harryset Samba Member
Joined: July 14, 2005 Posts: 690 Location: Bemidji, MN
Posted: Thu Apr 22, 2010 8:48 pm Post subject: |
I can't see any way possible that someone could seriously think that putting sound deadening materials/insulation on the engine bay walls would, or could cause the engine to run hotter. Unless you are relying on heat transfer into the passenger compartment part of the engines cooling system. Ok, I'll concede that if you used enough mass to block the normal airflow you'd run into problems.
Cooling air is drawn in through the bay louvers by the engine fan and blown out underneath and behind the vehicle. if your sheet metal is intact. Putting sound deadening material on the bay walls keeps heat and sound from transfering from the engine bay to the passenger compartment, it insulates the passenger compartment, not the engine bay. Having these materials on the bay walls in no way should cause the engine to run hotter. _________________ '72 Standard
Proud owner of a "Hoover Bit"
185 60's up front, Empi disc kit, 2 1/2" drop spindles, 185 65's in back, stock drums.
Sound Deadening by Secondskin |
LTL4 Samba Member
Posted: Thu Apr 22, 2010 9:23 am Post subject: |
that is true... I lived in SAC town, for 4 years and that is pretty dry in the summers. But went to the bay area all the time, thats perfect ACVW weather.... _________________ Newbie
Ty, 67 Sedan |
Hippopotabus Samba Member
Joined: May 27, 2004 Posts: 1600 Location: Miwuk Village, CA
Posted: Wed Apr 21, 2010 6:38 pm Post subject: |
Right on man! I'd listen to anyone who kept his or her bus alive in that heat. I'm always amazed at the folks who drive ACVW in AZ.
Its a dry heat... .....
Taking cooling advice from someone in San Francisco is like taking child counseling advice from Jeffery Dahlmer.
 _________________ Celer, Silens, Letalis
www.2dreconbn.net |
LTL4 Samba Member
Posted: Wed Apr 21, 2010 4:48 pm Post subject: |
That is true, Again that is what I was told, and over heating can come from a great number of different things. _________________ Newbie
Ty, 67 Sedan |
Posted: Wed Apr 21, 2010 4:15 pm Post subject: |
Dude not laughing at you but the folks who said that. I drive in really hot conditions in the summer and as long as the fan is spinning, your engine is tuned properly, and you have no air restrictions your fine.
That is to funny. _________________ Celer, Silens, Letalis
www.2dreconbn.net |
LTL4 Samba Member
Posted: Wed Apr 21, 2010 3:39 pm Post subject: |
most of the sound proofing materials are a form of installation, which is what is used to keep heat in... I have not tried doing this to my car, because some VW people in AZ have said that the extra installation can cause heat to be trapped in that area and then your fan will suck in that hot air and can cause over heating. _________________ Newbie
Ty, 67 Sedan |
Posted: Wed Apr 21, 2010 2:17 pm Post subject: |
Wondering if you could explain a little. Why would sound proofing effect the cooling capabilities of an aircooled engine. Nothing restricts airflow it just deaden's the sound. _________________ Celer, Silens, Letalis
www.2dreconbn.net |
LTL4 Samba Member
Posted: Wed Apr 21, 2010 1:12 pm Post subject: |
You cant really do that in AZ, to hot and with that and the heat in the summer good bye VW.... _________________ Newbie
Ty, 67 Sedan |
Posted: Wed Apr 21, 2010 10:08 am Post subject: |
I've done my engine bay with the aluminum (looking) bubble wrap. I like it and at night when I turn on the light (engine bay light) it helps illuminate the whole engine bay. _________________ Celer, Silens, Letalis
www.2dreconbn.net |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon Apr 19, 2010 5:22 am Post subject: |
| zeroman wrote: |
nothing....
leave it.. put stuff on the inside.. if you want |
agreed
i just cleaned up my firewall, shaved all the tarboard spikes and painted it
looks alot nicer than those cruddy chrome firewalls or tarboard
i've got good quality insulation under my parcel tray carpet and its no louder now than when i had the tarboard in
i dont think stock tarboard has real good sound and heat proofing properties anyway compared to todays insulations like dynamat and similar _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
RomanBug Samba Member
Joined: October 10, 2009 Posts: 44 Location: Rome, Ga
Posted: Sun Apr 18, 2010 10:40 pm Post subject: |
| Be careful what you use and how well its attached. A guy i know used the firewall kit from WCM. The piece in front of the engine melted down and covered the fan in the shroud. It did its best to burn up a week old motor. |
zeroman Samba Member
Joined: February 05, 2010 Posts: 891 Location: Cane field
Posted: Sun Apr 18, 2010 2:36 pm Post subject: |
yA... it really depends on the amount of noise you can take and what condition your interior is.
I have (currently) NO sound proofing. But with the top down.. its still not audible. _________________ 77 super convertible |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Sun Apr 18, 2010 1:32 am Post subject: |
nothing....
leave it.. put stuff on the inside.. if you want _________________ 77 super convertible |
Posted: Mon Apr 12, 2010 8:48 pm Post subject: Sound proofing material in engine bay |
I've got my engine bay de-rusted and POR'd, trying to decide what to put back in, really trying to avoid the old tarboards. _________________ '72 Standard
