Viewing feedback for: FritzCP Email: [email protected] Last Visited: August 30, 2025
volksnut Samba Member
Joined: November 16, 2002 Posts: 407 Location: winter park, florida
Posted: Tue Mar 25, 2025 7:09 am Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
Well packed and as described, came quickly too. Would buy from again. Thanks |
dphdo Samba Member
Joined: March 16, 2007 Posts: 11 Location: Athens, Ohio
Posted: Sat Jul 13, 2024 4:13 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
I bought the VW Rear Bearing Puller from this company. I had a problem with one of the "arms" of the puller. I wrote them about the problem, not expecting anything to be done, but lo and behold - they sent me two new arms for the puller - No Questions Asked!!!
He is obviously a man of integrity and honor. I HIGHLY recommend his products and company.
SMILES
Dale |
sgtmikeusmc Samba Member
Posted: Mon Jan 22, 2024 6:08 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
Received my 6306 Bearing puller today, fast shipping to California. This tool works amazing had my bearing off in less than 5 minutes.  |
Viking Volks-Werks Samba Member
Joined: May 30, 2023 Posts: 1 Location: Hesperia, CA 92345
Posted: Fri Oct 20, 2023 7:12 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
I just got the pair of these in the mail today.
So, I haven’t even used these yet, aside from grabbing an original screw, and a new aftermarket tin screw.
These are great. Like, for freaking real!!! Fits very nicely, hardly any play , fits solid!!
This is in reference to the “tin screw torqued” tool. That’s the email I sent him. And I tried it on a couple screws after that. Worked great. |
thom Samba Member
Joined: October 12, 2000 Posts: 6200 Location: Sacramento
Posted: Sun Sep 03, 2023 11:14 am Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
I used the pulley puller on a motor that has been sitting outside for over 20 years - came off without any drama whatsover. I've ruined several pulleys over the years by using the around-the-edge pullers.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Geetloaf Samba Member
Joined: November 20, 2006 Posts: 52 Location: Green Bay
Posted: Sat May 27, 2023 4:02 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
I purchased the vinyl and endcaps to rebuild my middle seat grab handle. The quality and accuracy of this reproduction is admirable. Restoration quality to be sure. Shipment arrived at my door in less than 24 hours. Very nice, Brad |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1362 Location: So. Cal
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1338 Location: roseville, ca
Posted: Fri Apr 21, 2023 5:04 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
Just purchased a swing axle bearing puller, and then saw the pulley puller, so I bought that too. Arrived in two days, very well packed. These tools look pretty awesome! I don’t need them, yet, but I’d rather have them and not need them. Also, buy good stuff when you see it for sale, because it won’t always be around. |
McFunzeepants Samba Member
Joined: February 04, 2015 Posts: 135 Location: Santa Cruz
Posted: Thu Mar 02, 2023 3:56 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
That Pulley puller works like a dream!
It is expensive, but well worth it-I'd buy it again. It removed a very stubborn pulley in under 20 min.
Great communication with Bradley and they shipped it almost immediately.
I didn't have to grind anything off of the puller or the pulley to make it fit-I just unbolted one of the fingers, placed it in one of the pulley slots then re-bolted it back together. |
DesignBuild Samba Member
Joined: September 29, 2016 Posts: 401 Location: HOUSTON, TEXAS
Posted: Sun Nov 06, 2022 12:16 am Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
I too purchased a Fritz 124 pulley puller and I was led to Bradley's ad by Hazetguy. I was looking for the pulley removal too VW203 and EverittB suggested two guys to contact, which I did. Hazetguy came back with a message that had a link to Brad's ad on TheSamba. I read and watched some YouTube videos that said to just pry it off. Well, I have a magnesium case that is 50 years old and I would prefer not to crack it. Paying $100 for a well made tool is reasonable compared to the alternative.
This is a very well made tool. Note that the fingers can be difficult to get into the OEM pulley extraction holes so you may want to Dremel some material on the outer radial edge of the two holes. Put a strip of rag around the pulley hub where it is against the engine case to keep crap out from any grinding. Remove a small amount of metal from the outer most edge of the hole. When you are able to get the second finger into it's corresponding hole without much difficulty you have removed enough. Note that the pulling fingers should be facing the crankshaft. I found that the best position for the pulley was with the holes on a horizontal line. Snug the center bolt with your fingers to hold the puller to the pulley hub and check to see that both fingers are hidden behind the pulley. Use a 17mm open end wrench to turn the center bolt. Since the puller is operating close to the center of the crankshaft the pulley should come off easily. My pulley came off after being in place for about 50 years.
For all of you with Type 3 engines, this tool may work to remove the fan mounted to the crankshaft, so check it out. It only pulls on the machined steel hub.
Kudos to Bradley for making a very good copy of the other very expensive brand of pulley puller. I ordered this last Thursday and had it in my hands the following Saturday; 2 day shipping. I had it before the USPS recognized that they had shipped it.
If you couldn't tell, I recommend Bradley for any purchase you want to make. |
SLO-N-LO-69 Samba Member
Joined: July 06, 2006 Posts: 646 Location: Central Florida
Posted: Tue Nov 01, 2022 4:13 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
I just purchased a pulley puller and can't be happier. It took about 30 seconds to get the pulley off and in perfect shape. I've been fighting with that pulley for a week and this thing pulled it off no sweat! A wonderful product well worth every penny. |
Tom Mohr Samba Member
Posted: Fri Jul 08, 2022 9:04 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
Received item quickly and it was as advertised, very happy. Thank you |
restojohnny Samba Member
Joined: February 13, 2004 Posts: 2841 Location: SPLITSVILLE , SON !!!!
Posted: Fri Feb 04, 2022 6:29 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
Recieved my item super quick and As described ALWAYS a pleasure dealing with Brad. Thankyou brotha  _________________ $$$ HUSTL'N AIN'T EAZEE $$$
** HELL YEAH I'LL SELL IT TO YOU**
O.G. POMONA VULTURE
MAGNESIUM BRM HOARDING BASTARD !!!!
$$ SWAPMEET MAFIA $$
48 split $$$$
53 LHD, LH cargo door standard kombi
54 Pre-A Porsche
55 oval ribbed door non-semiphore
56 semiphore ragtop
63 notchback (work in progress)
67 original Empi GTV beetle convertible !!
67 deluxe walkthru (work in progress)
67 convertible ghia (work in progress)
"STAY OUTTA MY BACKYARD !!! " |
Miskeroo Samba Member
Posted: Sun Nov 14, 2021 11:40 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
Westy spice bracket
My recent transaction with Brad went well.
Easy communication and fast Shipper.
Thank you Brad |
Sunroofgod Samba Member
Posted: Thu Jul 29, 2021 3:03 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
Brad was quick to reply to messages and items were exactly as described and shipped out quickly. Would definitely do business again in the future. |
jeffavatech Samba Member
Joined: March 01, 2009 Posts: 147 Location: Titusville, Florida
Posted: Sat Jul 17, 2021 6:14 am Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
Just got the grab bar kit and I have to say he was very fast and the kit worked great! It's the right color and style.  |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1334 Location: south san francisco
Posted: Wed Feb 03, 2021 5:11 pm Post subject: Re: Volksheime / FritzCP - [email protected] - Brad Due |
just bought one of his fritz pulley pullers. well made! a must have .
do not spend $35+ on a crappy empi covid-19 puller that bends
the pulley into a taco! fast shipping recommended seller .
thanks brad. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
akomjathy Samba Member
Posted: Fri Jun 21, 2019 1:01 pm Post subject: Re: Volksheime - [email protected] - Brad Due |
Brad is a very helpful and nice guy!! I was looking for a pop-out window latch part and he emailed me that he has got one for me. He gave it to me as a gift!! I had to pay only for the shipping cost to Budapest/Hungary. The part arrived in great condition, packaging was also great and shipping was very quick!! Hope to deal with him again in the future! Thanks very much: Attila |
plasticman1432 Samba Member
Joined: January 19, 2004 Posts: 1180 Location: Nosebleed seats, NY
Posted: Thu Aug 02, 2018 5:51 pm Post subject: Re: Volksheime - [email protected] - Brad Due |
Got my Bus bottle openers this week, and they are most excellent!! Brad's communication all along was top notch, and his products are even better.
Thanks, Brad! _________________ Organized people are just too lazy to look for stuff
'68 Meyers Manx: M1689D815E
http://public.fotki.com/VWDave/ |
blondin Samba Member
Joined: November 20, 2004 Posts: 11 Location: Nantes (FRANCE)
Posted: Thu Aug 24, 2017 11:38 am Post subject: Re: Volksheime - [email protected] - Brad Due |
Hi
I bought a westy cargo door sill floor trim plate repro from Brad.
Great communication,fast shipping and very good package...!!!
It was a pleasure to deal with him!
Steph |
