Frankenmirror
hiram6
hiram6 is offline
PostPosted: Sun Apr 11, 2010 2:51 pm    Post subject: Reply with quote
Yes, you can. The "ball and socket" mounts just pop out with a little effort, and they are the same size.
Exactly what I did with mine. I also added a longer bolt for the brace with a rubber cap on it to snug up against the windshield. Can't remember the size, but it was easy to find at the Depot, it's a metric thread of course.
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
Orbitald
Orbitald is offline
PostPosted: Sun Apr 11, 2010 10:41 am    Post subject: Reply with quote
So I got one of those '69 Bay Window mirrors and was wondering if I could attach the more modern mirror from my Vanagon to the older bus shaft.
Any advice on that would be greatly appreciated.
'87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing
jizae
jizae is offline
PostPosted: Mon Mar 29, 2010 2:36 pm    Post subject: Reply with quote
Whoops! You did say that- I dont know what the state's laws are where you are, so perhaps that extended rear view mirror would be considered legal there- I can only speak for my experience in California, and I havent heard of or seen anything against the dual mirror setup unless it was unusually large or something.. Well, other than the alternatives mentioned above, thats all I can think of.. Good luck 2 u!
campism
campism is offline
PostPosted: Mon Mar 29, 2010 2:29 pm    Post subject: Reply with quote
Right. I stated initially that I did have the dual setup that got kiboshed by the state inspectors so I'm working on alternatives.
jizae
jizae is offline
PostPosted: Mon Mar 29, 2010 1:38 pm    Post subject: Reply with quote
I would show you MY rear view setup, but I dont have pics on me right now; I'm in California, where the revenue enforcers would love to find one of those custom rear view mirrors to give you a citation for (supposedly for blocking the driver's view, or some BS like that- the same violation they give somoeone for having anything hanging from the rear view mirror in CA)..
To solve my rear view action, I have TWO rear mirrors: I have the regular stock one, but THEN I have a second rear view mirror that I got from the junkyard from some GM or Ford car or truck- I forgot specifically what make and year, but it really doesnt matter, go to a junkyard and get one out of ANY car or truck that you like the width, size, and view from it...
...So what I did is I glued it onto the dash itself upside down, where you can adjust it from its stem/base the same way you can your regular overhead stock rear view mirror. That way you can see everything you otherwise CAN'T behind your cabinet... Scenery behind you, mountains, trees, whatever..
presslab
presslab is offline
PostPosted: Mon Mar 29, 2010 8:53 am    Post subject: Reply with quote
No vibes at all. Mine touches the glass, you can just see the little clear rubber bumper in the pic.
Your mirror looks different than mine, you might need to angle the pipe a bit.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
buildyourown
buildyourown is offline
PostPosted: Sun Mar 28, 2010 5:24 pm    Post subject: Reply with quote
Just get fisheyes for the side mirrors and learn to use them. After years of driving trucks with canopies and no windows, I never look in the rear view.
JeffRobenolt
JeffRobenolt is offline
PostPosted: Sun Mar 28, 2010 3:39 pm    Post subject: Reply with quote
For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com
campism
campism is offline
PostPosted: Sun Mar 28, 2010 3:10 pm    Post subject: Reply with quote
Cool. Time to revamp mine. How is your mirror for vibrationlessness?
presslab
presslab is offline
PostPosted: Sun Mar 28, 2010 1:45 pm    Post subject: Reply with quote
Here is mine. The tarnished copper almost matches the brown color. Laughing
JeffRobenolt
PostPosted: Sat Mar 27, 2010 4:45 pm    Post subject: Reply with quote
There is something that fits in the original mirror hole perfect to fill it.
Can't see the forest thru all the tree's??
I have a windshield mount auto dim, temp, compass, homelink, led light mirror.
Take your stock mirror and rip the rubber coating of the base. Cut the stem off and clean it up on a grinder. Wire wheel to polish or paint to taste.
Most cars today come with windshield mount mirrors, can't see it being a problem. With the hole covered it would take a van owner to realize it is not factory and a van owner will be impressed.
I'll take pic's when I get home.
DAIZEE
DAIZEE is offline
PostPosted: Sat Mar 27, 2010 4:20 pm    Post subject: Reply with quote
I bought a clip on wider mirror with 1/4 of the right side being panoramic. I feel much more comfortable with it than the original which is still there under. Then I balance both outside mirrors and there is not a spot I can't see without moving.
Go Westy has a stick on rear view enhancer, I forget what its called but it changes the shape of the rear windshield from flat to convex. I'm thinking of getting one.
Here in Ontario you would probably be charged with windshield obstruction as they are going after anything on the windshield that interferes with seeing. Even going after some GPS, not all but some. I got my extended mirror from Canadian Tire (it was on sale). I know where there is a better one but they are so popular they seem to always be back ordered.
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
spitsnrovers
spitsnrovers is offline
PostPosted: Sat Mar 27, 2010 4:17 pm    Post subject: Reply with quote
Nice mod campism. I've been plagued with this problem as well - being taller than average, and installing higher than original seats.
I mounted a mirror to the junk box mounted on the dash, but it vibrated too badly to be of use.
I picked up a "glue to the windshield" version from the junk yhard, but will heed your warning about the highway troopers.
Like the idea of extending an original like you did.
thanks for the input.
'88 VW Westfalia
'75 Triumph Spitfire 1500
hiram6
hiram6 is offline
PostPosted: Sat Mar 27, 2010 3:49 pm    Post subject: Reply with quote
stevey88 wrote:
Why don't you install a rear view mirror that has a glue on base to the glass ?
I did this before finding the baywindow mirror. To me, one of the generic glue-ons was too far away from me when mounted to the windshield. BTW, if you try this and don't like it, it is truly amazing how easy you can unglue that base with acetone. It practically jumped off the windshield!!!
1996 Mazda Miata
campism
campism is offline
PostPosted: Sat Mar 27, 2010 11:41 am    Post subject: Reply with quote
I may again and dispense with the upper one but that'll leave an unsightly hole to be dealt with. You know, it's just one damn thing after another. Might be an idea to convert that mirror stalk to a mount for dual map lights or something like that. Who knows?
stevey88
stevey88 is offline
PostPosted: Sat Mar 27, 2010 9:30 am    Post subject: Reply with quote
Steve
240Gordy
240Gordy is offline
PostPosted: Sat Mar 27, 2010 7:45 am    Post subject: Reply with quote
all the big trucks and all the big buses have no rear view mirror, only side mirrors.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
Vsyevolod
Vsyevolod is offline
PostPosted: Sat Mar 27, 2010 1:16 am    Post subject: Reply with quote
I put a second mirror on the dashboard. It was from my FLAPS and was designed to be a glue-on replacement for a windshield mirror. I mounted a block of wood to the dash, about 4" tall. Then screwed the mirror mount to that wood piece and there you have it. Sorry, no photos, the van made it to Ashland last August before deciding to give up the ghost.
Having two mirrors was ideal for me. The upper mirror gave me the view of two cars behind me, while the lower mirror gave me the long view out the back. I wouldn't want just one mirror in a Westy.
Stephen
presslab
presslab is offline
PostPosted: Fri Mar 26, 2010 8:28 pm    Post subject: Reply with quote
I cut mine like yours, hammered some copper water pipe over the metal part on each piece, and extended the mirror so it touched the windshield. I used a rubber bumper where it touched. It works pretty good, not bad looking either. Smile I'll get a pic up later.
campism
campism is offline
PostPosted: Fri Mar 26, 2010 7:40 pm    Post subject: Reply with quote
Naw, man, it's cool. Live and learn, right? Anyway, it was the inspiration to try improving something that needs it. Thing is, if the one you found were reproduced I'll bet every Vanagon Westy driver out there would buy one.
