Windshield Rust Advice
Slow Steve
Slow Steve is offline
PostPosted: Thu Jan 14, 2010 9:29 am    Post subject: Re: Windshield Rust Advice Reply with quote
Aukai wrote:
I just got the sheet metal piece from Gerson of Klassic Fabrications delivered to my house. It's the piece that the lower windshield repair panel welds onto. Thanks everyone for your advice and input. Gerson, muchas gracias!!!!!!!
Post some pics of your repair progress and good luck.
Aukai
Aukai is offline
PostPosted: Thu Jan 14, 2010 2:10 am    Post subject: Windshield Rust Advice Reply with quote
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Jan 12, 2010 4:26 pm    Post subject: Reply with quote
sandblast and paint with POR15 then prime as per their guidelines. it isn't 100% needed to sandblast if you're using POR15 but when the rust is like that i'd do it if you have the ability.
here is a photo gallery with some decent details on replacing the lower channel. the owner of the bus is a member here, velvetgreen.
http://www.germansupply.com/Picture_Galleries/germ...bi.html#15
SL
SkooobaSteve
SkooobaSteve is offline
PostPosted: Tue Jan 12, 2010 2:09 pm    Post subject: Reply with quote
That a tough one, even thought the metal is not rusted through there is still more than likely going to have rust in between the 2 peices of metal.
Jonathan
Romans 6:13
WTB 67 beetle rear seat belts.
59 Euro ragtop build with my dad
http://www.thesamba.com/vw/forum/viewtopic.php?t=493553&postdays=0&postorder=asc&start=0
65 dlx Slow build
http://www.thesamba.com/vw/forum/viewtopic.php?t=391061
joescoolcustoms
joescoolcustoms is offline
PostPosted: Tue Jan 12, 2010 1:54 pm    Post subject: Reply with quote
I am in a similar situation. My Windscreen is rusted pretty well, but no holes or rust through. The overlaying metal is not swelling.
My question is with a condition like this, how does one restore this area and not have rust reappear from under the overlay?
What is the best method, media blast then POR treat, the prime and paint?
Bad News Racing 2018 NORRA 1000 3rd in Class
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Slow Steve
PostPosted: Mon Jan 11, 2010 10:08 pm    Post subject: Re: Windshield Rust Advice Reply with quote
Aukai wrote:
I am replacing the lower section of the windshield frame. I had cut and removed the rusted/rotted lower windshield section. When I put the new lower windshield replacement panel in, I have nothing to weld the bottom of the replacement windshield piece where the bottom of the windshield frame meets the top of the front nose. What do I do now??????
Thanks,
Bruce
What did you end up doing? Pics?
Slow Steve
PostPosted: Mon Jan 11, 2010 12:12 pm    Post subject: Reply with quote
Stanagon wrote:
skiholio wrote:
I think you might have cut the lower part that you could have rested the replacement on. There is a lip if you just cut the top layer of metal. Here's a link to my lower windshield replacement. Hope this helps.
http://kustomcoachwerks.com/forums/viewtopic.php?t=4477
inspiring build thread, esp. since it's being done outside! keep it going.
Thanks! Progress has been slow lately. COLD! And I wish I had a garage.
SkooobaSteve
PostPosted: Mon Jan 11, 2010 8:45 am    Post subject: Reply with quote
When you remove the window metal you have to be carefull not to cut into the nose part that is behind the metal.
The metal is spot welded to it all the way down on the both sides of the lip comming off the nose.
So when you remove the skin of the window seal area it should look somthing like that last picture.
Jonathan
Romans 6:13
65 dlx Slow build
Stanagon
Stanagon is offline
PostPosted: Sun Jan 10, 2010 7:25 pm    Post subject: Reply with quote
Stan's Classic Service, specializing in air-cooled VWs:
http://www.thesamba.com/vw/classifieds/detail.php?id=614073
www.stanagon.com
My '61 Mango bus thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=110367
My '64 vert thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=386344
My '71 squareback thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=637709
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Sun Jan 10, 2010 3:15 pm    Post subject: Reply with quote
skiholio wrote:
I think you might have cut the lower part that you could have rested the replacement on. Here's a link to my lower windshield replacement. Hope this helps.
i bet you are right.
if so you now have to fab a new upper section for the nose skin to attach the window frame too. up side is it well could have been rotty if your sills were really bad
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
Slow Steve
PostPosted: Sun Jan 10, 2010 3:10 pm    Post subject: Reply with quote
Campy
Campy is offline
PostPosted: Sun Jan 10, 2010 1:18 pm    Post subject: Reply with quote
I am not sure what you mean but, once the piece is welded in at the top and side edges, the sill is spot welded to the nose panel.
Don't worry; be happy. (Baba)
iamdonquixote
iamdonquixote is offline
PostPosted: Sun Jan 10, 2010 7:58 am    Post subject: Reply with quote
how much of a gap are we talking about ?
a pic would help.
Aukai
Aukai is offline
PostPosted: Sun Jan 10, 2010 3:32 am    Post subject: Windshield Rust Advice Reply with quote
Thanks,
Bruce
