Mysterious noise at startup
DrDarby
DrDarby is offline
PostPosted: Tue Dec 15, 2009 11:44 am    Post subject: Reply with quote
I thought loose cylinder head but the oil light flickering made me think. Many years ago I picked up a 71 beetle that was a travelling salesman's car. It had 185,000 miles and the rebuilt engine had about 75,000 miles on it and I was told it siezed and was parked in the garage where it sat about 8 years. It was three blocks away so I had a friend push me home with his car where I noted the engine was not siezed. An hour or so later I had it running and it ran well. It always knocked badly on cold start and the oil light flickered at hot idle but I was young and figured I'd drive it until it graduated into something worse. After driving it daily for 18 months my Dad retired and took another job about 40 miles away and I gave him the bug and swapped the engine with a low mileage original from a wreck. I split the case on this engine and found one of the main bearings must hae siezed at one time and the dowel pin now fit in a groove so the bearing was actually floating somewhat. I'll never figure out how it never locked up on my in all the miles I drove it as I'm sure some of the time the oil passage must have been closed off.
Midwest Autosavers, Inc. Crystal Lake, IL
dirtkeeper
dirtkeeper is offline
PostPosted: Tue Dec 15, 2009 8:30 am    Post subject: Reply with quote
i have had a similar experience when my carburetor was loose and another time when i had a loose cylinder head. as soon as the engine warmed a bit and expanded it sealed up. usually was loud for more than a few seconds...like a minute or more and it sounded more like an exhaust leak so may be different sound then yours.
Bruce Amacker
Bruce Amacker is offline
PostPosted: Tue Dec 15, 2009 8:15 am    Post subject: Reply with quote
PPS: Try an OEM (Honda) oil filter on your wife's car- many times it makes a big difference in startup noise, as the aftermarket filters may omit the drainback valve.
PPS: An oil analysis from Napa/Wix is a cheap way to see what's wearing out inside your motor. PN 4077, $14.
Good Luck!
Very Happy
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
Cusser
Cusser is offline
PostPosted: Tue Dec 15, 2009 6:59 am    Post subject: Reply with quote
It seems that the VDO twin sender idiot light part is set to turn the idiot light on at an oil pressure lower than the stock sender.
jlex
jlex is offline
PostPosted: Tue Dec 15, 2009 5:38 am    Post subject: Reply with quote
Ditch the straight 30W and try 10W-30 on your next oil change. The 30W maybe is too thick at startup.
RE your wife's Acura: when you do an oil change, fill up the new filter w/ oil before installing it. Should help get oil to the engine sooner.
jlex.
'70 std. "Elsie"
'88 Carrera
bjet767
bjet767 is offline
PostPosted: Mon Dec 14, 2009 10:32 pm    Post subject: Reply with quote
"But the engine (bearings?) sound louder for a couple of seconds and then quiet out. It doesn't do this if you shut the engine off for just a few minutes and then restart. "
Sounds to me more like lifters than bearings.
I have had failed bearings before and you will notice them and it will not go away as the engine warms up. Additionally your engine will run very hot if a bearing is failing.
I would check cold valve clearances.
superdubbr
superdubbr is offline
PostPosted: Wed Nov 25, 2009 2:16 pm    Post subject: Reply with quote
I haven't seen anything sparkly...not running a magnetic drain plug. Are they a good idea? I did find some black crud on the top of the heads around the valve drain (doubt that is related to this issue.) The first time I adjusted the valves (when I got the car) I cleaned this all out. I do find bits of it in the oil screen every time I do an oil change. Haven't seen anything else fishy though.
Blue '72 Super Beetle - 1600 DP
superdubbr
PostPosted: Wed Nov 25, 2009 2:13 pm    Post subject: Reply with quote
Forgot to mention, I am running a VDO twin output oil pres sending unit that I picked up last year. Right now, I am only using one terminal to run the stock oil pres warning lamp. When I bought the sender I was planning on adding an oil pres guage, but I haven't gotten around to it yet. (Read on here that aftermarket oil pres guages aren't so great so I put that one on the back burner.) I think the oil pres lamp is working ok. The oil light comes on when you turn the ignition on, then goes out immediately and stays out when you engage the starter and the engine fires.
By no oil pressure, I meant that it sounds the same way most engines do when you have just changed the oil and you first fire them up. (My wife's Acura Integra does this...I assume it is because it takes a second to get oil pressure when the filter is empty.) The oil pres light goes out as soon as you crank the engine. But the engine (bearings?) sound louder for a couple of seconds and then quiet out. It doesn't do this if you shut the engine off for just a few minutes and then restart.
It's done this for the last 10k, I just figured it was because there is no full-flow filter and it takes a second for the oil pump to prime and deliver pressure. Am I wrong?
jlex
jlex is offline
PostPosted: Wed Nov 25, 2009 2:07 pm    Post subject: Reply with quote
Notice anything sparkly in the oil when you change it? Would indicate wear is occuring due to a lack of lubrication or some other problem. If nothing out of the ordinary, that's a good sign.
jlex.
'70 std. "Elsie"
'88 Carrera
Cusser
Cusser is offline
PostPosted: Wed Nov 25, 2009 1:26 pm    Post subject: Reply with quote
What do you mean "no oil pressure" ? Does the warning light stay on for a few seconds, or are you utilizing a gauge (if so: mechanical or electronic sending unit) ?
After a run at operating temperature, it is common for an oil light to flicker, don't worry about it.
By the way, a stock oil sender unit is quite inexpensive, and very easy to swap out, a five minute job which includes finding your 24mm wrench or socket.
superdubbr
PostPosted: Wed Nov 25, 2009 1:16 pm    Post subject: Mysterious noise at startup Reply with quote
My '72 SB daily driver (stock 1600DP) always starts like a champ and runs smooth and strong. I've driven it over 10k miles this year. However, there are a couple of things that concern me - here's the major one.
Whenever the car sits for more than 1/2 hour or so, when I first fire it up, the engine sounds loud, like there is no oil pressure. Sort of a "dragging" sound. The oil light does not come on and the sound stops after about 2-3 seconds. Not sure if it is dry cylinder walls, bearings, or something to be concerned about? Is this normal?
Also, after a long run on the highway on a hot day, the oil light will flicker at idle. Goes out instantly if I step on the gas. I run straight 30w Shell Rotella. I think the engine runs a bit hot in this weather as the dipstick is pretty uncomfortable to the touch.
Reason I ask is that I have the engine out right now to fix oil leaks. Anything I should be concerned about here? Should I be replacing the oil pump? Is it possible my engine bearings are nearing the end of their life? If I believe the PO, the engine now has about 50k on it. (Not the original engine.)
