In Stock, NOS & OEM Seals,Parts and Terminals
My Feedback Here
The bitter taste of poor quality lingers long after the joy of the cheap price fades away.
scratchs68
PostPosted: Tue Nov 10, 2009 6:18 pm    Post subject: need help with removing the doghouse Reply with quote
I'm trying to remove the doghouse from my stock engine with out dropping the block. so far i got everythin off except the right side of the housing. It seems to be caught on the hinge. if i reach around the back side of the housing i feel two bolts or screws which seem to be holding it from lifting up and out. the left side(driverside) lifts no prob. My question is if i remove these two items will that do the trip and will the hinge fly out, and i'll never get it back together. I want to remove to inspect, clean or replace oil cooler. this is my first try at working on a air cooled engine. please any help would be great.....thanks scott
