alnglas Samba Member
Joined: October 22, 2008 Posts: 60 Location: Pascagoula,MS--Atl,GA
Posted: Mon Mar 22, 2010 10:57 am Post subject: |
Thnx for the info and I have a '59 as well as a '58 ragtop so Fluxcap I would love to make a Georgia show at some point this year. Keep me posted as to the show dates! _________________ Do what you like and Like what you do! |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Fri Mar 19, 2010 6:26 pm Post subject: |
I guess it should be noted, if a 61 and earlier car was retrofitted with later taillights, I suppose they could have kept the original 6-wire switch (only using three of the wires) and just ran an extra wire to the back of the car for the brake lights. If you still have the original 6-wire switch, then there really isn't anything more to do than mount your snowflakes and wire them up. Hopefully your snowflakes will cover the extra holes they drilled to mount the later taillights.
If sometime in the past, the turn-signal switch was replaced with the more common 3 wire switch, then you will need to consider the three options above. _________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
veedubfreak59 Samba Member
Joined: February 22, 2010 Posts: 228 Location: Denver, CO
Posted: Fri Mar 19, 2010 6:01 pm Post subject: |
fluxcap wrote: |
alnglas wrote: |
I notice quite a few older models have been fitted w/later model tails just like my '59. I have the snowflakes now I am looking for a how to on converting back????
Anyone?
My search could not narrow down nor find a decent answer. |
Three options
1) Get a 6-wire turn signal switch
2) Make a relay. Andy (glutamodo) has a few post showing what you need and how to wire it up - Here is one thread http://www.thesamba.com/vw/forum/viewtopic.php?p=4266938#4266938
3) Use a trailer converter - see this thread http://www.thesamba.com/vw/forum/viewtopic.php?t=391685
When will we see this 59 at some of the Georgia shows??? |
The snowflakes are gone off my 59 too, so i'm planning on picking up a set of the LED snowflakes so that they look stock, but can actually be seen. |
Posted: Fri Mar 19, 2010 5:38 pm Post subject: |
alnglas wrote: |
Anyone?
Three options
When will we see this 59 at some of the Georgia shows??? _________________ Eric - 1966 camper bus
Posted: Fri Mar 19, 2010 4:53 pm Post subject: |
Anyone?
My search could not narrow down nor find a decent answer. _________________ Do what you like and Like what you do! |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26524 Location: Douglas, WY
Posted: Thu Dec 17, 2009 4:58 pm Post subject: |
Its 1956-1961 for the "snowflake" style tail lights.
How did they hook up those tail lights I wonder, the wiring for a two-bulb tail light is different than a single-bulb, so you'll have to revert this back to the original setup. Hopefully your turn signal switch works properly since that it is the "brain" of the turn/brake light system.
As for finding them, that's why theSamba has a Classified Ads section, you can find many in there, and you can always post a Wanting To Buy (WTB) ad in there as well.
Since that style of tail light is commonly called the snowflake, that's a good keyword for a Classified ads search, try this link out:
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
Hope that helps!
-Andy |
56-61 will work. Do a search in the classifieds here for "snowflake". _________________ Eric - 1966 camper bus
64mustang65 Samba Member
Joined: December 07, 2009 Posts: 23 Location: Somerset,Pa
Posted: Thu Dec 17, 2009 4:53 pm Post subject: 1958 taillights & needed |
I need taillights for my 1958...it has 1964 housings and they are incorrect. Anyone know what year range is the same for my 58? Anyone have a set? Thanks in advance. |
