3BT Baja
Page: 1, 2, 3  Next
sloboatnova
sloboatnova is offline
PostPosted: Mon Feb 09, 2015 8:51 am    Post subject: Reply with quote
I got the main jets done, but need an idle jet between 55 and 60. But that will have to wait. I'm in the middle of a tranny upgrade and new torsion bars.
I fitted the oil cooler with 2 small gocart radiator fans, but haven't put it on my car yet. I'm gonna wait till I get on the trail some to see if I need them. If it doesn't need them, I won't run it as its more things to go wrong or break or leak.
Ms Hoover, I glued my head to my shoulder.
3BT Baja build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=417564&highlight=3bt+baja
Snowking63
Snowking63 is offline
PostPosted: Sun Feb 08, 2015 11:41 pm    Post subject: Reply with quote
My 44idf looks better on your car! Lol i know you were having jetting problems how's it working out? Ever end up using the external cooler?
Money is a gas, not a trip
OGK
my 63 baja daily driver
http://www.thesamba.com/vw/forum/viewtopic.php?p=6485278&highlight=#6485278
Bashr52
Bashr52 is offline
PostPosted: Wed Nov 05, 2014 8:09 am    Post subject: Reply with quote
Those look cool! You could have fixed your backfeed issue a number of ways, but adding a second light is the easiest Laughing I wired up euro style single filament turn signals to my Thing to be both turn and parking lights. I ran the parking light through a resistor to drop the input voltage to around 8 volts, so even with the lights on at night, once I engage a turn signal the bulb will see a full 12 volts and flashes brighter.
I probably would have thrown a relay in your rear light circuit so if the turn signals were engaged with the brake lights lit, it would override the brake light and just flashed the turn signal.
sloboatnova
PostPosted: Mon Nov 03, 2014 8:25 pm    Post subject: Reply with quote
Heres what I have left on the list before I can go wheelin.
swap to a 3rib
build a bumper/skid plate
install a real air filter
Other things I plan on doing is:
roll cage
better seat restraints
re-wire the whole car
build and install thing beams
3BT Baja build page
sloboatnova
PostPosted: Mon Nov 03, 2014 8:19 pm    Post subject: Reply with quote
Something else I did was fabbed some rear brake lights. I took my stock housings, removed the lenses, blanked them off flat, cut ovals for sealed LED, and installed halo style LEDS.
Pics dont come out right, but it looks solid.
I wired them up with the turn signal and brake together, but that didnt work. Turn signl would back feed and light u both brakes. So I added the 2" orange leds for turns.
3BT Baja build page
sloboatnova
PostPosted: Mon Nov 03, 2014 8:10 pm    Post subject: Reply with quote
Haven't updated this for a while but this baja keeps gettin better. I built a 1915 for it.
Specs
AS41 case case drilled and tapped for full flow
CB Perf CW / cross drilled crank / 8 dowel
Scat 5.5" rods
Mahle 94mm jugs
Engle 110 cam and followers
DRD 049 heads 40/35.5
single Weber IDF44
glenns rebuilt 019
CB perf maxi30 pump and 1.5qt slimline sump
Trimil sidewinder
This thing hauls but now. I doubled my power!!! Its almost scary.
3BT Baja build page
cmiller95
cmiller95 is offline
PostPosted: Tue Apr 17, 2012 8:55 pm    Post subject: Reply with quote
you could change to a hook and rod setup
Swing axle: Eating tires since 1938
My Rail Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=427627
My Baja Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466974
thext94
thext94 is offline
PostPosted: Tue Apr 17, 2012 6:56 pm    Post subject: Reply with quote
sloboatnova wrote:
Went wheelin this weekend and broke another lower ball joint. It was the other side this time. This is getting old quick. I have limit straps on the front, but the joint pulled right out of the pocket. Before I started wheelin, I replaced all of the ball joints. Could it be that maybe I didn't clock them in the right direction? Maybe my limit straps need tightened due to stretch or poor attachments? Does anyone make a ball joint that is supposed to be stronger than stock?
Interesting that your breaking balljoints so frequently, I am yet to have any problems with mine, and I like to think I beat it pretty hard. I realize this post is old so you may have solved the problem by now, but maybe tightening the straps like you said would help
Tyler
X-jeeper
X-jeeper is offline
PostPosted: Tue Apr 17, 2012 2:58 pm    Post subject: Reply with quote
i just found the baja im gona model mine after...when i get one! Love the look of it!
sloboatnova
PostPosted: Tue May 31, 2011 9:58 am    Post subject: Reply with quote
3BT Baja build page
sloboatnova
PostPosted: Sun Mar 06, 2011 8:07 am    Post subject: Reply with quote
Makin some progress. Travis and I modified my trailer to hold 2 baja's.
Should be safe after I tied em down all around.
We also fabricated mounts for my new winch. We welded the mounting plate to a reciever so that it doesn't stay mounted when not in use.
storage mount
We also put a different steering box on as I couldn't get the play to go away. I also put an Weber progressive to 2 stage air cleaner adapter on so I could keep my good filter. I'll post pics later.
3BT Baja build page
sloboatnova
PostPosted: Sat Feb 12, 2011 10:02 pm    Post subject: Reply with quote
So, today I bought a used Weber progressive 26/27 with intake. I put in on and drove a few miles to check it out. It definitely has more juice than the 34 pict solex. Hopefully it will hold up better on the trails too.
Now I need to figure out what I want to do for the air cleaner. I like the one I have, but it doesn't fit the progressive as it has an odd shape. I am considering using the adapter in the link. I could either use it to attach my old filter, or I might plumb my air inlet into the cab. I'm wondering if this adapter restricts air flow? Any input?
http://www2.cip1.com/ProductDetails.asp?ProductCode=C12-1529
Does anyone have they're air inlet plumbed into the cab? If so, some pics would be nice. I'm curious how loud it might be.
3BT Baja build page
sloboatnova
PostPosted: Thu Feb 03, 2011 12:41 pm    Post subject: Reply with quote
Thats a good idea. I could weld some steel to the nuts to make it like the large wingnut in your pic, but not so big. Then drill holes in the steel that I could tie together with a cable so they can't back off. I have some extra rubber pads that go between the front beam and the body that would be perfect.
3BT Baja build page
pafree
pafree is offline
PostPosted: Thu Feb 03, 2011 11:48 am    Post subject: Reply with quote
sloboatnova wrote:
I would like to make is to find a way to secure it tightly that won't require a wrench to remove it. I might try to find some large wingnuts if I feel they will not loosen up..
maybe make a small version of a spare tire wing nut that you could put a pipe on the wing to turn it off and tighten. add a spring or sponging piece of rubber under the jack so when you tighten it then the spring would apply pressure and just add a clip encase the nut backs off.
sloboatnova
PostPosted: Wed Oct 20, 2010 5:59 am    Post subject: Reply with quote
After busting a ball joint last time I went out and not having a jack, I got me a 48" farm jack. I mounted it to the rear bumper. Gotta be prepared.
3BT Baja build page
Lotrat
Lotrat is offline
PostPosted: Thu Aug 19, 2010 9:59 pm    Post subject: Reply with quote
sloboatnova wrote:
Lotrat wrote:
sloboatnova wrote:
Any idea's on why it broke out?
How old was it? Was the boot split at all?
I put all new ball joints in last fall. I've only been wheelin about 6 or 7 times. The boot was split.
It's not often you find someone who knows how old their broken ball joint it. Once the boot splits, it fills with dirt and sand and wears in no time. Add a little off-roading fun and they go pop.
Once I get a little in and out movement out of mine then I replace them. Not worth the headache.
Jackman wheels will have a "J" on one of the spokes.
Volksmeister
Volksmeister is offline
PostPosted: Thu Aug 19, 2010 9:39 pm    Post subject: Reply with quote
HAHA Thats funny, I cracked off a piece of my front fender from the front tires hitting in EXACTLY the same shape.... I trimmed them up, no probs. Looks like a fun time.
-Levi
sloboatnova
PostPosted: Tue Aug 17, 2010 8:05 pm    Post subject: Reply with quote
3BT Baja build page
sloboatnova
PostPosted: Tue Aug 17, 2010 8:03 pm    Post subject: Reply with quote
Lanceonthelake wrote:
what wheels are those?
I've been told they are old Jackman wheels, but I haven't confirmed that. Next time I have them off, I am going to look closely for some markings. They were on the car when I bought it.
3BT Baja build page
Lotrat
Lotrat is offline
PostPosted: Tue Aug 17, 2010 1:41 pm    Post subject: Reply with quote
Page: 1, 2, 3  Next
