HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Tue Dec 22, 2009 4:47 pm Post subject: |
The last time I did spring plates with urethane bushings I had the exact same problem. They simply would not allow it to align. Tried greasing them, greasing the splines, clamps, nothing. Finally ordered a set of stock bushings and it was like butta. I haven't messed with urethane since. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
HILLAHOLIC Samba Member
Joined: January 19, 2007 Posts: 110 Location: Elyria, Ohio
chubby53 Samba Member
Joined: February 17, 2005 Posts: 2106 Location: Eugene, Oregon
ess3489 Samba Member
Posted: Mon Dec 21, 2009 12:10 pm Post subject: |
i only have one side in right now so its not the other torsion bar preventing it from going in all the way |
oxfordethan Samba Member
Joined: August 18, 2009 Posts: 238 Location: Oxford, MS
Posted: Mon Dec 21, 2009 7:11 am Post subject: |
ess3489 wrote: |
a video would be great! to me the problem would be solved if the urathane bushing were a tiny bit thinner.....
i have the covers all the way on but it seems like the spring plate is in place at the cover but bending out so that at the stop its not quite over it. still about 1/4 inch out of the stop |
Yeah, a video on the whole process of lifting the rear end this way would be awesome. _________________ "Keep up the good work. You used the term craftsmanship. Don't you mean "craftsman$#&*?" "
'69 Bug being rebuilt
http://www.thesamba.com/vw/forum/viewtopic.php?t=374620 |
Posted: Sun Dec 20, 2009 4:39 pm Post subject: |
so i lowered it one spline and i tried and i think it finally slid over the stop pretty good. its right on the line of the stop but thats better than it was. only problem is i cant get the cover to go all the way on..... it wont godown in the middle. the corners where the bolts are will touch flat but not the middle. its warping or bending out. like i keep saying these bushings are just too big if they were smaller it seems like these peices would fit better together |
Posted: Sun Dec 20, 2009 2:46 pm Post subject: |
next time i do mine, I'll show you , i'll take pics step by step. I'm still in the dark ages, no video camera. hopefully it will help you. , actually I have a swingaxle pan out front i can do and show with that(will be easier with no car attatched.) Won't be able to get to it until the new year though hope that;s not an issue. later _________________ My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100 |
Posted: Sun Dec 20, 2009 2:21 pm Post subject: |
wait there is different torsion bars that i can buy that will make this not a pain.... if there is and thats what the 27mm bars your talking about will work instead of my throwing my back out trying to push and pull this stuff and still getting nowhere please inform me haha. i have just the regular swing axle type 1 i think |
sxuxrxf Samba Member
Joined: May 18, 2005 Posts: 1338 Location: Oceanside, CA
Posted: Sun Dec 20, 2009 2:14 pm Post subject: |
Reading all of this makes me really glad that I went with new 27mm bars. It all bolts up with NO hassles, although I have a good sized notch on 1 side of the dual spring plates for use with type 4 cv's. I just have to put the floor jack under the plate and lift a little against the weight of the car, no chain. _________________ (ignore the X's ) |
Posted: Sun Dec 20, 2009 1:51 pm Post subject: |
and if anyone has a video and can somehow email it to me at [email protected] that would be really helpful thanks |
Posted: Sun Dec 20, 2009 1:49 pm Post subject: |
Posted: Mon Dec 14, 2009 10:21 pm Post subject: |
BTW I have done it so many times I can do both sides in about an hour.
I have to loosen my newer buggy up one notch. I might video tape how to do it because this gets asked so many times. |
Posted: Mon Dec 14, 2009 10:19 pm Post subject: |
I had a similar problem. I did the driver side first and was easy. When I tried to do the passenger side I couldn’t get the cover on without bending it. It was about 1/4-3/8 away and the other side just slid in. I found out I had the driver side torsion bar in too far, not allowing the passenger side bar to go in enough, stopping the cover from going on all the way. |
Posted: Mon Dec 14, 2009 8:13 pm Post subject: |
still having problems i have tried all of those tricks but im still about 1/4 inch from being completely over the stop........ it seems like my inner bushing is so thick that it wont let my spring plate fully slide in....... maybe im wrong i got the urathane ones from bugpack. also i havent connected the end of the spring plate to the axle yet will that pull it that last 1/4 inch????? yall make these spring plates sound easy and i swear after this i am never taking them off again they are giving me way to many problems haha |
neanders Samba Member
Joined: November 12, 2007 Posts: 1146 Location: Spokane, WA
Posted: Fri Dec 11, 2009 12:11 pm Post subject: |
Here's what I did:
1) Use a little white lithium grease on the splines and the bushings (urethane?) so everything slides in and out easy
2) Assemble it all, using longer bolts on the spring plate cover so you can get the started
3) Using the jack and chain, crank the spring plate up so it is above the stop, and start the last bolt
4) Get a big ass C clamp, with one pad on the outside of the spring plate and the other on the inside of the upper shock/ body mount
5) Crank down that C clam until it pulls the spring plate and bushings the rest of the way together
6) Tighten down your spring plate cover, and remove the clamp.
7) Repeat for the other side.
Voila, you're done! _________________ It's mine now and I want a BAJA!!! |
Posted: Fri Dec 11, 2009 11:31 am Post subject: |
if you get the longer bolts(i've never used stainless), and bolt the cover with as many as you can with the spring plate unloaded(no pressure on it) then load it or put it in place and as your doing that tighten the bolts you can a little bit at a time. then put the others in, you may have to pry the cover around a little bit with a small prybar to get the other holes to line up. it is a pain but i'm done this several times with stock bolts. I guess it's just one of those things the more you do it the easier it gets. good luck.
Oh!! make sure that your bolts don't go in crooked, i've done that once, it really sucks to have to try to get it out and retap your threads. _________________ My build:
Posted: Fri Dec 11, 2009 10:40 am Post subject: |
i also have a set of old cover i thought about puting over it and hammering with a mallet to see if it will make it slide over...... not sure if thats a good idea or not. im going to trythe pipe idea and then go get some long stainless steel bolts and see if i can pull it over. im just worried about breaking a bolt off.... these things are a pain im going to try to never take them off again haha |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20808 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Dec 09, 2009 7:50 pm Post subject: |
ZARJDR wrote: |
A lot of folks start the covers with longe bolts, and then swap the long ones out once cover is drawn up tight |
Ditto....
Dale _________________ “Fear The Government That Wants To Take Your Guns"
