Fire Wall Tin? What fits?
mark_85226
mark_85226 is offline
PostPosted: Wed May 12, 2010 5:13 am    Post subject: Reply with quote
this link may help your situation!!
http://www.kustomcoachwerks.com/forums/viewtopic.php?t=3914
Mark
murray7010
murray7010 is offline
PostPosted: Tue May 11, 2010 6:17 pm    Post subject: Reply with quote
oh ok. i understand now. thanks for the input.
1951 Deluxe Sunroof Beetle (11C Model)
Follow the resto up to date on Instagram @SplittyMcFiddyJuan
10/2013----->http://www.youtube.com/watch?v=B2dHtL-_80g
Dave
Samba Elder
Dave is offline
PostPosted: Tue May 11, 2010 3:07 pm    Post subject: Reply with quote
Your whole engine is wider.
The 36 horse has a 64mm stroke, your 2110 has an 82mm stroke. that's a combined total of 36mm extra width, the size of your rear axle or flywheel gland, nut. It's not GOING to fit correctly.
Honestly? Id use the one you have as a pattern, het some tin snips, and a chunk of sheet metal, and make your own, if you have the tools. Otherwise, make the one you have, fit as well as you can, knowing that it is going to be too narrow.
2003 Samba Chummie Winner- Best Story
"Those that matter, don't mind,
and those that mind, don't matter"
murray7010
PostPosted: Tue May 11, 2010 2:34 pm    Post subject: Reply with quote
not wide enough where? around the arch of the block? if so, i think id rather trim from there than from everywhere else.
sgmalt46
sgmalt46 is offline
PostPosted: Tue May 11, 2010 2:31 pm    Post subject: Reply with quote
no easy fix. a 25/36/40 motor is not as wide. trim to fit? or live with it? Confused
murray7010
PostPosted: Tue May 11, 2010 2:06 pm    Post subject: Reply with quote
ANYONE?
murray7010
PostPosted: Tue May 11, 2010 8:34 am    Post subject: Fire Wall Tin? What fits? Reply with quote
Hello all,
Quick question. I have a 2110 in my split with an autolinea block and Im not satisfied with the unorthodox fit and look of the aftermarket late model firewall tin that the previous owner slapped back there. I have the motor out currently and was wondering if anyone here could tell me if i am correct in assuming the tin that i need to fit my firewall arch is the 25 or 36 horse rear firewall tin? will the 40hp tin fit? just want to make sure i get what works with my application. thanks again.
